PRINT DATA With Macro Substitution
hmgchang
Post by hmgchang »
Dear Masters and Friends,
How to use the PRINT DATA with macro subtitution ( &) ?
aLabel := { "one", "two", 1000000}
aFont  := { { "Verdana", 10, "BOLD ITALIC UNDERLINE"}, ;
            { "Arial", 09, "BOLD ITALIC"}, ;
            { "Courier", 10, "BOLD"}}
FOR nLabel := 1 TO LEN( aLabel)
  nRow  := ( nLabel - 1) * 4
  nCol  := 5 + 4
  cBIU := aFont[ nLabel, 3]
  @ nRow, nCol PRINT T_AllToChar( aLabel[ nLabel]) ;
    FONT aFont[ nLabel, 1] ;
    SIZE aFont[ nLabel, 2]
    &cBIU
    // CENTER
Get an compile error !
TIA
Best Rgds,
Chang
Just Hmg It !
Re: PRINT DATA With Macro Substitution
    SIZE aFont[ nLabel, 2] ;
    &cBIU
Did you miss the ; in the third line?
Tried in a single line?
hmgchang wrote:Dear Masters and Friends,
  nCol  := 5 + 4
    &cBIU
    // CENTER
TIA
Best Rgds,
Chang
Only way, I found to use variables to define bold, italic, underline was to convert @ nRow, nCol PRINT phrase to function:
_HMG_PRINTER_H_PRINT ( _HMG_SYSDATA[374], nStartRow, nStartCol ,;
			cFontName, nFontSize,;
			nColorR, nColorG, nColorB ,;
			cTextToPrint ,;
			lBold, lItalic, lUnderline, lOverline ,;
			.T. ,;
			.T. ,;
			.T. ,;
			cJust )
for multilines printout:
_HMG_PRINTER_H_MULTILINE_PRINT ( _HMG_SYSDATA[374], nStartRow, nStartCol ,;
			nEndRow, nEndCol,;
			cTextToPrint ,;
			.T. ,;
			.T. ,;
			.T. ,;
			cJust )
hmgchang
Post by hmgchang »
Yes Mr. Diamond, I missed the colon... thks
Good suggestion Mr. Marek Olszewski and thks, I will give a try...
but should i include any file or libs ?
Just Hmg It !
hmgchang
Post by hmgchang »
Salute for Mr. Mol...
It is working now... thks a lot...
BTW, any idea what the 3 boolean( .T.) after the lOverLine ?
Just Hmg It !
hmgchang wrote:BTW, any idea what the 3 boolean( .T.) after the lOverLine ?
It's about of: <.lcolor.>,<.lfont.>,<.lsize.>
According C:\HMG.3.2\INCLUDE\i_print.ch:
_HMG_PRINTER_H_MULTILINE_PRINT ( _HMG_SYSDATA \[ 374 \] , ;
                                 <Row> , ;
                                 <Col> , ;
                                 <ToRow> , ;
                                 <ToCol> , ;
                                 <cFontName> , ;
                                 <nFontSize> , ;
                                 <aColor>\[1\] , ;
                                 <aColor>\[2\] , ;
                                 <aColor>\[3\] , ;
                                 <cText> , ;
                                 <.bold.> , ;
                                 <.italic.> , ;
                                 <.underline.> , ;
                                 <.strikeout.> , ;
                                 <.lcolor.> , ;
                                 <.lfont.> , ;
                                 <.lsize.> , ;
                                 <"align"> )
hmgchang
Post by hmgchang »
Thanks very much mr. Cesar.
When the command print preview, it display toolbar for Save
instead of printing... but it only save to .emf ?
How about to other format or PDF ?
Pls help me...
Thks n Rgds
Chang
Just Hmg It !
hmgchang wrote:When the command print preview, it display toolbar for Save
ToolBars in HMG_PREVIEW it for your own options. User decides if wants to print or just PREVIEW.
In the next HMG release, we can count with others options to convert metafiles to other image format like: "BMP","JPG","GIF","TIFF","PNG".
For this option, we can count with HMGHPDF it is so simple and very good library. See also an example at C:\HMG.3.2\hfcl\Samples\HMGHPDF\demo.Prg
Pls help me...
Helping in what ? Many question: many responses... you need to study deep into HMG sources. All it is in your own computer when HMG is installed. I suggest to see all HMG examples in SAMPLES folder and you will learn a lot with it.
hmgchang
Post by hmgchang »
:D Thks Sirs,
Really the HMGHPDF is wonderful...
only the supported fonts limited .
Best Rgds
Chang
Just Hmg It !
