Hola a todos
se agrego al grid la direccion IPv4 e IPv6 de la placa de red conectada a internet que suministra el proveedor o direccion interna dada por el servidor DHCP local.
el GRID muestra las placas de red físicas disponibles
se elimino codigo redundante
se necesita limpiar un poco el codigo fuente eliminando las variables no usadas.
Translate Google
Hello everyone
grid is added to the IPv4 and IPv6 address of the network card connected to Internet provider that provides or internal direction given by the local DHCP server.
GRID displays the physical network plates available
redundant code was removed
needs to be cleaned a bit the source code by removing unused variables.
Dirección MAC
Re: Dirección MAC
Re: Dirección MAC
Enjoy
Re: Dirección MAC
Hola a todos
Tomando el ejemplo posteado por Maximiliano pude lograr esta Función espero les sirva:
(Aclaro que solo lo he probado en mi PC)
Hello everyone
Taking the example posted by Maximilian I could achieve this function hope they serve:
(I must say that I have only tried on my PC)
Hello everyone
FUNCTION SysInvent() // By AndyGlezL
LOCAL obj, cpu, nInd, obj1, obj2
WaitWindow( "Espere, Leyendo...", .T. )
oLocator := win_oleCreateObject( "wbemScripting.SwbemLocator" )
oWmi := oLocator:ConnectServer()
data1:=""
oCollection:= oWMI:ExecQuery("Select * from Win32_ComputerSystem")
For Each obj In oCollection
Name := 'Computer: '+CHR(9)+obj:Name
PhysicalMemory := 'PhysicalMemory: ' + CHR(9) + STR( ( VAL( obj:TotalPhysicalMemory) / 1000000 ) / 1024 ) + " GB."
cNumProcs := "# of Processors: " + CHR(9) + STR( obj:NumberOfProcessors )
data1 += Name+CRLF+cNumProcs+CRLF+PhysicalMemory
Next
data2:=""
oCollection := oWMI:ExecQuery("Select * from Win32_OperatingSystem")
Caption := 'OS: ' + CHR(9) + obj:Caption + CRLF
ServPack := 'Service Pack: ' + CHR(9) + STR( obj:ServicePackMajorVersion ) + CRLF
cVersion := "Version: " + CHR(9) + obj:Version + CRLF
FreePhysMem:= 'FreePhysMemory: '+CHR(9) + STR( ( VAL( obj:FreePhysicalMemory ) / 1000 ) / 1024 ) + " GB." + CRLF
cWinDir := "Win Directory:" + CHR(9) + obj:WindowsDirectory
data2 += Caption+ServPack+cVersion+FreePhysMem+cWinDir
Next
data3:=""
oCollection := oWMI:ExecQuery( 'select * from Win32_ComputerSystemProduct' )
Vendor := 'Manufacturer: '+CHR(9)+obj:Vendor
Name := 'MotherBoard: '+CHR(9)+obj:Name
IdentifyingNumber := 'Id. Number: '+CHR(9)+obj:IdentifyingNumber
data3 += Vendor+CRLF+Name+CRLF+IdentifyingNumber
Next
data4 := ""
nInd := 0
oCollection := oWMI:ExecQuery("Select * from Win32_DiskDrive")
nInd++
Model := 'Disc Model'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj:Model+CRLF
*SerialNumber := 'SerialNumber: '+obj:SerialNumber // ERROR ! ?????
InterfaceType := ' Interface'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj:InterfaceType+CRLF
Size := ' Disc.Size'+ALLTRIM(STR(nInd))+': '+CHR(9)+STR( ( VAL( obj:Size ) / 1000000 ) / 1024 )+" GB."+CRLF
Partitions := ' Partitions'+ALLTRIM(STR(nInd))+': '+CHR(9)+STR( obj:Partitions )+CRLF
data4 += Model+InterfaceType+Size+Partitions
Next
data5 := ""
oCollection := oWMI:ExecQuery( 'select * from Win32_Processor' )
For Each cpu In oCollection
*DeviceID := 'DeviceID: '+CHR(9)+cpu:DeviceID+CRLF
*Availability := 'Availability: '+CHR(9)+STR( cpu:Availability )+CRLF
AddressWidth := 'AddressWidth: '+CHR(9)+STR( cpu:AddressWidth )+CRLF
*CpuStatus := 'CpuStatus: '+CHR(9)+STR( cpu:CpuStatus )+CRLF
CurClockSpeed := 'ClockSpeed: '+CHR(9)+STR( cpu:CurrentClockSpeed )+CRLF
*MaxClockSpeed := 'MaxClockSpeed: '+CHR(9)+STR( cpu:MaxClockSpeed )+CRLF
L2CacheSize := 'L2CacheSize: '+CHR(9)+STR( cpu:L2CacheSize )+CRLF
L2CacheSpeed := 'L2CacheSpeed: '+CHR(9)+STR( cpu:L2CacheSpeed )+CRLF
Name := 'Name: '+ALLTRIM(cpu:Name)
*data5 += DeviceID+Availability+AddressWidth+CpuStatus+CurClockSpeed+MaxClockSpeed+L2CacheSize+L2CacheSpeed+Name
data5 += AddressWidth+CurClockSpeed+L2CacheSize+L2CacheSpeed+Name
Next
data6 := ""
nInd := 0
aNetConnectStat := { 'Disconnected', 'Connecting', 'Connected', 'Disconnecting', 'Hardware not present', 'Hardware disabled', 'Hardware malfunction', ;
'Media disconnected', 'Authenticating', 'Authentication succeeded', 'Authentication failed', 'Invalid address', 'Credentials required' }
oCollection1 := oWMI:ExecQuery( "SELECT * FROM Win32_NetworkAdapter WHERE Manufacturer != 'Microsoft' AND NOT PNPDeviceID LIKE 'ROOT\\%'" )
oCollection2 := oWMI:ExecQuery( 'SELECT * from Win32_NetworkAdapterConfiguration where IPEnabled=TRUE' )
For Each obj1 In oCollection1
nTemp := obj1:NetConnectionStatus
For Each obj2 In oCollection2
nInd++
cDescrip := 'Description'+ALLTRIM(STR(nInd))+': '+CHR(9)+SUBSTR( obj2:description, 1, AT( "-", obj2:description ) -2 )+' / '+aNetConnectStat[ nTemp+1 ]+CRLF
ServiceName := ' ServiceName'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj2:ServiceName(0)+CRLF
IPAddress := ' IPAddress'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj2:IPAddress(0)+CRLF
*DefaultIPGateway := 'DefaultIPGateway: '+obj:DefaultIPGateway(0) // ERROR ! ????
MACAddress := ' MACAddress'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj2:MACAddress(0)
data6 += cDescrip+ServiceName+IPAddress+MACAddress+CRLF
Next
Next
oCollection := 0
oWMI := 0
WaitWindow( )
MsgInfo(data1+CRLF+ ; // REPLICATE( "-", 80 )+CRLF+ ;
data2+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
data3+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
data4+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
data5+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
data6, 'System Inventory - By AndyGlezL' )
RETURN nil
- sysinfo.jpg (62.57 KiB) Viewed 4711 times
Re: Dirección MAC
Muy bueno Andrés !!!!
Slds
Slds
Re: Dirección MAC
Excelente Andres!
- edufloriv
- DBs Used: DBF, MariaDB, MySQL, MSSQL, MariaDB
Re: Dirección MAC
Que genial !! gracias por su tiempo amigos y por compartir.
Eduardo Flores Rivas
LIMA - PERU
