Unicode and HMG_HPDF
Re: Unicode and HMG_HPDF
IMATECH wrote:Hi Esgici !
Adjusted ( but not tested ! )
Error
IMATECH wrote: Adjusted ( but not tested ! )
I tested :
Two REQUEST moved to before Main()
hb_gtsys() moved to after Main()
PROCEDURE() ( and its RETURN ) lines commented;
and the result ( same as Dave's ) :
Error BASE/1302 Argument error: HB_TRANSLATE
Called from HB_TRANSLATE(0)
Called from MAIN(24) -> SELECT HPDFDOC ( hb_Translate( cTarget...
IMATECH
Post by IMATECH »
Hi Esgici, bdp !
Adjusted :?
and
Tested ( Works ok )
espãnol.zip
txt and pdf
(2.1 KiB) Downloaded 917 times
#include "hfcl.ch"
PROCEDURE Main()
LOCAL i
LOCAL lSelPDF
LOCAL aSourceText
LOCAL cSourceFileName
LOCAL cTargetFileName
hb_langSelect( 'es' )
hb_cdpSelect( "UTF8EX" )
cSourceFileName := "espãnol.txt"
aSourceText := hb_aTokens( hb_Translate( HB_MEMOREAD( cSourceFileName ), 'UTF8EX', 'ESISO' ), CHR(10) )
cTargetFileName := STRTRAN( cSourceFileName, "txt", "pdf" )
SELECT HPDFDOC ( hb_Translate( cTargetFileName, 'UTF8EX', 'ESISO' ) ) TO lSelPDF
IF lSelPDF
_HMG_HPDF_SetEncoding( "WinAnsiEncoding" )
START HPDFDOC
START HPDFPAGE
FOR i := 1 TO Len( aSourceText )
@ ( i * 4 )+15, 20 HPDFPRINT aSourceText[ i ]
END HPDFPAGE
END HPDFDOC
IF FILE( cTargetFileName )
MsgInfo( "PDF Builded as " + cTargetFileName )
MsgStop( "PDF Building Unsuccessful :(", "Unexpected ERROR !" )
ENDIF lSelPDF
// hb_gtsys()
PROCEDURE hb_gtsys()
REQUEST HB_LANG_ES
REQUEST HB_CODEPAGE_ESISO
REQUEST HB_CODEPAGE_UTF8EX
Harbour uses last libHaru sources ( 2.3.0RC2 ) supporting 1~2 bytes UTF8 codes
Then HMG_hbHpdf can be updated to use these new resources
libHaru 2.3.0RC2
    Changed package naming, no other changes was done.
libHaru 2.3.0RC1
    Added support for 3dMeasures of subtype PD3 and 3DC, projection annotations, ExData and javascript attached to a U3D model. (Robert Würfel)
    Added support for 1- and 2-byte UTF8 codes. (Clayman)
    Added full PDF/A1-b support. (Petr Pytelka)
    Added support for CCITT compression for B/W images. (Petr Pytelka)
    Add support for TwoPageLeft and TwoPageRight layouts. (Vincent Dupont)
    Const-ified arrays used in the sources. (Ilkka Lehtoranta)
    Fixed build with libpng 1.5.0
    Fixed bug in HPDF_GetContents() - isize variable was not initialized. (Vincent Dupont)
    Fixed possible endless loop in PNG handling code. (reported by Mathew Waters)
    Fixed several issues based on the warnings generated by clang-analyzer. (Daniel Höpfl)
    Fixed quite a number of warnings. (Davide Achilli)
    Added 'd' postfix to debug build, fixed wrong filename. (Wim Dumon)
    Fixed HPDF_Text_Rect() not to split words in some obscure cases.
http://libharu.org/
Code Template:
/* UTF8 */
HPDF_UseUTFEncodings( oPdf )
/* Embend Font */
HPDF_LoadTTFontFromFile( oPdf, "Any.ttf", .T. )
/* oPdf Font */
HPDF_GetFont( oPdf, cFontName, "UTF-8" )
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH wrote: Adjusted :?
and
Tested ( Works ok )
Hola Ronaldo,
yes; tested, works ok :arrow:
Thank you very much :D
Two little question ( if no problem ;) )
  • . español .OR. espãnol; which one is correct ? ( It cost me two hours :( )
    . how a function ( hb_gtsys ) runs without calling :o :?
Anyway, thanks again :)
Not only problem solved, but for everything increased my knowledge :D
As Daniel said : everybody learns something by every post ! 8-)
Viva HMG :D
IMATECH
Post by IMATECH »
Hi Esgici !
. español .OR. espãnol ( just a wrong backspace: shit happens )
Sorry, I don't know nothing about spanish language rules :(
. hb_gtsys
It's a default behavior for any Harbour GT
. HPDF_UseUTFEncodings( oPdf )
After Sr.Rathinagiri just include this function to HMG_HPDF lib any language will be correct created inside pdf files ( japanese, greek, ... )
. everybody learns something by every post !
Some times by every re-edited posts too :lol:
Then my posts can be readed again and again...
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH wrote: . HPDF_UseUTFEncodings( oPdf )
Yes, you are right,
Your good news and suggestions about HaruPDF and UT8 is more important than my asked problem,
thanks a lot for this also :)
Hopefully forum management will take into account your guidance :arrow:
Regarding re-editing posts, my humble opinion is:
forum software don't allow deleting answered posts;
this rule must apply to editing posts too, I think.
Because some people abusing it; uses posts as a scratchpad,
and will be very difficult to follow the subjects.
For example, corrects an his erroneous sentences after someone warn it :(
Anyway, thanks to everything and
Viva HMG :D
IMATECH
Post by IMATECH »
Hi quartz !
It's for you :)
Mixed Latin and Greek
pdf using Arial.ttf font
hbhpdf_unicode.zip
Windows Font, Source Sample and PDF File
(463.86 KiB) Downloaded 1074 times
M., Ronaldo
By: IMATECH
Imation Tecnologia
IMATECH wrote:Hi quartz !
It's for you :)
hbhpdf_unicode.zip
Thank you Ronaldo,
Add following 2 line to run above example
#define HPDF_COMP_ALL 0x0F
REQUEST HB_GT_WIN_DEFAULT
quartz565
Post by quartz565 »
Thank you very much Ronaldo. It works perfectly! :)
Thanks all !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
IMATECH
Post by IMATECH »
Hi !
Esgici, DanielMaximiliano, BPD and Nikos :)
Thanks for interest and feedback
Best regards
M., Ronaldo
By: IMATECH
Imation Tecnologia
