En un TEXTBOX tengo que ingresar un valor que puede tener estas características:
cValor:="000000" o cValor:="ZZ1234" o cValor:="ZZXXXX"
y el INPUTMASK tendria que ser algo como este código de Clipper
@ 10,10 get cValor picture "@R !!-!!!!"
si fueran solo números el INPUTMASK seria
@ 10,10 TEXTBOX txtValor ;
VALUE cValor ;
WIDTH 70 ;
INPUTMASK "99-9999"
y funciona bien, pero el tema es que no encuentro dentro de las propiedades del INPUTMASK un valor para ingresar caracteres alfanumericos para este formato.¿ Es posible eso?
Pregunta por cierto formato en INPUTMASK de TEXTBOX
Antonio
Sistemas
Resipol
Sistemas
Resipol
- esgici
Re: Pregunta por cierto formato en INPUTMASK de TEXTBOX
citro (via Google) wrote:In a textbox I have to enter a value that can have these characteristics:
cValor: = "000000" or cValor: = "ZZ1234" or cValor: = "ZZXXXX"
INPUTMASK and would have to be something like this code Clipper
@ 10,10 get cValor picture "@ R -!!"
if numbers were the only serious INPUTMASK
@ 10,10 TEXTBOX txtValor;
VALUE cValor;
WIDTH 70;
INPUTMASK "99-9999"
and it works fine, but the issue is that I find within INPUTMASK properties to enter a value for this format alphanumeric characters. Is that possible?
So, did you triedHMG Doc wrote:InputMask String (Non-Numeric Textbox):
9 Digits
A Alphabetic Characters
! Converts an alphabetic character to uppercase
(All other characters ar included in text in the position indicated by the mask)
INPUTMASK "AA-AAAA" Happy HMG'ing
Viva INTERNATIONAL HMG
with "AA-AAAA" only allows me to enter letters, if I use "!!-!!!!" The TextBox appears with a minus character eg.
cValor: = "000000"
appear as "00-000"
In Example 5, said masks are fixed format, that is,
INPUTMASK 'AAA-99999 / A'
The first 3 characters are alphabetic, but if I want to enter numbers or vice versa
INPUTMASK '999-AAAA / A'
cValor: = "000000"
appear as "00-000"
Antonio
Sistemas
Resipol
Sistemas
Resipol
Hi Citro,
For a variable mask would be advisable to make a function in ONCHANGE, to verify that each pulse is one of the formats you need. I believe!
