Regular Expression or Regex
hmgchang
Post by hmgchang »
Hello Masters,
I was looked into the check.hb files and came across these lines,
FOR EACH match IN hb_regexAll( "([A-Za-z] |[^A-Za-z_:]|^)([A-Za-z_][A-Za-z0-9_]+\()", cFileStripped,,,,, .F. )
IF Len( match[ 2 ][ _MATCH_cStr ] ) != 2 .OR. !( Left( match[ 2 ][ _MATCH_cStr ], 1 ) $ "D" /* "METHOD" */ )
cProper := ProperCase( hAll, hb_StrShrink( match[ 3 ][ _MATCH_cStr ] ) ) + "("
IF !( cProper == match[ 3 ][ _MATCH_cStr ] ) .AND. ;
!( Upper( cProper ) == Upper( "FILE(" ) ) .AND. ; /* interacts with "file(s)" text */
!( Upper( cProper ) == Upper( "TOKEN(" ) ) .AND. ; /* interacts with "token(s)" text */
!( Upper( cProper ) == Upper( "INT(" ) ) .AND. ; /* interacts with SQL statements */
( ! lInCommentOnly .OR. !( "|" + Lower( cProper ) + "|" $ Lower( "|Max(|Min(|FOpen(|Abs(|Log10(|GetEnv(|Sqrt(|Rand(|IsDigit(|IsAlpha(|" ) ) )
cFile := Left( cFile, match[ 3 ][ _MATCH_nStart ] - 1 ) + cProper + SubStr( cFile, match[ 3 ][ _MATCH_nEnd ] + 1 )
IF lVerbose
OutStd( cFileName, match[ 3 ][ _MATCH_cStr ], cProper, "|" + match[ 1 ][ _MATCH_cStr ] + "|" + hb_eol() )
nChanged++
I tried to figure out how the Regex works, but not easy. Can you pls give me some very basic understanding of Regular Expression and the usage ?
Thank you in advance !
Just Hmg It !
Re: Regular Expression or Regex
Hi Chang
hmgchang wrote: I tried to figure out how the Regex works, but not easy. Can you pls give me some very basic understanding of Regular Expression and the usage ?
You may find some basic info about regular expression here.
For Harbour specific subject asking to Harbour Users Group or following Harbour Developers Group may be more useful.
Amarante
DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL
Post by Amarante »
Below an example of the use of Regular Expression:
FUNCTION Swap_RegExp( cString, cExpRegular, cSwap )
* Parameters:
* cString      <expC> - string with data
* cExpRegular  <expC> - string with regular expression to find
* cSwap        [expC] - string to change (default SPACE( 1 ) )
* Return:
* expC - cString changed
LOCAL	aFound
IF cSwap = NIL
  cSwap := SPACE( 1 )
cExpRegular := HB_RegexComp( cExpRegular )
DO WHILE .NOT. EMPTY( aFound := HB_Regex( cExpRegular, cString ) )
  cString := aFound[ 2 ] + cSwap + aFound[ LEN( aFound ) ]
ENDDO
RETURN cString
Gracias por compartir Amarante
Hi Amarate
Amarante wrote:Below an example of the use of Regular Expression:
Thank to share, but;
Is this a "working" sample ?
fe
LOCAL   aFound
  cString := aFound[ 2 ] ...    <- without declared aFound is an array
is this legal ?
And, we need a sample statement to call / apply this function for understanding the subject,
by see a regular expression is similar to what ?
