HMG 3.1.5
Re: HMG 3.1.5 (Test)
Mario Mansilla wrote: I mean that there is a LABEL control property (BORDER) that is not contemplated in the IDE, I edit the fmg and manually income (BORDER. T.), but every time I modify something the IDE removes it and I have to re-edit it manually.
My order means that if HMG developers can incorporate this modification.
Thank to clarify and notice :)
I didn't know LABEL control has a BORDER property :(
Adding it to IDE will be only by a gruru ;)
quartz565
Post by quartz565 »
Hi all,
In the IDE, it would be very useful to have an option (button) "Apply" in the values window of Controls, so you'll see the result of a value in the form, without having to reopen the value window, which closes when we press the “OK” button. I do not know how difficult it is, but I think we would save a lot of time... :idea:
Best Regards,
Nikos.
os: Windows Server 2019 - 64
quartz565 wrote: In the IDE, it would be very useful to have an option (button) "Apply" in the values window of Controls, so you'll see the result of a value in the form, without having to reopen the value window, which closes when we press the “OK” button. I do not know how difficult it is, but I think we would save a lot of time... :idea:
Hi all
I agree with Nikos :arrow:
More, IMHO an extra "Apply" button may not required; when changed value of any property of any control, if the new value echoed to form will be very useful.
By the way, me too I have same little wish for next release:
In "prosilver" theme of forum ( my favorite ) "post selection" bar is a bit down and It is at top of home page in other themes:
Post selection bars
Post selection bars
IMHO the top of home page is better place and will be better if will be applied to the "prosilver" theme too .
Yet another little wish:
Pool section in forum home page
And last and the most trivial :
An unnecessary info
An unnecessary info
An unnecessary info.JPG (35.1 KiB) Viewed 4436 times
Since we haven't different manager for different forum / topic, this is a needless info, I think :?
Please nobody will take this personal, everything is for HMG, forum and community.
Viva HMG, HMG Forum and members :D
HMG 3.1.5 (Test)
New item was added at HMG 3.1.5 - Improvements and corrections in order to require for replacing existing example C:\hmg.3.1.5\SAMPLES\SampleApplications\CONTACTOS contributed improvements by Javier Tovar.
Mario Mansilla
Post by Mario Mansilla »
Hola :
Baje el instalador de la version HMG 3.1.5 pero al intentar instalarlo en mi pc mi antivirus AVAST me da error archivo sospechoso (win32 evo gen) en dos archivos de harbour hbformat.exe y hbtest.exe los cuales los envia al area protegida .
Alguien tuvo este problema :( .
Saludos cordilaes.
Mario Mansilla
Hello:
Lower HMG installer version 3.1.5 but when trying to install it on my pc my AVAST antivirus suspicious file it gives me error (win32 evo gen) in two files and hbtest.exe hbformat.exe harbor which sends them to the protected area.
Someone had this problem.
Greetings cordilaes.
Mario Mansilla
Mario Mansilla wrote: Lower HMG installer version 3.1.5 but when trying to install it on my pc my AVAST antivirus suspicious file it gives me error (win32 evo gen) in two files and hbtest.exe hbformat.exe harbor which sends them to the protected area.
Hola Mario
Please look at here and here.
Most probably this is a false alarm ( reported to avast )
Mario Mansilla wrote:Hola :
Saludos cordilaes.
Mario Mansilla
Hello:
Mario Mansilla
Generalmente nunca usaras estos 2 archivos ya que son de tarea especifica.
igual puede indicar falso positivo a estos 2 archivos
Mario Mansilla
Hola Esgici y Daniel :
muchas gracias , perfecto entonces no hay problema .
Mario Mansilla
Hola
Instalé la version 3.1.5 y el parche "HMG.3.1.5_patch2.rar", corrí el "BuildAllLib.bat" y en la generacion
de las librerias, desplegó unos mensajes con error.
Despues compilé mi programa, me desplegó unos mensajes "warning" y me generó el ejecutable,
pero al correrlo, se congela y no hace nada.
Esto es lo que genera el archivo build.log.
