Very very thanks ! Beautiful!Rathinagiri wrote:I am trying to get successfully using Unicode with HMG_HPDF.
Also, in the next release we try to incorporate PDF, Barcode and BosTaurus functionalities into HMG.
HMG_HPDF - Export to PDF made easy... (New Version)
I use the great HMG3.2(stable). Have i nice international HMG to everyone!
- srvet_claudio
Very nice!!!Rathinagiri wrote:I am trying to get successfully using Unicode with HMG_HPDF.
Hi Rathi, glad to know that.Rathinagiri wrote:I am trying to get successfully using Unicode with HMG_HPDF
I'm very curious to know how you will do this and I hope very much that you get.
I found something here. I hope it helps you, which says:
Cmap concept at Wiki and another reference at Microsoft - Character To Glyph Index Mapping Table.NOTE:
Haru can use only TrueType fonts which has cmap of unicode and following tables.
"OS/2", "cmap", "cvt ", "fpgm", "glyf", "head", "hhea", "hmtx", "loca", "maxp", "name", "post", "prep"
But I guess its works with OpenType fonts and probably Haru library doesn't work
Or are you trying to convert UNICODE to ANSI and make it workable for both modes ?
Great !!!Rathinagiri wrote:Also, in the next release we try to incorporate PDF, Barcode and BosTaurus functionalities into HMG.
Rathinagiri, have you seen my implementations (see source files here in this message) of HMG_HPdf for validation of true types fonts files names ?
Hi Rathinagiri,
I found some more at: https://groups.google.com/forum/#!topic ... zXoH_K3OAI
And I remember this post: viewtopic.php?p=30384#p30384 talking about HPDF_UseUTFEncodings
I hope to be useful for you...
Pablo, as it is stated here
http://libharu.org/" onclick="window.open(this.href);return false;
UTF8 is supported in the newer versions of libharu and the same was adapted in Harbour also, sometime ago. So, I am trying to get that working.
Thanks for the link Pablo. I will try to adapt that too.Pablo César wrote:Hi Rathinagiri,
