Posts: 4023 Joined: Wed Jul 30, 2008 6:43 pm
Post
by Roberto Lopez » Thu May 28, 2009 3:06 am
Please test and report any problem you found.
- Harbour MiniGUI 2.9.2 Changelog:
English:
- Fixed: Print Preview. 'go to page' window not refresh preview window.
- New: Property style synonyms for the following DEFINE WINDOW command clauses:
- WindowType (Main/Modal/Child/SpltChild Clauses)
- Visible (NoShow Clause)
- AutoRelease (NoAutoRelease Clause)
- MinButton (NoMinimize Clause)
- MaxButton (NoMaximize Clause)
- Sizable (NoSize Clause)
- SysMenu (NoSysMenu Clause)
- TitleBar (NoCaption Clause)
- FontName (Font Clause)
- FontSize (Size Clause)
- HelpButton (HelpButton Clause)
- Break (Break Clause)
- Focused (Focused Clause)
- Topmost (Topmost Clause)
Thanks in advance.
Roberto.
hmg292.rar
(386.73 KiB) Downloaded 368 times
Posts: 5482 Joined: Tue Jul 29, 2008 6:30 pm
Post
by Rathinagiri » Thu May 28, 2009 7:04 am
So, now we have many options. Thanks Roberto.
Post
by Roberto Lopez » Thu May 28, 2009 12:10 pm
rathinagiri wrote: So, now we have many options. Thanks Roberto.
The idea is to give to the window definition a 'property style' for all clauses used at definition time, being consistent with controls that have full 'property style' via alternate syntax for all properties.
Roberto.
Vanguarda
Posts: 543 Joined: Wed Feb 11, 2009 10:56 am
Post
by Vanguarda » Thu May 28, 2009 12:38 pm
HI all,
Thanks Master Roberto. Very nice this update...
with best reagrds,
shridhar
Posts: 32 Joined: Mon May 25, 2009 5:24 am
Post
by shridhar » Thu May 28, 2009 12:40 pm
Thanks a lot ..! Master.
gfilatov
Posts: 1116 Joined: Fri Aug 01, 2008 5:42 am
Post
by gfilatov » Thu May 28, 2009 1:00 pm
Roberto,
I want to say about some optimization again
How about to change this multiline definition in the
i_window.ch
#xcommand DEFINE WINDOW <w> ;
[ FONT <FontName> SIZE <FontSize> ] ;
[ FONTNAME <FontName> FONTSIZE <FontSize> ] ;
with the following
one line
[ <dummy1: FONT, FONTNAME> <FontName> <dummy2: SIZE, FONTSIZE> <FontSize> ] ;
Just my 2 cents...
Post
by Roberto Lopez » Thu May 28, 2009 1:25 pm
gfilatov wrote: Roberto,
i_window.ch
with the following
one line
Just my 2 cents...
Thanks!
Roberto.
Posts: 4543 Joined: Wed Jul 30, 2008 9:17 pm
Post
by esgici » Thu May 28, 2009 7:19 pm
Roberto Lopez wrote:
... test and report any problem you found.
Hi Maestro
While
MsgBox( "Window Row is : " + LTRIM( STR( ThisWindow.Row ) ) )
and
MsgBox( "Window Row is : " + LTRIM( STR( GetProperty( <cWindowName>, "Row" ) ) ) )
producing correct values;
MsgBox( "Window type is : " + ThisWindow.WindowType )
produced :
Error E0030 Syntax error: "syntax error at '.'"
and
MsgBox( VALTYPE( GetProperty( <cWindowName>, "WindowType" ) ) )
produced : "
U "
Other "property style synonyms" are seeming the same.
Best Regards
Viva
INTERNATIONAL HMG
Post
by Roberto Lopez » Thu May 28, 2009 10:22 pm
Hi Maestro
While
and
produced :
and
produced : "
U "
Best Regards
It's an error, but in documentation, since these new properties are available at control definition only and should be tagged with (D) in the documentation.
Properties available at control definition are not available at SetProperty and GetProperty functions nor semi-oop syntax.
I'll fix the documentation.
Thanks for reporting.
Roberto.
Post
by Roberto Lopez » Thu May 28, 2009 11:03 pm
Ok. Here it is.
We
always had three property types:
D: Available only at control definition
R: Read-Only (*)
W: Write-Only (*)
(*): at runtime only via Getproperty, SetProperty or semi-oop
This had be never properly documented (until now:) )
Properties:
- Row
- Col
- Width
- Height
- Title
- NotifyIcon
- NotifyTooltip
- FocusedControl (R)
- Cursor (W)
- VirtualWidth (D)
- VirtualHeight (D)
- Icon (R)
- WindowType (Main/Modal/Child/SpltChild/Standard Clauses) (D)
- Visible (NoShow Clause) (D)
- AutoRelease (NoAutoRelease Clause) (D)
- MinButton (NoMinimize Clause)(D)
- MaxButton (NoMaximize Clause) (D)
- Sizable (NoSize Clause) (D)
- SysMenu (NoSysMenu Clause) (D)
- TitleBar (NoCaption Clause) (D)
- BackColor (D)
- FontName (Font Clause) (D)
- FontSize (Size Clause) (D)
- HelpButton (HelpButton Clause) (D)
- GripperText (D)
- Break (Break Clause) (D)
- Focused (Focused Clause) (D)
- Topmost (Topmost Clause) (D)
- Name (R)
R: Read-Only
W: Write-Only
D: Available at definition only
Roberto.