Harbour 3.2.0dev (r1307180024)
Copyright (c) 1999-2013, http://harbour-project.org/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
conad.prg: In function 'HB_FUN_HDGETSERIAL':
conad.prg:8007:5: warning: passing argument 1 of 'Get_SerialNumber' discards 'const' qualifier from pointer target type [enabled by default]
conad.prg:7998:19: note: expected 'char *' but argument is of type 'const char *'
conad.prg: In function 'HB_FUN_MAKELAYER':
conad.prg:8239:9: warning: implicit declaration of function 'SetLayeredWindowAttributes' [-Wimplicit-function-declaration]
Warning: resolving _SetLayeredWindowAttributes by linking to _SetLayeredWindowAttributes@16
Use --enable-stdcall-fixup to disable these warnings
Use --disable-stdcall-fixup to disable these fixups
Application Internal Error - D:\RespaldosPCs\DiscoC\Trabajo\ConAd\conad.exe
Terminated at: 2013.10.30 18:14:45
Error irrecuperable 6005: Exception error:
Exception Code:C0000005
Exception Address:004ACBD8
EAX:EEDE3400 EBX:01E5BEBC ECX:00000011 EDX:0158000B
ESI:005EA810 EDI:005E9340 EBP:00EE8A0C
CS:EIP:001B:004ACBD8 SS:ESP:0023:0022DD20
DS:0023 ES:0023 FS:003B GS:0000
Flags:00010286
CS:EIP: 8B 10 F6 C6 20 74 08 89 04 24 E8 99 B6 FF FF 89
SS:ESP: 00EE1D34 FFFFFFF5 00000000 006A3E30 006A3E2E 005EA810 006A3F88 0049FED8 01E5BEBC 005EA810 006E0061 0022DD60 5B154FC1 5B18113C 0022DDCC 003F49F8
C stack:
EIP: EBP: Frame: OldEBP, RetAddr, Params...
004ACBD8 00EE8A0C 0208C530 0208C60C 0208BF7C 0208C4E8 00000000 00ED66BC 00000000 00ED000A 00ED72BC 00ED668C
Modules:
0x00400000 0x00409000 D:\RespaldosPCs\DiscoC\Trabajo\ConAd\conad.exe
0x7C910000 0x000B8000 C:\WINDOWS\system32\ntdll.dll
0x7C800000 0x00103000 C:\WINDOWS\system32\kernel32.dll
0x10000000 0x00176000 D:\RespaldosPCs\DiscoC\Trabajo\ConAd\libmySQL.dll
0x71A50000 0x0000A000 C:\WINDOWS\system32\WSOCK32.dll
0x71A30000 0x00017000 C:\WINDOWS\system32\WS2_32.dll
0x77DA0000 0x000AC000 C:\WINDOWS\system32\ADVAPI32.dll
0x77E50000 0x00093000 C:\WINDOWS\system32\RPCRT4.dll
0x77FC0000 0x00011000 C:\WINDOWS\system32\Secur32.dll
0x77BE0000 0x00058000 C:\WINDOWS\system32\msvcrt.dll
0x71A20000 0x00008000 C:\WINDOWS\system32\WS2HELP.dll
0x773A0000 0x00103000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.DLL
0x77EF0000 0x00049000 C:\WINDOWS\system32\GDI32.dll
0x7E390000 0x00091000 C:\WINDOWS\system32\USER32.dll
0x77F40000 0x00076000 C:\WINDOWS\system32\SHLWAPI.dll
0x76360000 0x0004A000 C:\WINDOWS\system32\COMDLG32.DLL
0x7E6A0000 0x00821000 C:\WINDOWS\system32\SHELL32.dll
0x76330000 0x00005000 C:\WINDOWS\system32\MSIMG32.DLL
0x75ED0000 0x00021000 C:\WINDOWS\system32\MSVFW32.DLL
0x76B00000 0x0002E000 C:\WINDOWS\system32\WINMM.dll
0x774B0000 0x0013E000 C:\WINDOWS\system32\OLE32.dll
0x770F0000 0x0008B000 C:\WINDOWS\system32\OLEAUT32.DLL
0x73B00000 0x00013000 C:\WINDOWS\system32\AVICAP32.DLL
0x77BD0000 0x00008000 C:\WINDOWS\system32\VERSION.dll
0x72F80000 0x00026000 C:\WINDOWS\system32\WINSPOOL.DRV
0x76340000 0x0001D000 C:\WINDOWS\system32\IMM32.DLL
0x5B150000 0x00038000 C:\WINDOWS\system32\uxtheme.dll
