HMG 3.3.0 (Stable)
Re: HMG 3.3.0 (Stable)
I've prepared sample with EVENT.
This event allow to process arrow keys (UP and DOWN) to move pointer of grid while textbox T_WhatToSearch is focused.
It works OK with hmg 3.1.5.
When I try to compile it with hmg 3.3.0, textbox T_WhatToSearch is blocked and doesn't accept any pressed key - alphanumeric or move keys.
What's wrong?
test1.zip
(1.82 KiB) Downloaded 427 times
I've noticed very long compilation time with new version. What's going on?
It would be great to have OnKey trigger in every control, not only in GRID.
Is it very difficult?
Post by EduardoLuis »
Hi Great Masters:
Thanks for your effort and generosity sharing with all of us all your knowledge.-
And thanks to let me be part of the fellowship.-
With regards. Eduardo
mol wrote:I've prepared sample with EVENT.
What's wrong?
Hi Marek.
Change in:
PROCEDURE KeyUpDown_Action(cForm, cCurrentControl, cGridName)
STATIC flag := .F.
LOCAL hWnd, ch
local lFound := .f.
local nPos := len(GetProperty(cForm, cCurrentControl,"Value"))
local nRet := NIL // 0
mol wrote:I've noticed very long compilation time with new version. What's going on?
I have not had that problem, perhaps is due to the new version of MinGW-Harbour and your antivirus.
mol wrote:It would be great to have OnKey trigger in every control, not only in GRID.
I wrote it down on the to-do list.
Claudio :
compilando con Windows Home premiun 64 en modo 32 la aplicacion se compila perfecto pero seleccionando modo 64 bit da una mensaje de error Windres.
te dejo la captura.
2014-05-26 11_04_24-Build Log.jpg (63.67 KiB) Viewed 9305 times
danielmaximiliano wrote:Claudio :
te dejo la captura.
Daniel,
en HMG.3.3.0 falta el parche que va a preparar Rathi con los compiladores de 64 bits.
in HMG.3.3.0 missing the patch that will prepare Rathi with 64-bit compilers.
srvet_claudio wrote: Daniel,
Listo. se agradece la info / Done. is grateful for the info
fouednoomen
Post by fouednoomen »
Many Thanks Mr. Diamond and Dr. Soto :P
Foued
HMG 3.3.0 (Stable)
Dear Rathi,
In _HMG_HPDF_INIT function we can count with lLog argument when developper wish to have a details of fonts applied for ttf and UNICODE ones. But this argument always is false, I mean there was not any parameter option at C:\hmg.3.3.0\INCLUDE\hmg_hpdf.ch.
Probably was has lost the include file due so many details and hard work for release composing. Please note below:
This do you think is possible to be included ? Please confirm.
File C:\hmg.3.3.0\SAMPLES\HPDF\Demo2_UniCode\Demo.prg is with error at compiling by this missing parameter.
