Browse / grid /dbf
Browse / grid /dbf
Hi to All,
I'm working hard on hmg 3.2, reading all doc i've found and samples but now i've some questions without answers ...
I've made a test program with a 40 000 records database with a simple grid with ROWSOURCE DBF, and the same with the "browse" control. With the grid the "loading" of my form is about 15s over the network and 2s with the browse.
I'm 'happy' but ... as i've not found samples with browse in hmg 3.2 i'm a bit affraid that browse will be discarded in newer version !
-> Why browse is faster than grid ? ( I've tried to use VIRTUAL GRID with no succes with a DBF rowsoure )
-> Is there a way to make a grid as fast than browse with a dbf ? ( as grid seems to be the most used control )
thanks to spend a little of ure time to give me some answer or some sample !
Re: Browse / grid /dbf
I'm still using browse for it's functionality with dbf files.
You can find samples in older versions of HMG. They are still the same.
IMHO, Grid is unusable for dbf files.
Hi,jpp wrote:Hi to All,
IMHO The using of the command COUNT TO in a grid code is reason of this different loading time between Grid and Browse.
Please take a look for the following function in core code:
Function GetDataGridRecCount()
Local nCount
Local nInitialRecord
nInitialRecord := RecNo()
COUNT TO nCount
dbGoTo( nInitialRecord )
Return nCount
- srvet_claudio
Hi Grigory.gfilatov wrote:Hi,jpp wrote:Hi to All,
Please take a look for the following function in core code:Code: Select all
Function GetDataGridRecCount() Local nCount Local nInitialRecord nInitialRecord := RecNo() COUNT TO nCount dbGoTo( nInitialRecord ) Return nCount ...
Many thanks for your tip!!!
Hi all,
An example of where Claudio Soto shows that Grid is much faster than Browse, hope to find.
Hi all.
Well not if you Browse faster, but if the new Grid is much faster than the last!
Please see this post:
viewtopic.php?f=24&t=3224&p=29330&hilit=gridex" onclick="window.open(this.href);return false; # p29330
Hi Grigory
lot of thanks for your answer...and bravo for your knowledge of hmg !
I've had a look at h_grid.prg and i have seen that cellnavigation is forced to .t. for a rowsource.
i supposed it's for a good reason but i've not found why !
to come back to "GetDataGridRecCount" why not use lastrec() ? is it for the accuracy of the scroll bar in case of deleted or filter ? is this case it will be nice to bypass that in case of large databases.
cordialement from France !!!!
IMHO lasterc() give the number of the last record, but not how many records are.jpp wrote:....
Saludos, Fernando Chirico.
Hi Fernando,
i know that lastrec does not give the number of records...but in the case of GetDataGridRecCount, if "the real count of records" is only for the accuracy of the vscrollbar, it's not very important for me in front of the time saved when loading the grid with a 'big' database ...
bye !
bye !