Happy HMG :D
Amarante
Post by Amarante »
esgici,
You were correct. Inadvertently I copied a routine part of my use and had not verified their operation. Follows, for those interested, the routine corrected and examples of using regular expressions.
hugs
PROCEDURE MAIN()
LOCAL xRegex
LOCAL aMatch
LOCAL cStr := "This Text +Plus Date [1962-11-20] is A.3265-5"
// Example of using regular expression:
* checks if a text contains YYYY-MM-DD
xRegex := HB_RegexComp( "([0-9]{4}[-][0-9]{2}[-][0-9]{2})" )
aMatch := HB_Regex( xRegex, cStr )
* Found
IF .NOT. EMPTY( aMatch )
  MsgInfo( aMatch[ 1 ] )
// Example of using Swap_RegExp function:
* regular expression (*)
cStr := Swap_RegExp( cStr, "([0-9]{4}[-][0-9]{2}[-][0-9]{2})", "Secret" )
MsgInfo( cStr )
* Parameters:
* Return:
LOCAL   aFound
IF cSwap = NIL
  cSwap := SPACE( 1 )
IF .NOT. EMPTY( aFound := HB_Regex( cExpRegular, cString ) )
  cString := STRTRAN( cString, aFound[ 2 ], cSwap )
RETURN cString
Samples_RegExp.rar
(25.55 KiB) Downloaded 402 times
No entiendo bien esto de expresiones reguleres, a que se refieren?.
Veo en los ejemplos que hay "Say", esto es en modo consola solamente?
I do not understand this in reguleres expressions that refer to?.
I see in the examples that there is "Say" that is only in console mode?
Amarante
Post by Amarante »
Javier Tovar wrote:No entiendo bien esto de expresiones reguleres, a que se refieren?.
Javier,
Examples are pure Harbour, so the use of SAY to display the result.
A regular expression in Computing, sets a standard to be used to find or replace words or groups of words. It is an accurate way to make certain portions of the search text.
For example, if the set of words is {wing, car, garden, eggs, ground} and regular expression search for a pattern rr, get the words car and land.
There are different formats to set up regular expressions, but with some general notions is possible to understand much of the expressions. Source: Wikipedia - Regular Expression
Read more at the Net Workshop: http://www.oficinadanet.com.br/artigo/p ... -regulares" onclick="window.open(this.href);return false;
Hope this helps.
hugs
Javier,
Los ejemplos están em Harbour, por lo que el uso de SAY es para mostrar el resultado.
Una expresión regular en Informática, establece un estándar que se utiliza para buscar o reemplazar palabras o grupos de palabras. Es una forma precisa para que ciertas partes del texto de búsqueda.
Por ejemplo, si el conjunto de palabras es {ala, coche, jardín, huevos, tierra} y búsqueda de expresiones regulares para un rr patrón, consiga la palabra coche y la tierra.
Existen diferentes formatos para crear expresiones regulares, pero con algunas nociones generales es posible entender gran parte de las expresiones. Fuente: Wikipedia - Expresión Regular
Ver más en el Taller neto: http://www.oficinadanet.com.br/artigo/p ... -regulares" onclick="window.open(this.href);return false;
Espero que esto ayude.
Abrazos
Muchas gracias por la información.
Thank you very much for the information.
Regex can also be used in testing emailadresses:
* checks if a text is a valid emailadres
cStr1 := "sg@host.com"	// VALID
cStr2 := "sg#host.com"	// INVALID
IF Is_Valid_Emailaddress(cStr1)
	MsgInfo( cStr1  + ' is a VALID emailadres ', 'OK'  )
   MsgInfo( cStr1  + ' is an invalid emailadres !!', 'NOK' )
IF Is_Valid_Emailaddress(cStr2)
	MsgInfo( cStr2  + ' is a VALID emailadres ', 'OK'  )
   MsgInfo( cStr2  + ' is an invalid emailadres !!', 'NOK' )
Function Is_Valid_Emailaddress(cStr)
xRegex := HB_RegexComp( "([_\.0-9a-zA-Z-]+@([0-9a-zA-Z][0-9a-zA-Z-]+\.)+[a-zA-Z]{2,6})" )
   RETURN .T. // valid emailadres
   RETURN .F. // invalid emailadres
It has not been tested extensively so I'm not sure if it is 100% OK.
Greetings,
