Hi Rathi, what I wonder is if the folders of examples will be restructured, ie, whether they will join all in one and there will rename subfolders for such examples. May you tell me how is going to be for next release ?Rathinagiri wrote:Definitely it will be useful for all. Thanks Pablo.
HMG Samples Folder Structure
Folder Structure
Too many folders and some are in wrong folder.
For example, folder: C:\hmg.3.1.5\SAMPLES\Controls\EditBox
With sub-folders: EDIT.1, EDIT.2 and EDIT.EXTENDED ? This is not EditBox, it is EDIT command.
Is it possible to participate and review this case ?
I believe that same given structure must accompany to your DOC system.
In that way It makes easier to located from DOC to SAMPLES.
Roberto, already said in some where that is also not agree with some folders.
I guess Print, DLL, PrintEAN13, ReportBasic, OLE, DATA_BOUND, Resource, SystemTray (Notify Menu), This, ThisWindow, Valid, VirtualDim, Panel, Font (It could even be if FONT were a control), Cursor, MenuContext in Controls folder ?
