ON MOUSEDRAG ?
ON MOUSEDRAG ?
Hola a todos
Como puedo saber cuando se mueve de lugar una ventana ?
Probé con "ON MOUSEDRAG" pero no ejecuta mi funcion. Algun ejemplo ?
Hello everyone
As I can know when moving from place a window?
I tried "ON MOUSEDRAG" but does not execute my function. Some example?
Hello everyone
ON MOUSEDRAG ?
Hola Andrés,
Fijate si este ejemplo te ayuda a resolver. Try this: Message re-edited to attached mouse pointers files and for second time to include source code file (was missing, sorry).
ON MOUSEDRAG ?
Disculpame. La solucion que presenté, creo que no resuelve tu caso.
Sorry. This example which I had presented, will not solve your case.
- esgici
Re: ON MOUSEDRAG ?
I'm not sure that I have understood correctandyglezl wrote: As I can know when moving from place a window?
I hope attached sample will help you
Happy HMG'ing
Viva INTERNATIONAL HMG
- srvet_claudio
Re: ON MOUSEDRAG ?
See this code:andyglezl wrote:Hola a todos
Hello everyone
WIDTH 640 ;
HEIGHT 480 ;
TITLE 'Move Window' ;
@ 100 , 10 LABEL Label_X VALUE "" AUTOSIZE
@ 150 , 10 LABEL Label_Y VALUE "" AUTOSIZE
CENTER WINDOW Form_1
#define WM_MOVE 3
CREATE EVENT PROCNAME MoveTest() HWND Form_1.HANDLE MSG WM_MOVE
FUNCTION MoveTest()
LOCAL xPos := LOWORD(EventlParam())
LOCAL yPos := HIWORD(EventlParam())
Form_1.Label_X.Value := "X = " + HB_NTOS(xPos)
Form_1.Label_Y.Value := "Y = " + HB_NTOS(yPos)
- esgici
Re: ON MOUSEDRAG ?
Apparently, we need ON MOVE eventsrvet_claudio wrote: ...
See this code:
Viva HMG
ON MOUSEDRAG ?
Very Good Doctor !!srvet_claudio wrote:See this code:
#define WM_MOVE 3
FUNCTION MoveTest()
So the code I posted could be improved like this:
#define HTCAPTION 2
#define WM_MOVE 3
#define WM_NCLBUTTONDOWN 161
WIDTH 400 ;
HEIGHT 200 ;
TITLE 'Hello World!' ;
MAIN ;
ON MOUSECLICK MoveActiveWindow()
DEFINE STATUSBAR
STATUSITEM "Click on Form and holding mouse's button for moving this window"
END STATUSBAR
DEFINE LABEL Label_1
ROW 100
COL 10
VALUE ""
END LABEL
// Form_1.Cursor := "hand32-32.cur"
Form_1.Cursor := "Move-32.cur"
Function MoveActiveWindow( hWnd )
DEFAULT hWnd := GetActiveWindow()
PostMessage( hWnd, WM_NCLBUTTONDOWN, HTCAPTION, 0 )
// FileCursor( "Grabbed32-32.cur" )
FileCursor( "Maggy.ani" )
Function MoveTest()
Local xPos := LOWORD(EventlParam())
Local yPos := HIWORD(EventlParam())
Form_1.Label_1.Value:="Lin: "+Str(yPos,3,0)+" / Col: "+Str(xPos,3,0)
#pragma BEGINDUMP
#include <windows.h>
HB_FUNC( FILECURSOR )
hb_retnl( ( LONG ) SetCursor( LoadCursorFromFile( hb_parc( 1 ) ) ) );
#pragma ENDDUMPHMGing a better world
ON MOUSEDRAG ?
Hereunder is some cursor pointers, one is animated cursor pointer.
I hope you enjoy ! (Sorry I couldn't resist it...)
Re: ON MOUSEDRAG ?
Gracias Pablo César, esgici y Claudio
Revisé los ejemplos que enviaron e hice esto.
La idea que traigo es crear 2 ventanas, y que al mover la ventana 'Main',
la ventana 'Child' se acople a un lado de la 'Main'.
El siguiente código ya lo hace, hay que mover la ventana MAIN y darle click,
la ventana CHILD se ubicara a un lado de la MAIN. Lo que quiero es que
automaticamente la ventana CHILD se "acople" al deja de pulsar el botón del
ratón.
Thanks Pablo Cesar, Esgici and Claudio
I checked the examples sent and made this.
The idea is to create 2 windows bring, and that moving the window 'Main'
window 'Child' engages a side of the 'Main'.
The following code already does, you have to move the MAIN window and give click,
CHILD window was located on one side of the MAIN. What I want is that
CHILD window is automatically "attach" to stop pressing the button
mouse.
ratón.
mouse.
#define HTCAPTION 2
#define WM_MOVE 3
DEFINE WINDOW Form_1 AT 0,0 WIDTH 400 HEIGHT 600 TITLE 'Hello World!' MAIN ;
ON MOUSECLICK MoveActiveWindow() ;
ON INIT ( CreaChild( GetFormHandle('Form_1') ), MoveActiveWindow( hWnd ) )
DEFINE STATUSBAR
END STATUSBAR
FUNCTION CreaChild()
Local xPos := Form_1.Row
Local yPos := Form_1.Col
Local nWidth := Form_1.Width
DEFINE WINDOW Form_2 AT xPos,yPos+nWidth WIDTH 300 HEIGHT 200 TITLE 'WinChild' CHILD
DEFINE STATUSBAR
STATUSITEM "This window CHILD will be 'anchored' to the MAIN ..."
END STATUSBAR
ACTIVATE WINDOW Form_2
RETURN Nil
Form_1.StatusBar.Item(1):="Lin: "+Str(yPos,3,0)+" / Col: "+Str(xPos,3,0)
Form_2.Row:=xPos
Form_2.Col:=yPos+nWidth
- WinAcople.png (388.85 KiB) Viewed 11053 times
