HMG 3.1.5
Re: HMG 3.1.5 (Test)
con MsgInfo( STR( VolSerial( "C:" ) ) obtengo "2696837951".
Entonces no me queda claro porque HDGETSERIAL me da otro
numero diferente ???. Creo que tendre que cambiar de todos modos.
Gracias
with MsgInfo( STR (VolSerial("C:") ) I get "2696837951".
So I'm not clear because HDGETSERIAL gives me another
different number???. I think I'll have to change anyway.
thanks
Gracias
thanks
- esgici
It's impossible to know why it gives a different number, without seeing source code of HDGETSERIALandyglezl wrote: with MsgInfo( STR (VolSerial("C:") ) I get "2696837951".
Happy HMG'ing
Viva INTERNATIONAL HMG
Andy :andyglezl wrote:con MsgInfo( STR( VolSerial( "C:" ) ) obtengo "2696837951".
Gracias
thanks
probaste con el ejemplo que indique anteriormente ?
OK, Ya me funciona el ejecutable. ( quite la funcion MAKELAYER )
La funcion HDGETSERIAL("c:\") la he estado utilizando desde hace años pero no recuerdo
de donde la obtuve, ademas esta en C y siempre despliega el "warning" al compilar.
OK, I already runs the executable. (Remove the function MAKELAYER)
The function HDGETSERIAL ("c: \") I've been using for years but can not remember
where I got it, also is in C and always displays the "warning" to compile.
Harbour 3.2.0dev (r1307180024)
Copyright (c) 1999-2013, http ://harbour-project.org/
conad.prg: In function 'HB_FUN_HDGETSERIAL':
conad.prg:8007:5: warning: passing argument 1 of 'Get_SerialNumber' discards 'const' qualifier from pointer target type [enabled by default]
conad.prg:7998:19: note: expected 'char *' but argument is of type 'const char *'
conad.prg: In function 'HB_FUN_MAKELAYER':
conad.prg:8239:9: warning: implicit declaration of function 'SetLayeredWindowAttributes' [-Wimplicit-function-declaration]
Warning: resolving _SetLayeredWindowAttributes by linking to _SetLayeredWindowAttributes@16
Use --enable-stdcall-fixup to disable these warnings
Use --disable-stdcall-fixup to disable these fixups
resumiendo.
summarizing.
A fin de cuentas, llegue al mismo resultado. Gracias.
After all, reach the same result.Thanks.
Ahora me falta resolver la funcion MAKELAYER()
Now I need to solve MAKELAYER() function
resumiendo.
summarizing.
HDGETSERIAL() // -1598129345
VOL en D.O.S. // A0BE7B3F
NTOC (VolSerial ("C:"), 16) // A0BE7B3F
STR( VolSerial( "C:" ) ) // 2696837951
NTOC( 2696837951, 16 ) ) // A0BE7B3F
NumToHex( VolSerial( "C:" ) ) // A0BE7B3F
NumToHex( HDGETSERIAL("c:\") ) // FFFFFFFFA0BE7B3F
Las pruebas anteriores indican que: A0BE7B3F = 2696837951 = -1598129345
Previous tests indicated that:
Que hace esa funcion Andy ?.andyglezl wrote: Ahora me falta resolver la funcion MAKELAYER()
- esgici
Hola Andres
is correct, but
not !
If your function(s) are in binary format ( .lib or anything else ) it's difficult to help you, I think
I'm not a mathematician, but I know :andyglezl wrote:Previous tests indicate that: A0BE7B3F = 2696837951 = -1598129345
is correct, but
not !
- srvet_claudio
Hi Andres,andyglezl wrote:OK, Ya me funciona el ejecutable. ( quite la funcion MAKELAYER )
display lines numbers 8007, 7998 and 8239 (+/- 10 lines) of file conad.prg
Yo reprobé matematicas, asumo que es igual en base al resutado obtenido.
I failed in mathematics, I assume it's just based on the result set obtained.
The MAKELAYER() function makes the window transparent,Here are the routines in "C":
Gracias. Thanks.
La funcion MAKELAYER() hace transparente la ventana, aqui están la rutinas en "C":HDGETSERIAL() // -1598129345
unsigned long Get_SerialNumber(char* RootPathName)
unsigned long SerialNumber;
GetVolumeInformation(RootPathName, NULL, 0, &SerialNumber, NULL, NULL, NULL, 0);
return SerialNumber;
HB_FUNC( HDGETSERIAL)
hb_retnl( Get_SerialNumber(hb_parc(1)) );
#define WS_EX_LAYERED 0x80000
#define LWA_COLORKEY 1
#define LWA_ALPHA 2
WINUSERAPI
BOOL
WINAPI
SetLayeredWindowAttributes(
HWND hwnd,
COLORREF crKey,
BYTE bAlpha,
DWORD dwFlags);
HB_FUNC ( GETWINDOWLONG )
hb_retnl( ( LONG ) GetWindowLong( ( HWND ) hb_parnl( 1 ), hb_parni( 2 ) ) );
HB_FUNC ( SETWINDOWPOS )
HWND hwnd = (HWND) hb_parnl(1); // handle to window or control
HWND hWndInsertAfter= (HWND) hb_parnl(2); // placement-order handle
int X = hb_parni(3); // horizontal position
int Y = hb_parni(4); // vertical position
int cx = hb_parni(5); // width
int cy = hb_parni(6); // height
UINT uFlags = (UINT) hb_parni(7); // window-positioning options
hb_retl( (BOOL) SetWindowPos( hwnd, hWndInsertAfter, X, Y, cx, cy, uFlags ) );
HB_FUNC ( SETLAYEREDWINDOWATTRIBUTES )
COLORREF crKey = (COLORREF) hb_parnl(2);
BYTE bAlpha = (BYTE) hb_parni(3);
DWORD dwFlags = (DWORD) hb_parni(4);
hb_retl( (BOOL) SetLayeredWindowAttributes(hwnd, crKey, bAlpha, dwFlags) );
HB_FUNC (MAKELAYER)
SetWindowLong (hwnd , GWL_EXSTYLE ,
GetWindowLong (hwnd , GWL_EXSTYLE ) | WS_EX_LAYERED ) ;
SetLayeredWindowAttributes(hwnd, 0, crKey, LWA_ALPHA);
}Gracias. Thanks.
- Cades-layer.jpg (43.33 KiB) Viewed 4381 times
- esgici
While digging my moldy archives, found two HDGETSERIAL functionsesgici wrote: It's impossible to know why it gives a different number, without seeing source code of HDGETSERIAL![]()
No any neat and useful hint but as far as I see ;
if function used by Andres is the same and
function invoked from other than current drive and
no parameter ( drive code ) specified
than it returns a negative value.
Happy HMG'ing
- srvet_claudio
Para:
Para el error:
Con HMG.3.1.5 para hacer una ventana transparente tenes:
cambia:andyglezl wrote: conad.prg: In function 'HB_FUN_HDGETSERIAL':
hb_retnl( Get_SerialNumber((char *) hb_parc(1)) );
}Agrega al inicio enseguida del #pragma BEGINDUMPandyglezl wrote:conad.prg: In function 'HB_FUN_MAKELAYER':
#define _WIN32_WINNT 0x0500Code: Select all
SET WINDOW <cFormName> TRANSPARENT TO COLOR <aColor>
