Dbf Grid Print Version: 1.00000
fchirico
Re: Dbf Grid Print Version: 1.00000
Post by fchirico »
Javier, muy buena la aplicación!
Te felicito.
Te comento dos bugs:
1) Si abres una DBF de una carpeta que no sea la actual, la aplicación simplemente se cierra
2) Si hago doble click sobre el grid en una columna que no tiene un campo asignado, el programa muestra el siguiente error:
Date:30/12/2013 Time: 23:08:15
Error: HMG 3.2 Stable
Grid: Invalid nColIndex. Program Terminated
Called from _GRIDEX_GETCOLUMNCONTROL(104)
Called from _GRIDEX_GETPROPERTY(8766)
Called from GETPROPERTY(7522)
Called from BORRACOLUMNA(457)
Called from (b)PRINCIPAL(1738)
Called from EVENTS(2960)
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(5195)
Called from DOMETHOD(8102)
Called from PRINCIPAL(168)
Muchas gracias y saludos.
Javier, very good app!
I congratulate you.
I commented two bugs:
1) If you open a DBF in a folder other than the current one, the application simply closes
2) If I double click on the grid in a column that does not have an assigned field, the program displays the following error:
Date: 30/12/2013 Time: 23:08:15
Called from _GRIDEX_GETCOLUMNCONTROL (104)
Called from _GRIDEX_GETPROPERTY (8766)
Called from getProperty (7522)
Called from BORRACOLUMNA (457)
Called from (b) MAIN (1738)
Called from EVENTS (2960)
Called from DOMESSAGELOOP (0)
Called from _ACTIVATEWINDOW (5195)
Called from DOMETHOD (8102)
Called from MAIN (168)
Thank you very much and greetings.
Saludos, Fernando Chirico.
Hola fchirico,
1.- La primera a mi no me ocurre en lo absoluto.
2.- La seguda si me pasa también, pero no encuentro la forma de remediarlo, esto a lo mejor es un Bug del propio grid.
Tendremos que esperar a ver que dicen los Maestros!. En teoría no lo debe de hacer. :(
Que bueno que te gusto :D
Saludos :D
Hello fchirico,
1 -. The first I do not think at all.
. 2 - The seguda if I pass too, but can not find how to remedy it, maybe this is a bug in the grid itself.
We'll have to wait and see what the Masters say!. In theory it should not do. :(
Glad you liked :D
regards :D
Saludos y un gran abrazo :D
Greetings and a big hug: D
Hola a todos,
Sigo afinando mi aplicación espero que les sea útil!
Hi all,
I keep tweaking my application I hope you find it useful!
Imprimir.rar
(1.15 MiB) Downloaded 359 times
Hello Javier,
Very nice and usefull!
Gracias Serge, que bueno que te gusto y te sea útil!
Thanks Serge, good taste and you will be useful!
