HMG 3.3.0 (Stable)
- dragancesu
Re: HMG 3.3.0 (Stable)
I had a problem with images, pictures 32 * 32 bmp format used in the toolbar some were not shown when I compile with 3.3, were shown black squares, respectively 4 images were black, the other 6 were well illustrated
I put the other but also, when I put the image in PNG format was shown to be, a total of 14 images
Are there any restrictions on the format or size?
I feel the samedragancesu wrote:I had a problem with images, pictures 32 * 32 bmp format used in the toolbar some were not shown when I compile with 3.3, were shown black squares, respectively 4 images were black, the other 6 were well illustrated
- srvet_claudio
Daniel podrías subir un par de las imágenes del ToolBar que no se ven en tu ejemplo.danielmaximiliano wrote:I feel the samedragancesu wrote:I had a problem with images, pictures 32 * 32 bmp format used in the toolbar some were not shown when I compile with 3.3, were shown black squares, respectively 4 images were black, the other 6 were well illustrated
HMG 3.3.0 (Stable)
Dear Rathi,Pablo César wrote:In _HMG_HPDF_INIT function we can count with lLog argument when developper wish to have a details of fonts applied for ttf and UNICODE ones. But this argument always is false, I mean there was not any parameter option at C:\hmg.3.3.0\INCLUDE\hmg_hpdf.ch.
Probably was has lost the include file due so many details and hard work for release composing. Please note below:
This do you think is possible to be included ? Please confirm.Rathinagiri wrote:Ok Pablo.
Would you also please make these alterations at C:\hmg.3.3.0\SOURCE\h_HMG_HPDF.Prg on these lines:
HTML_END(nFHandle)
FClose( nFhandle )
To be replaced by these lines:
If lDoLog
FWrite( nFHandle, "</table></body></html>"+CRLF )
FClose( nFHandle )
Endif
Thank you in advanced.
- Roberto Lopez
- HMG Founder
WOW!!!
A really impressive release!!!
Thanks to all for this!
HMG.3.2 compila ok.srvet_claudio wrote: Daniel podrías subir un par de las imágenes del ToolBar que no se ven en tu ejemplo.
BMP del Toolbar
I've edit Polish language file for unicode IDE.
Please, attach it with new version or next patch
- Polish.zip
- (3.58 KiB) Downloaded 892 times
HMG 3.3.0 (Stable)
Bravo !!!mol wrote:I've edit Polish language file for unicode IDE.
Hola a Todos
Compile mi aplicación con esta versión de HMG y lo que hasta el momento he encontrado
es lo siguiente:
En el "preview" de impresión, solo el formato .EMF queda bien grabado, los otros formatos
quedan distorsionados.
Hi Everyone
Compile my application with this version of HMG and what I found so far is the following:
In the "preview" print, only format .EMF is well recorded, the other formats are distorted.
es lo siguiente:
Hi Everyone
- HMG-HPDF01.jpg (243.43 KiB) Viewed 22796 times
- HMG-HPDF02.jpg (141.24 KiB) Viewed 22796 times
- srvet_claudio
Many thanks!mol wrote:I've edit Polish language file for unicode IDE.
