HFCL (Hmg Forum Component Library)
Source code related resources
sudip
Re: HFCL (Hmg Forum Component Library)
Post by sudip »
rathinagiri wrote:Hi Swapan,
Had you copied i_userOOPS.ch to include directory?
Hi Rathi,
I copied i_usurOOPS.ch from C:\HMG\HFCL folder to C:\HMG\Include folder. But when tried to copile GridPrint sample, got following errors:-
C:\hmg\hfcl\Samples\GridPrint\MAIN.o:MAIN.c:(.data+0x1e8): undefined reference to `HB_FUN(int13_t &, int0_t &)'
mingw32-make.exe: *** [C:\hmg\hfcl\Samples\GridPrint\MAIN.exe] Error 1
Finished With Errors.
Hope I am not disturbing you too much ;)
Regards.
During testing of Grid2Print, I found some bugs:
1. If you define Footer and Pagination is set on bottom of page - page numbers are out of bottom margin
2. In Report properties - "Header1" is taken from language table but Header2 stay in English
3. Merge Header - "Multi Header1" nad "Multi Header2" aren't taken from language table.
4. It will be good to predefine page properties depending of language/country setting - in Poland we always use "A4 size of paper" - I think it's not posible to buy Letter size paper. I think it's in whole Europe excluding England, but I'm not sure....
5. Some words in Polish are longer than in English - some labels are cutted off - they don't look good
6. It would be great possibility to save all settings to database or .mem file for next calls of print functionality - with possibility to restore default setting (one more button "Default Settings")
Besides, this is great work, Rathinagiri...
Below I put Polish translation:
   // POLISH
        msgarr := {"Brak danych do druku!",;    //1
                   "Brak zainstalowanych drukarek w systemie!",;  //2
                   "Kreator wydruku",;  //3
                   "Kreator zapisu",; //4
                   "Kolumny",; //5
                   "Nazwa kolumny",; //6
                   "Szerokość (mm)",; //7
                   "Kliknij dwa razy na kolumnie, aby ją zaznaczyć/odznaczyć do wydruku",; //8
                   "Zmień rozmiar kolumny tekstowej",; //9
                   "Całkowitta szerokość:",; //10
                   "z",;  //11
                   "Nagłówek 1",;  //12
                   "Nagłówek 2",; //13
                   "Nagłówek 3",; //14
                   "Stopka 1",; //15
                   "Własności raportu",; //16
                   "Rozmiar czcionki",; //17
                   "Długie teksty",; //18
                   "Zawijanie słów",; //19
                   "Obcięcie",; //20
                   "Numeracja stron",; //21
                   "Wyłączona",; //22
                   "Góra",; //23
                   "Dół",; //24
                   "Linie siatki",; //25
                   "Kolumna",; //26
                   "Wiersz",; //27
                   "Centruj stronę",; //28
                   "Pionowy",; //29
                   "Strona/Drukarka",; //30
                   "Orientacja",; //31
                   "Pozioma",; //32
                   "Pionowa",; //33
                   "Drukarka: ",; //34
                   "Rozmiar strony",; //35
                   "Szerokość strony",; //36
                   "Wysokość strony",; //37
                   "Marginesy (mm)",; //38
                   "Górny",; //39
                   "Prawy",; //40
                   "Lewy",; //41
                   "Dolny",; //42
                   "Drukuj",; //43
                   "Anuluj",; //44
                   "Witaj w Kreatorze Wydruku",; //45
                   "Wybrałeś więcej kolumn, niż można zmieścić na stronie!",; //46
                   "Musisz wybrać drukarkę!",; //47
                   "Nie można wybrać drukarki! Sprawdź jej dostępność.",; //48
                   "Numer strony:",; //49
                   "Rozmiar:",; //50
                   "Wykonano",; //51
                   "Nie można zmieniać rozmiau nietekstowych kolumn!",; //52
                   "Justyfikacja określona nieprawidłowo.",; //53
                   "Puste przestrzenie",; //54
                   "Rozszerz",; //55
                   "Zastosuj",; //56
                   "Dołącz",;//57
                   "Suma",;//58
                   "Tak",;//59
                   "Nie",;//60
                   "Dołącz nagłówek",; //61
                   "Od",; //62
                   "Do",; //63
                   "Nagłówek",; //64
                   "Pojawił się błąd w definicji dołączanego nagłówka w linii  nr ",; //65
Thanks for your exclusive report and excellent guidance Mol.
I would do one by one. :)
mol wrote:During testing of Grid2Print, I found some bugs:
I had rectified this.
mol wrote:2. In Report properties - "Header1" is taken from language table but Header2 stay in English
I don't understand this. Do you mean header2label? It is rightly taken from the msgarr[13]. Isn't it? Or, am I missed something?
mol wrote:3. Merge Header - "Multi Header1" nad "Multi Header2" aren't taken from language table.
This also, I can't get to the point. :(
mol wrote:4. It will be good to predefine page properties depending of language/country setting - in Poland we always use "A4 size of paper" - I think it's not posible to buy Letter size paper. I think it's in whole Europe excluding England, but I'm not sure....
Yes. It is a great idea. This can be done when selecting the language itself. :) I will do for Poland in the coming version.
mol wrote:5. Some words in Polish are longer than in English - some labels are cutted off - they don't look good
Hmm. Can you please specify the label names whose length of values exceed their control length and the optimum length for the same? I would rectify it.
mol wrote:6. It would be great possibility to save all settings to database or .mem file for next calls of print functionality - with possibility to restore default setting (one more button "Default Settings")
As of now, all the settings for a particular report is saved in a memory file namely 'reports.cfg' whenever a report print button is pressed automatically. I welcome your suggestion on this.
mol wrote:Besides, this is great work, Rathinagiri...
Thanks a lot for your appreciation and valuable contribution.
Here is a new bug fixed version of HFCL 0.92.
Change Log:
GridPrint
1. Fixed some bugs reported by mol. (Thanks a lot Mol)
2. Fixed dynamic headers for reports not printed.
Thanks a lot Rathi :)
fchirico
Post by fchirico »
rathinagiri wrote:Here is a new bug fixed version of HFCL 0.92.
Thank you!
Saludos, Fernando Chirico.
I'll test it on monday.
I'll try to put some screenshots with my suggestions.
Marek
sudip
Post by sudip »
Hello Rathi,
rathinagiri wrote: Had you copied i_userOOPS.ch to include directory?
Yes I copied, but got following error:-
TIA.
With best regards.
Hi Sudip
Does your main.prg include #include "hfcl.ch" statement ?
