Is there any way to use Open Office Apps, eg., Calc instead of Excel from HMG.
A discussion regarding this topic will be great helpful for all who are using Open Source Software
Thank you in advace
Regards.
Hello Mol,mol wrote:...
i don't know, who is author, but regards to him.
Regards.Antonio wrote:Sudip,
To seems AutomateIt program (OLE conversor) not running; i obtain a Run time
error at worksheets in
oExcel:CreateObject("Excel.Application")
oExcel:WorkSheets:Count // here RTE
I'm developmeting a layer for to use OLE Calc throw OLE Excel syntax.
I don´t know if this option it's the better ???
Initial layer's code:
#Define lSISTEMA_CALC .T. //-------------------------------------------------------------------------- // FUNCTION CreateObjectExcelLayer() Local oExcel:= NIL Local oErr:= NIL IF !lSISTEMA_CALC TRY // Siempre crea objeto (evito algunos problemas pe. en saveas()) oExcel:= CreateObject( "Excel.Application" ) CATCH oErr MERROR_( " No se pudo conectar con Excel !", OLE2TXTERROR(), oExcel,; oErr:SubSystem(),; oErr:Description,; oErr:Operation ) oExcel:= NIL END ELSE oExcel:= TExcelLayer():New() ENDIF RETURN oExcel * //-------------------------------------------------------------------------- // CLASS TExcelLayer METHOD New() // ASSIGN Visible(x) INLINE (msginfo("hola", x)) METHOD Get(cMessage) //INLINE msginfo(cMessage, "falta implementar !") // Datas Excel simuladas ---------------------------------------- // Estas datas seran las que se manjen desde fuera... pero aqui // dentro deben tener valores apropiados DATA oSheet DATA WorkBooks DATA TmpWorkSheets HIDDEN METHOD WorkSheets(nSheet) #Define ACTIVE_SHEET ::oOOCalc:getCurrentController():getActiveSheet() ACCESS ActiveSheet INLINE TWorkSheetExcelLayer():New(Self, NIL, NIL, ACTIVE_SHEET) //--------------------------------------------------------------- // Datas Calc reales -------------------------------------------- DATA oOOEngine READONLY DATA oOOCore READONLY DATA oOODesktop READONLY DATA oOOCalc READONLY //--------------------------------------------------------------- ENDCLASS * //-------------------------------------------------------------------------- // METHOD WorkSheets(nSheet) Local xRet:= NIL #Define lCOMO_DATA PCount() == 0 IF lCOMO_DATA xRet:= ::TmpWorkSheets ELSE xRet:= TWorkSheetExcelLayer():New(Self, NIL, nSheet- 1) ENDIF RETURN xRet //-------------------------------------------------------------------------- // METHOD Get(cMessage) cMessage:= Upper(cMessage) DO CASE CASE cMessage == "ACTIVESHEET" xRet:= ::ActiveSheet * CASE .T. MERROR_("Falta implementar mensaje", cMessage) ENDCASE RETURN xRet * //-------------------------------------------------------------------------- // METHOD New() CLASS TExcelLayer Local oErr * TRY ::oOOEngine:= CreateObject( "com.sun.star.ServiceManager" ) CATCH oErr MERROR_( " No se pudo conectar con Open Office !", OLE2TXTERROR(), ::oOOEngine,; oErr:SubSystem(),; oErr:Description,; oErr:Operation ) RETURN NIL END ::oOOcore := ::oOOEngine:CreateInstance("com.sun.star.refelection.CoreReflection") ::oOODesktop := ::oOOEngine:createInstance("com.sun.star.frame.Desktop") * ::oOOCalc := ::oOODesktop:loadComponentFromURL("private:factory/scalc", "_blank", 0, {}) ::WorkBooks := TWorkBooksExcelLayer():New(Self) ::TmpWorkSheets:= TWorkSheetsExcelLayer():New(Self) RETURN Self * * * //-------------------------------------------------------------------------- // //-------------------------------------------------------------------------- // CLASS TWorkBooksExcelLayer EXPORTED: METHOD New() METHOD Add() HIDDEN: DATA oExcelLayer ENDCLASS //-------------------------------------------------------------------------- // METHOD New(oExcelLayer) CLASS TWorkBooksExcelLayer ::oExcelLayer:= oExcelLayer RETURN Self //-------------------------------------------------------------------------- // METHOD Add() CLASS TWorkBooksExcelLayer Local oBook oBook:= TWorkBookExcelLayer():New(::oExcelLayer) //, Self) RETURN oBook //-------------------------------------------------------------------------- // CLASS TWorkBookExcelLayer EXPORTED: METHOD New() HIDDEN: DATA oExcelLayer DATA oWorkBooksExcelLayer ENDCLASS //-------------------------------------------------------------------------- // METHOD New(oExcelLayer, oWorkBooksExcelLayer) CLASS TWorkBookExcelLayer ::oExcelLayer := oExcelLayer ::oWorkBooksExcelLayer:= oWorkBooksExcelLayer RETURN Self //-------------------------------------------------------------------------- // CLASS TWorkSheetsExcelLayer EXPORTED: METHOD New() // // -1 pq parece que indica una hoja mas de la cuenta !!! // ACCESS Count INLINE Len( ::oExcelLayer:oOOCalc:getSheets() )- 1 ACCESS Count INLINE ::oExcelLayer:oOOCalc:getSheets():getCount() HIDDEN: DATA oExcelLayer ENDCLASS //-------------------------------------------------------------------------- // METHOD New(oExcelLayer) CLASS TWorkSheetsExcelLayer ::oExcelLayer:= oExcelLayer RETURN Self * //-------------------------------------------------------------------------- // CLASS TWorkSheetExcelLayer EXPORTED: METHOD New() METHOD Delete() INLINE ::oExcelLayer:oOOCalc:getSheets():removeByName(::oOOSheet:Name ) ACCESS Name INLINE ::oOOSheet:Name ASSIGN Name(cName) INLINE ::oOOSheet:Name:= cName HIDDEN: DATA oExcelLayer DATA oWorkSheetsExcelLayer DATA nSheet DATA oOOSheet ENDCLASS //-------------------------------------------------------------------------- // METHOD New(oExcelLayer, oWorkSheetsExcelLayer, nSheet, oOOSheet) CLASS TWorkSheetExcelLayer ::oExcelLayer := oExcelLayer ::oWorkSheetsExcelLayer:= oWorkSheetsExcelLayer ::nSheet := nSheet DO CASE CASE ::nSheet != NIL ::oOOSheet:= ::oExcelLayer:oOOCalc:getSheets():getByIndex(nSheet) CASE oOOSheet != NIL ::oOOSheet:= oOOSheet ENDCASE RETURN Self
