HPDFPRINT with Font cannot be loaded
hmgchang
Post by hmgchang »
Dear Masters & Friends,
i try to load the ttf font :
[img]d:\test\tscparan_TTF.JPG[/img]
but i get this :
[img]fontcannotbeloaded.JPG[/img]
What am i doing wrong ?
Pls help !
Thks n rgds
Chang :)
Just Hmg It !
hmgchang
Re: HPDFPRINT with Font cannot be loaded
Post by hmgchang »
this is what i get : error !
Just Hmg It !
It is something quite difficult to guess what is happen without your code ! :mrgreen:
Probably your font file isn't in current folder. Try to put the FULL path.
hmgchang
Post by hmgchang »
ok Sir, pls find my ssw,
#include "hfcl.ch"
  MEMVAR _HMG_SYSDATA
        Load Window Main
        Main.Center
        Main.Activate
Return NIL
FUNCTION ssw_HPdfPrint( cTtf)
  LOCAL aLine, aFont
  LOCAL cString, cFontname, cPdfname, cStartupFolder
  LOCAL nI
  LOCAL lSuccess
  HB_DEFAULT( @cTtf, '')
  cString := MEMOREAD( "List.TXT")
  aLine := HB_ATOKENS( cString, CRLF)
  lSuccess := .F.
  IF EMPTY( cTtf)
    aFont := GetFont()
    cFontname := aFont[ 1]
    // cFontname := "MS LineDraw.TTF"
    // cFontname := "tahoma.TTF"
    // cFontname := "times.TTF"
    cFontname:= "cour.TTF"
  cPdfName := "ssw_" + STRTRAN( cFontname, ".TTF", "_TTF") + ".pdf"
  SELECT HPDFDOC cPdfname TO lSuccess papersize HPDF_PAPER_A4
  SET HPDFDOC COMPRESS ALL
  SET HPDFDOC PAGEMODE TO OUTLINE
  SET HPDFINFO AUTHOR      TO 'S. Rathinagiri'
  SET HPDFINFO CREATOR     TO 'S. Rathinagiri'
  SET HPDFINFO TITLE       TO 'ssw HPDF Print'
  SET HPDFINFO SUBJECT     TO 'Test HPdfPrint for Load Font'
  SET HPDFINFO KEYWORDS    TO 'HMG, HPDF, Documentation, LibHaru, Harbour, MiniGUI'
  SET HPDFINFO DATECREATED TO date() TIME time()
  IF lSuccess
    START HPDFDOC
      START HPDFPAGE
        FOR nI := 1 TO LEN( aLine)
          @ 10 + nI  * 5, 10 HPDFPRINT aLine[ nI] FONT cFontname
      END HPDFPAGE
    END HPDFDOC
    MsgInfo( "Pdf Printed !")
    MsgInfo( "Error Printing Pdf !")
Just Hmg It !
Hola hmgchang
Pudiera ser esta la razon ?
viewtopic.php?f=5&t=3422&p=31430#p31430
Hello hmgchang
Could this be the reason ?
hmgchang
Post by hmgchang »
Hi Andy,
I actually tried to load the Courier font ( Cour.TTF).
I dont know if i hv done something wrong, pls advise
thks n rgds
Chang
Just Hmg It !
There is a fix in the next version of HMG. I am sure it will solve this problem.
For the time being, try to give the full path of the font file.
Rathinagiri wrote:For the time being, try to give the full path of the font file.
Yeah, as I have already told him...
Only in the new version is going to find the ttf file. Is necessary to know where the file is. If is not in current folder, will not find. And I think even been in current, will need the fullpath of ttf file.
Post by EduardoLuis »
Hi Chang:
I use this procedure to load ttf fonts, and all works fine.-
1) First define at the begining of the function pdf_create include these variables
function pdf_create
local lSuccess := .f.
local cLB := chr( 10 )
local cTTFFName, cFontName, qPDF
2) Before each line HPDFPRINT where you want an special font put:
qPDF := _HMG_SYSDATA[ 150, 1 ]
cTTFFName := "C:\VEGANO\KUNSTLER.ttf"
cFontName := HPDF_LoadTTFontFromFile( qPDF, cTTFFName, .F. )
@ 235, 200 HPDFPRINT "This is right aligned text" FONT cFontName SIZE 30 RIGHT
Notes:
cTTFFName stores folder where is the font file.-
cFontName stores the full name of the font
For simplicity i keep the fonts i use on the principal folder of my develope.-
I hope this will let you solve your problem.-
With regards.
Eduardo