0x76BF0000 0x0002E000 C:\WINDOWS\system32\WINTRUST.dll
0x77A50000 0x00096000 C:\WINDOWS\system32\CRYPT32.dll
0x77AF0000 0x00012000 C:\WINDOWS\system32\MSASN1.dll
0x76C50000 0x00028000 C:\WINDOWS\system32\IMAGEHLP.dll
0x72CA0000 0x00009000 C:\WINDOWS\system32\wdmaud.drv
0x72C90000 0x00008000 C:\WINDOWS\system32\msacm32.drv
0x77BB0000 0x00015000 C:\WINDOWS\system32\MSACM32.dll
0x77BA0000 0x00007000 C:\WINDOWS\system32\midimap.dll
0x649C0000 0x00009000 C:\Documents and Settings\All Users\Datos de programa\Real\RealPlayer\BrowserRecordPlugin\Chrome\Hook\rpchrome150browserrecordhelper.dll
0x78520000 0x000A3000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\MSVCR90.dll
0x746B0000 0x0004C000 C:\WINDOWS\system32\MSCTF.dll
0x01560000 0x00005000 C:\Archivos de programa\Unlocker\UnlockerHook.dll
0x75160000 0x0002E000 C:\WINDOWS\system32\msctfime.ime
0x4EBA0000 0x001AB000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22791_x-ww_c8dff154\GdiPlus.dll
0x70E20000 0x00013000 C:\WINDOWS\system32\asycfilt.dll
0x597F0000 0x00055000 C:\WINDOWS\system32\netapi32.dll
0x77B10000 0x00022000 C:\WINDOWS\system32\appHelp.dll
0x76F90000 0x0007F000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77010000 0x000D0000 C:\WINDOWS\system32\COMRes.dll
0x40290000 0x005D7000 C:\WINDOWS\system32\ieframe.dll
0x76BB0000 0x0000B000 C:\WINDOWS\system32\PSAPI.DLL
0x400A0000 0x00045000 C:\WINDOWS\system32\iertutil.dll
0x44430000 0x00128000 C:\WINDOWS\system32\urlmon.dll
0x778F0000 0x000F7000 C:\WINDOWS\system32\SETUPAPI.dll
0x621E0000 0x0000A000 C:\WINDOWS\system32\mciseq.dll
Called from EVENTPROCESS(6291) in source\h_windows.prg
Called from EVENTS(444) in source\h_windows.prg
Called from MAKELAYER(0)
y aquí como que se queda en un loop ya que sigue generando este mensaje
hasta que cancelo el programa.
Con la version 3.0.46 tambien me genera los "warning" pero si se ejecuta el programa.
Alguna idea ? Gracias.
Hello
I installed the 3.1.5 version and patch "HMG.3.1.5_patch2.rar", ran the "BuildAllLib.bat" and the generation
of the libraries, deployed about failed messages.
After I compiled my program, I deployed some messages "warning" and I created the executable,
but to run it, it freezes and does nothing.
This is what generates the build.log.
..... same as the above quote .....
and here as it stays in a loop as it continues to generate this message
until I cancel the program.
With version 3.0.46 I also generates the "warning" but if you run.
Any idea? Thank you.
Hola Andrés :
desde HMG.3.0.46 a HMG.3.1.5 hubo cambios en Harbour, este inconveniente no es propia de HMG, sino que cambiaron dentro de las funciones que te aparecen en el LOG que genera Build.bat
para saber leer el serial de un HD en linea de comandos D.O.S
para HMG/Harbour
Public cSerial := ""
Public nSerial := VolSerial( "C:" + HB_OSpathseparator() )
        Load Window Main
        Main.Center
	 cSerial:=NumToHex( nSerial )
   cSerial:=Stuff(cSerial,5,0,"-")
   Main.Text_1.value := cSerial
        Main.Activate
vol 2.png (10.51 KiB) Viewed 4134 times
