Notepad++ Language Help (HMG / Harbour)
We can add a HMG.chm and also Harbour.chm options of help accessing by ContextMenu of Notepad++, as shows image below:
First at all we have to unpack these files (are not updated, whom have more actualized, please let us know) into a xBase folder on your hard disk.
xBase.rar
(506.41 KiB) Downloaded 2299 times
Second, check up yours plugins installation of your Notepad++ going by Plugins menu/Plugin Manager/Show Plupgin Manager/Installed tab if "Language Help" is already installed, in case not: go to "Availabe" tab and then install it.
Third, you will need to add chm files and setting up "Language Help" plugin, going to:
Fourth, you will need to add it as follows:
And setup it as follows:
Fifth, close and restart you Notepad++ and then you be able to use it, clicking with right mouse button on the any HMG or Harbour command and you can choose HMG or Harbour to see sintaxe with already word passed as argument for chm file (see first image of this message) and the result will be the followng one:
I hope to be enjoy it ! :)
Re: Notepad++ Language Help (HMG / Harbour)
Thank you for valuable hint
Your wellcome, my friend !
You can also access the help of HMG (if first resgistered is HMG) by pressing Ctrl + F1 and also by button Image on menu.
Pablo César wrote: You can also access the help of HMG (if first resgistered is HMG) by pressing Ctrl + F1 and also by button Image on menu.
Hi Pablo
Thank to your valuables hints and help on NotePad++ ( and on all subjects of course ) :)
[u]Moderator Notes[/u] (Pablo César) wrote:This message was re-edited in order to split topic and separate matters in another existing topic.
Chm files in Windows 7 and newest it is having restrictions. So it can be changed by pdf files. ;)
Tiger
Post by Tiger »
Hi Pablo,
I follow your instruction to creat a new CHM file that included HMG, Harbour and Clipper tools.
Sorry the size of file is very huge ... ;)
HMG_DOC.7z
(7.34 MiB) Downloaded 1068 times
Thanks Tiger !
apais
Post by apais »
Very good compilation Tiger !
Angel Pais
Wow! Thanks man!
Steed
Post by Steed »
thanks
