HMG 3.2 (Stable)
tonton2
Re: HMG 3.2 (Stable)
Post by tonton2 »
Bonsoir,
Pour moi tout marche trés bien que ce soit dans Unicode ou Ansi pourtant dans ma compilation j'ai 36 fichiers *.prg.
Merci pour tout ce que vous faîtes. :D
NB.j'ais mis le fichier IDE_Ansi et IDE_Unicode du 25/08/2013 et jai changé dans hmg.ini j'ai remis hmg.c:\hmg.3.2 à la place de c:\hmg.3.1.5 et en plus j'ai mis frenc.ansi et french.uni
Hello,
For me everything works very well in either Unicode or Ansi yet in my compilation I have 36 files *. Prg.
Thank you for all that you do. :roll:
NB.j 'ais set IDE_Ansi and IDE_Unicode file 25/08/2013 and I have changed hmg.ini I gave hmg.c: \ hmg.3.2 instead of c: \ hmg.3.1.5 and I put more frenc.ansi and french.uni
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Hi All
I should repeat this.
( viewtopic.php?f=30&t=2996&p=27136#p27133)
Do you know peel onions ?
Attention : this article is dated 2003 :o
Happy HMG :D
tonton2 wrote:Hello,
Thanks Tonton.
Pablo César wrote:Hi Marek,
Is it possible you post any short example with the same behaviour ?
Hi All.
This patch allow sets tooltip in the image control.
Copy the
PRG and C files in c:\hmg.3.2\source
and CH file in c:\hmg.3.2\include
and rebuild the lib.
HMG.3.2_patch1.rar
(41.08 KiB) Downloaded 491 times
HMG 3.2 (Stable)
srvet_claudio wrote:Hi All.
Thank you master !! :)
But for me here, it doesn't work... (copying files in respective folders and rebuilded) :(
HMG 3.2 (Stable)
Hi Claudio, I made following test (same in attached executable file):
DEFINE WINDOW demo AT 40,40 WIDTH 500 HEIGHT 400 TITLE 'Demo Tooltip' ;
    ICON NIL MAIN
    @ 10,10 IMAGE imagen1 picture "pastel.jpg"  WIDTH 150 HEIGHT 150 ACTION  Msginfo("Hola") STRETCH TOOLTIP "Prueba de Tooltip"
	_DefineImage ( "imagen2", "demo", 200, 180, "pastel.jpg" , 150 , 150 , {||Msginfo("Hola")}  , Nil, .F. , .T. , .F.,{0,0,0},.T.,Nil, "Prueba de Tooltip" )
	DEFINE IMAGE imagen3
	    ROW    10
	    COL    200
	    WIDTH  150
	    HEIGHT 150
	    PICTURE "pastel.jpg"
	    HELPID Nil
	    VISIBLE .T.
	    STRETCH .T.
	END IMAGE
	DEFINE LABEL Label_1
	    ROW    230
	    COL    360
	    WIDTH  120
	    HEIGHT 24
	    VALUE "<- This is working"
	    FONTNAME "Arial"
	    FONTSIZE 9
	    TOOLTIP ""
	    FONTBOLD .F.
	    FONTITALIC .F.
	    FONTUNDERLINE .F.
	    FONTSTRIKEOUT .F.
	    HELPID Nil
	    VISIBLE .T.
	    TRANSPARENT .F.
	    ACTION Nil
	    AUTOSIZE .F.
	    BACKCOLOR Nil
	    FONTCOLOR Nil
	END LABEL
	DEFINE BUTTON Button_1
	    ROW    220
	    COL    10
	    WIDTH  100
	    HEIGHT 28
	    ACTION ThisWindow.Release()
	    CAPTION "Salida"
	    FONTNAME "Arial"
	    FONTSIZE 9
	    TOOLTIP "Button ToolTip Test"
	    FONTBOLD .F.
	    FONTITALIC .F.
	    FONTUNDERLINE .F.
	    FONTSTRIKEOUT .F.
	    ONGOTFOCUS Nil
	    ONLOSTFOCUS Nil
	    HELPID Nil
	    FLAT .F.
	    TABSTOP .T.
	    VISIBLE .T.
	    TRANSPARENT .F.
	    MULTILINE .F.
	    PICTURE Nil
	    PICTALIGNMENT TOP
	END BUTTON
end window
Activate Window demo
I think Claudio, is missing your C:\hmg.3.2\INCLUDE\i_altsyntax.ch file to be attached into the HMG.3.2_patch1.rar (for DEFINE IMAGE too) and some variable treatments for undeclared variables in C:\hmg.3.2\SOURCE\h_image.prg to turn it workable, I guess it so. I saw the time of your posting was too late, you were so tired at this time... :(
But calling the function like this:
_DefineImage("imagen2","demo",200,180,"pastel.jpg",150,150,{||Msginfo("Hola")} ,Nil,.F.,.T.,.F.,{0,0,0},.T.,Nil, "Prueba de Tooltip")
it is working good ! (in WinXP and Win7) :)
demo (executable file).rar
(827.74 KiB) Downloaded 423 times
HMG 3.2 (Stable)
There is something wrong with TRANSPARENT in @...IMAGE, because when I trying gives me syntax error...
Pablo César wrote: But calling the function like this:
Pablo César wrote:There is something wrong with TRANSPARENT in @...IMAGE, because when I trying gives me syntax error...
Pablo, on my system everything works OK, the problem is a conflict caused by the macro-replacement of Harbour.
viewtopic.php?p=31299#p31299
meneale
Post by meneale »
This is how image with transparent property looks :|
AMD Phenom II X6 1090T 3.2GHz (OverClock 3.9GHz) | Windows 8.1 Pro 64-bit
4GB DDR3 | GTX 550 Ti 1GB | MSI 880GMA-E35
