HELP FOR CONSOLE MODE PREVIEW REPORT
henglongbike
Post by henglongbike »
I'm a newbird here, please help.
After preview the test report, I can not return back to console mode and program closed.
I make a sample cobe here.
REQUEST HB_GT_WIN_DEFAULT
SETMODE(25,80)
? "Now starting the program."
Wait
PrintJob()
? "Now ending the program"
Wait
Function PrintJob()
	DEFINE WINDOW dummy ;
		at 0,0 ;
		width 0 ;
		height 0 ;
		main ;
		nocaption ;
		nosysmenu ;
		on init StartMain()
	ACTIVATE WINDOW dummy
Function StartMain()
	select printer default preview
	start printdoc
	start printpage
	@ 20,20 print "This is a test print"
	end printpage
	end printdoc
	EndPrintJob()
Function EndPrintJob()
dummy.release
Re: HELP FOR CONSOLE MODE PREVIEW REPORT
Hola henglongbike
Quita la linea indicada. / Removes the specified line.
start printdoc
start printpage
end printpage
end printdoc
EndPrintJob()
Saludos/regards
Always, when you elease main window, your application will end
henglongbike
Thank Javier Tovar & mol
I have removed the function EndPrintJob(),
also got the problem. It can not return back to console mode.
Can not display "Now ending the program" & wait.
And I see this
viewtopic.php?f=5&t=178
Mixed-Mode: Continue console after gui-window is released
I don't how to do it.
Code:
#include <minigui.ch>
procedure main
   Load Window dummy as main && is an invisble main window, that calls dummy_onInit()
   main.Activate
return
function dummy_onInit()
   * Console-Part
   ? "Hello world"
   gui_function() && Calls the visible window
   * After the user closes the window, the console-part will continue
   ? "Welcome back!"
   ? "Program will terminate in 5 seconds"
   inkey(5)
   main.release
return
function gui_function()
   Load Window window1 && is a MODAL window
   window1.Center
   window1.activate
return
henglongbike
Please help !!
I have some clipper program need to run in window 8 64bit,
it's need to run between console mode and GUI.
Hi Henglongbike,
this is equivalent to the previous example:
   DEFINE WINDOW Form_Main;
      WIDTH 100;
      HEIGHT 100;
      MAIN;
      NOSHOW;
      ON INIT ProcMixMode()
   ACTIVATE WINDOW Form_Main
Procedure ProcMixMode()
// Console-Part
   SETMODE (25,80)
   ? "Hello world"
   Wait "Press key to continue..."
// Calls the visible window
   GUI_Function()
// After the user closes the window, the console-part will continue
   ? "Welcome back!"
   Inkey(5)
// Close the program
   Form_Main.Release
Procedure GUI_Function()
   DEFINE WINDOW Form_Modal;
      WIDTH  300;
      HEIGHT 300;
      TITLE "GUI_Function";
      MODAL
      @ 50,  100 LABEL  Label_1  VALUE "This a modal Window"
      @ 200, 100 BUTTON Button_1 CAPTION "OK" ACTION MsgInfo ("Hello")
   CENTER WINDOW Form_Modal
   ACTIVATE WINDOW Form_Modal
In HMG.3.2 exists the trick: SET WINDOW MAIN ON/OFF (see demo in C:\hmg.3.2\SAMPLES\Miscellaneous\ScreenSplash)
// Console-Part
   SETMODE (25,80)
   ? "Hello world"
   GUI_Function()
   ? "Welcome back!"
   Inkey(5)
   SET WINDOW MAIN OFF
      WIDTH  300;
      HEIGHT 300;
      MODAL
   SET WINDOW MAIN ON
This demo is with print command:
      WIDTH 100;
      HEIGHT 100;
      MAIN;
      NOSHOW;
// Console-Part
   SETMODE (25,80)
   ? "Hello world"
   GUI_Function()
   ? "Welcome back!"
   Inkey(5)
   Form_Main.Release
   DEFINE WINDOW Form_Print;
      WIDTH  30;
      HEIGHT 30;
      NOSHOW;
      CHILD
      DEFINE TIMER Timer_1 INTERVAL 300 ACTION Proc_Print()
   CENTER WINDOW Form_Print
   ACTIVATE WINDOW Form_Print
Procedure Proc_Print()
   Form_Print.Timer_1.Release
   start printdoc
   start printpage
   end printpage
   end printdoc
   Form_Print.Release
henglongbike
Thank srvet_claudio,
Great ! The code is work !
I will write in my program.
Thank you for help.
