Object on Form can be move by user
Re: Object on Form can be move by user
mol wrote:you've missed IDE.PRG in attached sample
Included
demo.rar
(10.93 KiB) Downloaded 213 times
Hola bpd2000,
Pues si esta excelente la aplicación :D , pero no creo poder ayudar, :( , todavia mis conocimientos son escasos!
Pero seria buena aplicación.
bpd2000 wrote:Dear Javier Tovar,
Thank you for code
I have created attached sample code that can be compile in minigui
I want same code to compile in HMG
Any help
Some years ago Roberto decided to not publish IDE code... :(
Try this sample, you can remove msgdebug mesages...
 * bpd2000@gmail.com
/* modified by Marek Olszewski MOL (2014.04.17)
*  mol@pro.onet.pl
#include "minigui.ch"
function main
Define window oEdit At 0,0 width 600 height 400 main title "Move & Resize Control?"
   // Public nTextBoxCounter := 0
   Public nTitleBarHeight := GetTitleHeight()
   Public nBorderWidth := GetBorderWidth()
   DEFINE STATUSBAR Font "Arial" SIZE 8
			STATUSITEM ""
		END STATUSBAR
      DEFINE button moveControl1
         Row 120
         Col 15
         width 80
         caption "Move_Me"
       action moveControl( this.name )
       END button
       DEFINE button resizeControl1
         Row 120
         Col 115
         width 100
         caption "Resize_Me"
         action resizeControl( _HMG_aControlNames[ 1 ] )
      END button
End window
oEdit.center
oEdit.activate
return nil
PROCEDURE MoveControl( cControlName )
   LOCAL ControlHandle := GetControlHandle( cControlName, 'oEdit' )
   LOCAL z
	ControlHandle := GetControlHandle(cControlName, thisWindow.Name)
		nCurrentCol := this.Col //- oEdit.Col - nBorderWidth
		nCurrentRow := this.Row //- oEdit.Row - nTitleBarHeight - nBorderWidth
msgdebug(nCurrentCol, nCurrentRow)
	InterActiveMove()
	nCurrentCol := GetWindowCol( ControlHandle ) - oEdit.Col - nBorderWidth
	nCurrentRow := GetWindowrow( ControlHandle ) - oEdit.Row - nTitleBarHeight - nBorderWidth
		nCurrentCol := int(nCurrentCol / 10) * 10
		nCurrentRow := int(nCurrentRow / 10) * 10
		this.col := nCurrentCol
		this.row := nCurrentRow
PROCEDURE DrawFocusRect( oControl )
	//ERASE WINDOW oEdit
	//DRAW RECTANGLE IN WINDOW oEdit AT oEdit.&(oControl).row - 1 , oEdit.&(oControl).col - 1 TO oEdit.&(oControl).row + oEdit.&(oControl).height + 1 , oEdit.&(oControl).col + oEdit.&(oControl).width + 1 PENCOLOR { 128, 128, 128 } PENWIDTH 2
  	//DRAW RECTANGLE IN WINDOW oEdit AT oEdit.&(oControl).row + oEdit.&(oControl).height + 2 , oEdit.&(oControl).col + oEdit.&(oControl).width + 2 TO oEdit.&(oControl).row + oEdit.&(oControl).height - 6 , oEdit.&(oControl).col + oEdit.&(oControl).width - 6 PENCOLOR { 128, 128, 128 } PENWIDTH 2 FILLCOLOR {192,192,192}
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
HB_FUNC( SETPIXEL )
   hb_retnl( (ULONG) SetPixel( (HDC) hb_parnl( 1 ) ,
				hb_parni( 2 )      ,
				hb_parni( 3 )      ,
			(COLORREF) hb_parnl( 4 ) ) );
HB_FUNC( SETCROSSCURSOR )
   SetClassLong( ( HWND ) hb_parnl(1), GCL_HCURSOR, ( LONG ) LoadCursor(NULL, IDC_CROSS) );
HB_FUNC( INTERACTIVEMOVE )
   keybd_event(
      VK_RIGHT,  // virtual-key code
      0,         // hardware scan code
      0,         // flags specifying various function options
      0          // additional data associated with keystroke
   keybd_event(
      VK_LEFT,   // virtual-key code
   SendMessage( GetFocus(), WM_SYSCOMMAND, SC_MOVE, 10 );
   RedrawWindow( GetFocus(), NULL, NULL, RDW_ERASE | RDW_INVALIDATE | RDW_ALLCHILDREN | RDW_ERASENOW | RDW_UPDATENOW );
HB_FUNC( INTERACTIVESIZE )
   keybd_event(
      VK_DOWN,
      0,
      0,
      0
   keybd_event(
      VK_RIGHT,
      0,
      0,
      0
   SendMessage( GetFocus(), WM_SYSCOMMAND, SC_SIZE, 0 );
#pragma ENDDUMP
mol wrote:Try this sample, you can remove msgdebug mesages...
Thank you, Mol
Excellent coding extension
Regarding re-size of Object, Hint
With the use of Move & Re-size of object we can design application to Crop Image etc.
You request, you get it!
 * bpd2000@gmail.com
FUNCTION MAIN
			STATUSITEM ""
		END STATUSBAR
      DEFINE button MoveControl1
         Row 120
         Col 15
         width 120
		 height 30
         caption "TEST BUTTON"
       action MsgBox( "Call context menu of this button to move or resize control" )
       END button
	   DEFINE CONTROL CONTEXTMENU  MoveControl1
			MenuItem "Move button"	action moveControl( "MoveControl1" )
			MenuItem "Resize button"	action ResizeControl( "MoveControl1" )
		END MENU
End window
oEdit.center
oEdit.activate
return nil
   LOCAL ControlHandle
	DoMethod(ThisWindow.Name, cControlName, "SetFocus")
	InterActiveMove()
	//nCurrentCol := int(nCurrentCol / 10) * 10
	//nCurrentRow := int(nCurrentRow / 10) * 10
	SetProperty(ThisWindow.Name, cControlName,"Col", nCurrentCol)
	SetProperty(ThisWindow.Name, cControlName,"Row", nCurrentRow)
PROCEDURE ResizeControl( cControlName )
	local nNewWidth, nNewHeight
	InterActiveSize()
	nNewWidth	:= GetWindowWidth( ControlHandle )
	nNewHeight	:= GetWindowHeight( ControlHandle )
	SetProperty(ThisWindow.Name, cControlName,"Width",nNewWidth)
	SetProperty(ThisWindow.Name, cControlName,"Height", nNewHeight )
#pragma BEGINDUMP
#include "hbapi.h"
HB_FUNC( SETPIXEL )
				hb_parni( 2 )      ,
				hb_parni( 3 )      ,
   keybd_event(
   keybd_event(
   keybd_event(
      VK_DOWN,
      0,
      0,
      0
   keybd_event(
      VK_RIGHT,
      0,
      0,
      0
#pragma ENDDUMP
mol wrote:You request, you get it!
Thank you, Mol
Very nice coding and useful to other user also
:D :D :D Excelente frase!
Gracias Mol, en verdad Felicidades!!! :D :D :D
Buena aplicación,
