Good point of view ! You are right Scot, troubles becomes only with accentuated characters for other languages non-English.CalScot wrote:maybe it's because I use only (American) English that I haven't really thought about this, but it sounds like we're heading towards the end of DBF files!![]()
Diferencias HMG 3.0.42 vs 3.2
Re: Diferencias HMG 3.0.42 vs 3.2
Thanks, Pablo.
As I said:
CalScot
As I said:
CalScot
No, not see it that way. At the end, this will encourage us all to work with SQL something ... that is evolving in our knowledge.CalScot wrote:As I said:![]()
You just had a birthday: Before you know it, you'll be my age - and increasingly less inclined to have to change things that you thought you'd finished making perfect and stable!!!
Yes, I'm laughing about it, but there is some truth to it, too!
CalScot
- mjaviergutierrez
- DBs Used: DBF, MySQL
Hola, haciendo mi primer prueba con hmg 3.1.5, uso el ide (no ide_ansi ), creo un programa con una rutina que utilizo mucho que es dejar un archivo .TXT en las impresiones y llamar al DOSPRINTER para que lo habrá en PDF. Imprimo letras acentuadas y la eñe pero me muestra símbolos. Me pasa lo mismo en HMG 3.0.46, pero lo soluciono con HB_ANSITOOEM(), pensé que con esta versión nueva, ya usaría esta función. Dejo el código a continuación:
tengo notepad++ v6.1.5 (UNICODE), lo puse en por el menú Formato: Codificar en UTF-8
porque pasa esto ? entendi mal ?
Function Imprimir( )
SET PRINT TO REPORT.TXT
SET PRINT ON
SET CONSOLE OFF
? "PRUEBA DE HMG UNICODE"
? "LETRAS ACENTUADAS : á é í ó ú ñ Ñ"
SET PRINT TO
SET PRINT OFF
SET CONSOLE OFF
EXECUTE FILE "DOSPRINTER.EXE" PARAMETERS "/PDF REPORT.TXT"
