HFCL (Hmg Forum Component Library)
Source code related resources
HFCL
As guided by Roberto I had created the first version of HFCL.
It has the following directory structure:
hfcl -> include,samples. The root directory consists the prg files, make file and a batch file.
1. Unzip the contents to c:\hmg.
2. Under c:\hmg\hfcl directory run makehfcl.bat
3. In HMG-IDE, select tools->preferences
4. Add in additional libraries 'hfcl' without quotes.
5. Add in additional include paths 'c:\hmg\hfcl\include' without quotes.
That's all and enjoy running the samples under samples directory.
Kindly test and give your comments.
hfcl.zip
HMG Forum Component Library (Initial Test Version)
(18.68 KiB) Downloaded 418 times
Re: Incremental Search with Combo Box
I had changed autofill considerably here.
Kindly test that too when you have time.
rathinagiri wrote: As guided by Roberto I had created the first version of HFCL.
Hi Rathi
How speedy you are :!:
Don't you care to short-winded olds, like me :?:
Out of joke, your works is perfect as always.
Installed and tested, everything is okay.
Thank you very much with hopefulness of this will be a happy beginning.
Thanks for your report Esgici.
rathinagiri wrote: hfcl -> include,samples. The root directory consists the prg files, make file and a batch file.
Thanks!
Roberto.
rathinagiri wrote:I had changed autofill considerably here.
Ok.
I'll do it ASAP!
Roberto.
I've tested. Its a great job.
IMHO it should be included in HFCL too..
And maybe, we should have a place to find the last hfcl version to download or to upload an updated version. Is that possible?
Roberto.
Re: HFCL (Hmg Forum Component Library)
And introducing HFCL documentation ... :)
esgici wrote:And introducing HFCL documentation ... :)
any volunteers? :)
Roberto.
Roberto.
Yes. It is possible. We can give the download link in the front page itself. The file can be put in the root directory of our forum to download.
Regarding uploading an updated version, it can be done in this thread. Once, it is approved, we can bring that to the root directory of the forum.
What is your opinion?
