secure email with attachment sending...
Re: secure email with attachment sending...
Bingo :
Hotmail server.jpg (44.07 KiB) Viewed 5103 times
Try modify servers
aServers [1] := { 'Gmail   Outgoing Mail Server ' , 'smtp.gmail.com'         , '465' }
aServers [2] := { 'Hotmail Outgoing Mail Server ' , 'smtp-mail.outlook.com'  , '25' }  /* [color=#FF0000]Work [/color]*/
aServers [3] := { 'Yahoo   Outgoing Mail Server ' , 'smtp.mail.yahoo.com.ar' , '465' }
Modify source
 TRY
   /* Guardamos la configuracion de Servidor, Puerto, Usuario */
      loCfg := CREATEOBJECT( "CDO.Configuration" )
      WITH OBJECT loCfg:Fields
         :Item( "http://schemas.microsoft.com/cdo/configuration/smtpserver" )      :Value := aServers [Main.Server.Value , 2 ]
         :Item( "http://schemas.microsoft.com/cdo/configuration/smtpserverport" )  :Value := VAL (aServers [ Main.Server.Value , 3])
         :Item( "http://schemas.microsoft.com/cdo/configuration/sendusing" )       :Value := 2
         :Item( "http://schemas.microsoft.com/cdo/configuration/smtpauthenticate" ):Value := .T.
         :Item( "http://schemas.microsoft.com/cdo/configuration/smtpusessl" )      :Value := .T.
		 :Item( "http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") :Value := 1
         :Item( "http://schemas.microsoft.com/cdo/configuration/sendusername" )    :Value := Main.cFrom.Value
         :Item( "http://schemas.microsoft.com/cdo/configuration/sendpassword" )    :Value := Main.cPass.Value
         :Update()
      END WITH
Post by EduardoLuis »
Hola Dany:
En cuanto a los attachment, probe con un archivo *.PDF de 10.95 mg y lo transmitió correctamente.- TODO OK.-
FELICITACIONES.- AMIGO.-
Abrazo. Eduardo
hmgchang wrote:Happy New Year All ....
- How can we send email with attachment ( report/dbf) from Hmg program ?
- Can we secure the to only specified email address but not others ?
- If only I can hv a sample on the above issues....
Thks n Rgds
Chang
Hi Chang:
Look http://hmgforum.com/viewtopic.php?f=24&t=3473
Hola Max, gracias por tu ejemplo.
Probe y no he podido hacer que se envie un mail. :?
Ya intente cambiar los nombres de Servidores y Puertos y nada.
*aServers [2] := { 'Hotmail Outgoing Mail Server ' , 'smtp-mail.outlook.com' , '25' } // 587
aServers [2] := { 'Hotmail Outgoing Mail Server ' , 'smtp.live.com' , '587' } // <=== Con este envio desde OfficeOutlook
Alguna idea ?
Otra cosa, estoy compilando con HMG 3.1.5 y me salen 2 "ToolTip" en los botones de la ToolBar (señalado con amarillo)
no se si sea problema de esta version, a alguien mas le aparece así ?
Hi Max, thanks for your example.
I tried and I have not been able to do is send a mail. :?
Now try changing the names of servers and ports and nothing.
 aServers [2] := { 'Hotmail Outgoing Mail Server ' , 'smtp.live.com'          , '587' }  // [color=#FF0000]<=== With this configuration I send from OfficeOutlook[/color]
Any idea?
Another thing, I'm compiling with HMG 3.1.5 and I get 2 "ToolTip" in the ToolBar buttons (marked with yellow)
can be detailed in this version, so they appear to someone else?
Para los que tengan Win7 que puedan probar lo siguiente...
For those who have Win7 you can try the following ...
http://www.howtogeek.com/120011/stupid- ... -software/
andyglezl wrote:Hola Max, gracias por tu ejemplo.
Andy, lee este post http://hmgforum.com/viewtopic.php?f=24&t=3473
recuerda que necesitas configurar Outlook.com para acceder de aplicaciones externas POP3 y SMTP.
con la configuracion propuesta funciona.
