HMG_HPDF with pdf417?
paulomhouse
Hi
How can i make a report with HMG_HPDF with pdf417 codebar?
I don´t know how to use HMG_CreateBarCode, is it possible with ?
Thank you
Thank you
Re: HMG_HPDF with pdf417?
Definitely it is possible.
First create a barcode image file by giving the cImageFileName parameter to the HMG_CreateBarCode function. I will make a small sample soon.
paulomhouse
Could you show me a piece of this information?
Create a image -> HMG_CreateBarCode and insert it
Thank you
Thank you
Please try this!
Please try this!
#include "hfcl.ch"
define window barcode at 0, 0 width 400 height 100 title "Barcode PDF Sample" main
define label l1
row 10
col 10
width 100
value 'Enter Barcode'
end label
define textbox t1
row 10
col 110
width 100
end textbox
define button b1
row 10
col 220
caption 'Create PDF'
action createpdf()
end button
end window
barcode.center
barcode.activate
function createpdf
local cImage := 'barcode.png'
local nReturn := 0
local lSuccess := .f.
nReturn := HMG_CreateBarCode( barcode.t1.value,;
"PDF417",;
2,;
100,;
.f.,;
cImage )
if nReturn == 0
msgstop( 'Barcode Creation error!' )
return nil
if file( 'barcode.png' )
SELECT HPDFDOC 'HMG_barcode.pdf' TO lSuccess papersize HPDF_PAPER_A4
if lSuccess
START HPDFDOC
START HPDFPAGE
@ 10, 10 HPDFPRINT IMAGE "barcode.png" WIDTH 172 HEIGHT 78
END HPDFPAGE
END HPDFDOC
return nil
Thank you for working sample
It is hard coded to be PNG file format. But it can be any extension like jpg, bmp or whatever.
Just change the line appropriately at line no. 59 of \hfcl\source\hmg_zebra.prg
And, don't forget to re-create the library.
paulomhouse
Thanks a lot Rathinagiri
It is exacty I was waiting.
Now, I need to define papersize like HPDF_PAPER_USER, How can I do it? 4,00inX2,00in.
You can use the following sample for having user defined paper size. The sizes are in millimeters.
SELECT HPDFDOC "sample.pdf" PAPERLENGTH 300 PAPERWIDTH 300
