Control under the Mouse
Hi to all,
if you want to know the control under the mouse pointer ( to select it or change the shape of the pointer ) here if the way to simulate a MOUSE OVER
DEFINE WINDOW w_test
some controls ( label, textbox, etc ... )
CREATE EVENT PROCNAME TESTMOVE HWND W_test
ACTIVATE WINDOW W_TEST
function testmove()
LOCAL hWnd := EventHWND()
Local nMsg:= EventMsg()
local wParam:= EventWPARAM ()
local cNom, cForm
if nMsg == 32 .and. wParam <> win_1.HANDLE
GetControlNameByHandle(wParam,@cNom, @cForm)
msgbox("Event " + str( nMsg,3,0) + " / " + str(wParam,8,0) + " / " + cNom + " / " + cForm )
return nil
that's all !!!
bye
function testmove()
local cNom, cForm
return nil
that's all !!!
bye
Re: Control under the Mouse
That is so nice.
Muy bien amigo!
- esgici
Hi jpp
Welcome aboard
Happy HMG'ing
Welcome aboard
Good sample, thanks to participationjpp wrote:here if the way to simulate a MOUSE OVER
Happy HMG'ing
Viva INTERNATIONAL HMG
hi and thx for ure messages...
Now if u want to select the control change the proc EVENT to this one :
function selectCtrl()
local cNom,cForm
static ctrlselect:= ""
if wParam <> win_1.HANDLE
if nMsg == 528 .and. !empty(ctrlselect)
msgbox("ctrl selected " + ctrlselect )
if nMsg == 32
ctrlselect:= upper(cNom)
ctrlselect:= ""
return nil
i've tested with label, textbox and button ...
Any feeback welcome
Bye
local cNom,cForm
if nMsg == 32
ctrlselect:= ""
return nil
Any feeback welcome
Bye
---------------------------------------------Hi to all,
function testmove()
local cNom, cForm
if nMsg == 32 .and. wParam <> win_1.HANDLE <====== ERROR
return nil
that's all !!!
bye
Hi jpp, gives error, which is defined Win_1?
Hola jpp,
Me da error, me dice que no existe la variable "W_test"
CREATE EVENT PROCNAME TESTMOVE HWND W_test <===== ERROR
function testmove()
local cNom, cForm
return nil
function testmove()
local cNom, cForm
return nil
Sorry for the mistake !
win_1.handle does not exist, it's W_TEST ( the name of the form )
bye
bye
jpp wrote:if you want to know the control under the mouse pointer ( to select it or change the shape of the pointer ) here if the way to simulate a MOUSE OVER
Hola Javier, prueba con: W_test.HANDLE (ejemplo completo es el que acabé postando)Javier Tovar wrote:Hola jpp,
Hola Pablo César,
Fantastico! me quede
Un Abrazo
Un Abrazo
