One more Parameter in Getfile()
I think it would be very useful to set an extra parameter in the function getfile() for the file(s) view in the predefined folder? i.e. 1,2,3,4,5,6 where 1=Details, 2=List, 3=Icons, 4= Tiles, 5=Thumbnails, 6=Filmstrip. This way it wouldn’t be necessary to change this setting from the view menu.
It would make it a lot easier if someone (like my): would like to choose one or more images at once (if you do not know the name of the file...)
Nikos
Nikos
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
Re: One more Parameter in Getfile()
It would make it a lot easier if someone (like my): would like to choose one or more images at once (OR if you do not know the name of the IMAGE file...)
Best Regards,
Nikos.
Nikos.
- esgici
I guess acFilter parameter of GetFile() function may meets your need ( at least a portion )quartz565 wrote: I think it would be very useful to set an extra parameter in the function getfile() for the file(s) view in the predefined folder? i.e. 1,2,3,4,5,6 where 1=Details, 2=List, 3=Icons, 4= Tiles, 5=Thumbnails, 6=Filmstrip. This way it wouldn’t be necessary to change this setting from the view menu.
Happy HMG'ing
Viva INTERNATIONAL HMG
That’s a very useful utility indeed Esgici. Thanks!
What I mean though is:
When we open a folder by using the getfile() command, in that window the listing of the files is always in “List” view so only the names of the files appear. So if you’d want to have a quick look at some images for example you have to go at the view menu and change it to “Thumbnails”. What I’m trying to find out is if there is an option that can be set to the getfile() command as a parameter which could do that and open the window in “Thumbnails” view.
- DIR_VIEW.png (117.06 KiB) Viewed 5271 times
Best Regards,
Nikos.
Nikos.
- esgici
As far as know, GetFile() function of HMG calls GetOpenFileName() of Windows API.quartz565 wrote: What I mean though is:
So, "List View" is normal behavior of Windows.
"View menu" and other views are features of Windows Explorer, not sub-functions.
Maybe an expert would develop a solution for your request.
Anyway you would think develop your own GetFile() function.
When done please share with us.
Happy HMG'ing
Hi Nikos !
It would be good to have something like this:
or something like this:
But you can do it by yourself, creating a windows, selecting path, showing pictures and multiselecting of files. All depends of your imagination and criativity.
Thanks Esgici,Pablo.
I will try...
Nikos
I will try...
Nikos
Best Regards,
Nikos.
Nikos.
- srvet_claudio
Hi Nikos.quartz565 wrote:Hi,
Nikos
In function C_GETFILE (file C:\hmg.3.1.5\SOURCE\c_dialogs.c, line 196) change:
int flags = OFN_FILEMUSTEXIST;Code: Select all
int flags = OFN_FILEMUSTEXIST | OFN_EXPLORER;Best regards,
Claudio.
PS: see picture
- Captura_GetFile.png (203.87 KiB) Viewed 5170 times
- esgici
I can't believesrvet_claudio wrote: In function C_GETFILE (file C:\hmg.3.1.5\SOURCE\c_dialogs.c, line 196) change:for:Code: Select all
int flags = OFN_FILEMUSTEXIST;and rebuild-lib.Code: Select all
Can't be simple as that
Viva HMG, viva Dr. Soto
- esgici
I couldn't rebuildsrvet_claudio wrote:...
and rebuild-lib.
Will we hope a new release ?
Best regards
