Control under the Mouse
Re: Control under the Mouse
Eres un mago :D
My two cents:
#define WM_SETCURSOR     32
#define WM_PARENTNOTIFY  528
Hola DR. Claudio Soto
srvet_claudio wrote:Re: Control under the Mouse
My two cents:
Code:
No se como utilizar sus "Dos centavos", alguna idea?, Como se manejan o ...
Hola Javier,
son los nombres de los mensajes de Windows interceptados por la rutina, es solo por cuestión de claridad.
Function TestMove()
Local hWnd := EventHWND()
Local nMsg:= EventMsg()
Local wParam:= EventWPARAM ()
Local cNom, cForm
if nMsg == WM_SETCURSOR .and. wParam <> w_test.HANDLE
   GetControlNameByHandle(wParam,@cNom, @cForm)
   msgbox("Event " + str( nMsg,3,0) + " / " + str(wParam,8,0) + " / " + cNom + " / " + cForm )
Function SelectCtrl()
Local cNom,cForm
Static ctrlselect:= ""
if wParam <> w_test.HANDLE
   if nMsg == WM_PARENTNOTIFY .and. !empty(ctrlselect)
      msgbox("ctrl selected " + ctrlselect )
         ctrlselect:= HMG_UPPER (cNom)
         ctrlselect:= ""
Hola Dr. Claudio Soto,
Gracias por aclarar, vi un poco Microsoft sobre #define WM_SETCURSOR 32 y #define WM_PARENTNOTIFY 528 y todo sobre las API's y es un mundo de información.
Saludos!
jpp
Post by jpp »
first thanks for ure answers.
A the begining my purpose was to write an ide to save time for designing forms.
( thats why i wanted to know the control's name under the mouse ).
After a cup of day, i realised that foxpro had a good ide ...
As all the form and it's controls are stored into an scx/sct file ( a simple dbf/ftp file ) which is very simple to read with dbu ( rdd dbf/cdx ).
now, it's very simple to convert ur's prg form design to foxpro properties ( as they are quite similar ) and after the foxpro designer, back to hmg prg !
For the moment i've written the first stage ( hmg->foxpro ) and it's very successfull !!!
I will post something when i'll finish the next stage ...
Jpp
jpp wrote:hi,
Jpp
Wow very nice!!!
Hola
Aqui les dejo una variante del ejemplo de jpp y Pablo Cesar.
Hello
Here 'example of a variant of jpp and Pablo Cesar.
#define BLUE1 { 218,229,243 }
#define BLUE2 { 000,120,187 }
STATIC cCtrlAnt:="",  lProp:=.F.
	DEFINE WINDOW w_test AT 000 , 000 WIDTH 230 HEIGHT 380 BACKCOLOR BLUE1 TITLE "SIMULATE A MOUSE OVER --- BY AGL" MAIN
		ON KEY ESCAPE ACTION Thiswindow.Release()
		@ 030,010 LABEL LB_1 VALUE "Opcion 1" OF w_test WIDTH 200 HEIGHT 20 FONT 'Verdana' SIZE 9 FONTCOLOR WHITE BACKCOLOR BLUE2 CENTERALIGN ACTION MsgInfo( "Opcion 1" )
		@ 055,010 LABEL LB_2 VALUE "Opcion 2" OF w_test WIDTH 200 HEIGHT 20 FONT 'Verdana' SIZE 9 FONTCOLOR WHITE BACKCOLOR BLUE2 CENTERALIGN ACTION MsgInfo( "Opcion 2" )
		@ 080,010 LABEL LB_3 VALUE "Opcion 3" OF w_test WIDTH 200 HEIGHT 20 FONT 'Verdana' SIZE 9 FONTCOLOR WHITE BACKCOLOR BLUE2 CENTERALIGN ACTION MsgInfo( "Opcion 3" )
		@ 105,010 LABEL LB_4 VALUE "Opcion 4" OF w_test WIDTH 200 HEIGHT 20 FONT 'Verdana' SIZE 9 FONTCOLOR WHITE BACKCOLOR BLUE2 CENTERALIGN ACTION MsgInfo( "Opcion 4" )
		@ 130,010 LABEL LB_5 VALUE "Opcion 5" OF w_test WIDTH 200 HEIGHT 20 FONT 'Verdana' SIZE 9 FONTCOLOR WHITE BACKCOLOR BLUE2 CENTERALIGN ACTION MsgInfo( "Opcion 5" )
		@ 155,010 LABEL LB_6 VALUE "Opcion 6" OF w_test WIDTH 200 HEIGHT 20 FONT 'Verdana' SIZE 9 FONTCOLOR WHITE BACKCOLOR BLUE2 CENTERALIGN ACTION MsgInfo( "Opcion 6" )
		@ 250,000 LABEL LB_7 VALUE ""  WIDTH 200 HEIGHT 20 FONT 'Verdana' SIZE 9 FONTCOLOR BLACK  CENTERALIGN TRANSPARENT
	CREATE EVENT PROCNAME SELECTCTRL( EventWPARAM() )  // HWND W_test.HANDLE
	CENTER   WINDOW w_test
	ACTIVATE WINDOW w_test
RETURN Nil
FUNCTION SelectCtrl( wParam )
	LOCAL cCtrl, cForm, cTemp
	GetControlNameByHandle( wParam, @cCtrl, @cForm )
	cTemp:=ALLTRIM( cForm )+ALLTRIM( cCtrl )
	w_test.LB_7.VALUE := cTemp   // **** Display cForn, cCtrl
	IF cTemp==cForm
		IF lProp
			// La intencion es hacer que la Funcion acepte cualquier nombre de Ventana, pero de esta forma no se ejecuta el ACTION del LABEL !
			// The intention is to make the function accepts any window name, but this way the ACTION of LABEL is not running!
			*SETPROPERTY( cForm, cCtrlAnt, "FONTBOLD" , .F. )
			*SETPROPERTY( cForm, cCtrlAnt, "FONTSIZE" , 9   )
			*SETPROPERTY( cForm, cCtrlAnt, "BACKCOLOR", BLUE2 )
			w_test.&cCtrlAnt..FONTBOLD  := .F.
			w_test.&cCtrlAnt..FONTSIZE  := 9
			w_test.&cCtrlAnt..BACKCOLOR := BLUE2
			lProp:=.F.
		IF ! empty(cCtrl)
			IF ! lProp
				w_test.&cCtrl..FONTBOLD  := .T.
				w_test.&cCtrl..FONTSIZE  := 12
				w_test.&cCtrl..BACKCOLOR := BLUE
				cCtrlAnt:=cCtrl
				lProp:=.T.
RETURN Nil
Muy buen ejemplo Andrés!!!
Espectacular Andres, gracias por compartir.
