HMG 3.1.5
Re: HMG 3.1.5 (Test)
mol wrote:Thanks Claudio for your work!
Could you point changes in IDE? We would take a closer look to test it....
The improvements are small:
- Changing the language at runtime
- Language files with different extension (.ASN and .UNI)
- All names of files language are in English
- Show compiler version of HMG
- Show the path of the open project
- Display the contents of BUILD.LOG file
- Different icons and splash screen (red and blue)
- Version of the IDE with numbers
The IDE has had several versions since birth (identified with dates).
What do you consider should be appropriate the number of this version :?:
1.0.3 is an appropriate number :?:
Thanks.
Pablo César wrote: 4. In Tools/Preferences at module Editor option.
Since we are walking to the disassociation of the Notepad++ installed files under HMG installations and let user define his own preferred editor. I suggest that the initial value of editor_field comes after a routine (which I can contribute) to detect which is the default editor used by the user. If no found of any association with the PRG extension file (by checking at Windows registry), should be displayed as "<Not defined>" and also under displayed the Notepad++ link for installation. This will allow the sources editor shall be installed in a conventional way and not in HMG installation sub-folders.
Please Pablo, post the routine that implements this idea.
srvet_claudio wrote:...The improvements are small:...
Maybe small for developer, definitely great for users;
thank a lot :)
Viva HMG :D
mol wrote:I'm trying to build form with new Unicode IDE and I got good work while project time and bad while working...
Hi Marek
Your code page is SET CODEPAGE TO UNICODE :?:
You compiled HMG library with the UNICODE option :?:
I'm afreaid I've mixed unicode and ansi.
By the way, I don't need unicode.
It's too much work and too few time to translate my huge project from ansi to unicode at this time...
Sure !
Here it is:
Local cEditor:=CheckExt("prg")
Local cNPP:=""
If Empty(cEditor)
   cNPP:=IsNotepadPlusPlus()
   If !Empty(cNPP)
      If MsgYesNo("Do you want to set Notepad++ as source default editor ?","Notepad++ is already installed")
	     cEditor:=cNPP
	  Endif
   Endif
Endif
If Empty(cEditor)
   MsgStop("Source editor <Not installed> !")
Else
   MsgInfo(cEditor,"Editor for prg files")
Endif
Function CheckExt(cExt)
Local cRet, nIni, nFin
cRet := RegistryRead("HKEY_CLASSES_ROOT\."+cExt+"\")
If cRet=Nil
   cRet:=""
Else
   If !(":\" $ cRet)
      cRet := RegistryRead("HKEY_CLASSES_ROOT\"+cRet+"\shell\open\command\")
   Endif
Endif
If ":\" $ cRet
   nIni:=HB_UAt('"',cRet)
   nFin:=HB_UAt('"',HB_USubStr(cRet,nIni+1),2)
   cRet:=HB_USubStr(cRet,nIni+1,nFin-1)
   If !File(cRet)
	   cRet:=""
   Endif
Endif
Return cRet
Function IsNotepadPlusPlus()
Local cRet:=""
cRet := RegistryRead("HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Notepad++\UninstallString")
If !Empty(cRet)
   If File(cRet)
      cRet:=HB_USubStr(cRet,1,HB_UAt("\UNINSTALL.EXE",HMG_Upper(cRet)))+"notepad++.exe"
	  If !File(cRet)
	     cRet:=""
	  Endif
   Else
      cRet:=""
   Endif
Endif
Return cRet
It is in xBase. You can change CheckExt("prg") by other extension file, just to make a test if Notepad++ is installed as regular installation or not. I hope you find it useful.
Pablo César wrote:It is in xBase. You can change CheckExt("prg") by other extension file, just to make a test if Notepad++ is installed as regular installation or not. I hope you find it useful.
Thanks
Hello Friends,
they think of these questions:
srvet_claudio wrote:The IDE has had several versions since birth (identified with dates).
What do you consider should be appropriate the number of this version? :?:
1.0.3 is an appropriate number? :?:
Thanks.
The version 1.0.3 does not give a false impression that it is a new IDE ?
Please give me your opinion.
srvet_claudio wrote:Hello Friends,
Thanks.
ohh sorry I forgot to give my opinion about.
IMO, I think every tool and applications should have the version number. And do not think that is a problem to be different version IDE and HMG release package, however it is important for reference anyway.
Pablo :
subo una imagen que comprueba los resultados del codigo que publico hace un rato.
2013-08-26 21_08_59-Editor for prg files.png (20.33 KiB) Viewed 5626 times
