hmg 3.1.5 erro window statup
jairpinho
Post by jairpinho »
My application was working until version 3.1.4 of hmg this now with this error on startup.
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Amarante
DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL
Re: hmg 3.1.5 erro window statup
Post by Amarante »
Jair, você fez a alteração na h_windows.prg?
veja o post http://hmgforum.com/viewtopic.php?p=28100#p28100" onclick="window.open(this.href);return false;
Oi Jair, você já executou esta correção ?
Hi Jair, you have already performed this fix?
A minha resposta estava sendo editada enquanto você Amarante tinha postado. De qualquer forma ambos servem com o mesmo propósito. ;)
My response was being edited as you had posted Amarante. Anyhow both serve the same purpose. ;)
emzampi
Post by emzampi »
My name is Emanuele and I live in Italy, I admire and use (as an amateur) your project that revives the clipper. Thank you for this vs. job.
That said excuse me for English, and I think you point out an anomaly that reflected in the inputbox command riscontrbile also examples of hmg 3.1.5 /
samples / function / inputbox / demo. In essence inputbox does not wait for input and in my program this error:
-Date :11-08-2013 Time: 10:47:21
Error: HMG 3.1.5 (31/07/2013)
Not Modal WIndows can not be activated When a modal window is active. graph_66 Program Terminated
Called from _ACTIVATEWINDOW (5187)
Called from MESS (574)
Called from (b) MAIN (147)
Called from _DOCONTROLEVENTPROCEDURE (5545)
Called from EVENTS (1562)
Called from _DOMESSAGELOOP (0)
Called from _ACTIVATEWINDOW (5210)
Called from MAIN (240)
Earlier versions 3.1.4 hmg were OK also on the examples.
thanks
Emanuele
jairpinho
Post by jairpinho »
Amarante wrote:Jair, você fez a alteração na h_windows.prg?
veja o post http://hmgforum.com/viewtopic.php?p=28100#p28100" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Obrigado Pablo e Amarante deu certo agora falta imagens gif ou png em modo transparente, tambem deu um problema com operadores nesta versão com um programa ja estava funcionando o operador é >=
Thanks Pablo Amarante and it worked now missing gif or png images in transparent mode, also has a problem with operators in this version with a program was already running the operator is> =
Jair Pinho
