HMG 3.1.5. Variable Problem
radohabjan
Post by radohabjan »
Hello Friend,
I have big problem with variables in new version 3.1.5..
All variables in sub procedures are not defined (variable test), but variables in main procedure is OK. In 3.0.46 works perfect.
See the code:
PROCEDURE Main
SET LANGUAGE TO SLOVENIAN
REQUEST HB_CODEPAGE_SLWIN
HB_CDPSELECT("SLWIN")
test1="Q"
DEFINE WINDOW Win_1  AT 0,0 WIDTH 540 HEIGHT 460 MAIN
ON KEY ESCAPE ACTION Win_1.Release
 Define Button Button_4
 Row   300
 Col   80
 Caption 'Test'
 Action test()
 End Button
Win_1.Center
Win_1.Activate
procedure test
test="W"
DEFINE WINDOW Win_2  AT 0,0 WIDTH 540 HEIGHT 460 MODAL
ON KEY ESCAPE ACTION Win_2.Release
 Row   300
 Col   80
 Caption 'Test Variable'
 Action test1()
 End Button
Win_2.Center
Win_2.Activate
procedure test1()
msginfo(test1)
msginfo(test)
return
Variable test is not defined.
br Rado
I have tested your code and I also noted there are diferance in 3.0.46 and 3.1.4 with last version 3.1.5. I do not know if is Harbour behaviou or HMG. But if you try this:
PROCEDURE Main
/* SET LANGUAGE TO SLOVENIAN
HB_CDPSELECT("SLWIN") */
Public test1:="Q"
 Row   300
 Col   80
 Caption 'Test'
 Action test()
 End Button
Win_1.Center
Win_1.Activate
procedure test
Public test2:="W"
DEFINE WINDOW Win_2  AT 200,100 WIDTH 540 HEIGHT 460 MODAL
 Row   300
 Col   80
 Action test1()
 End Button
// Win_2.Center
Win_2.Activate
procedure test1()
msginfo(test1)
msginfo(test2)
return
Then it will work, but need to change private for public declaration of variables.
The strange is between versions 3.1.4 and 3.1.5 in this case.
Now with this patch, it is also working for your example ! :)
Amarante
DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL
Re: HMG 3.1.5. Variable Problem
Post by Amarante »
Português:
Depois que instalei a versão 3.1.5 passei a ter erros quando declaro parametros em uma função. :?
Estas variáveis declaradas como PARAMETERS devem ser reconhecidas como publicas por outras procedures no módulo, como está documentado no Clipper NG, mas não estão. :shock:
O mais estranho é que fiz alguns testes simples e funcionaram, mas quando compilo um programa que funciona bem na 3.1.4 o mesmo falha na 3.1.5. :cry:
Também notei comportamento estranho em janelas modal, por exemplo, em uma função rodando embaixo do 3.1.4 executo uma janela modal e logo após executo uma msginfo, quando rodo embaixo do 3.1.5 simplesmente após a janela modal a msginfo não funciona, simplesmente nada acontece. Estranho... Voltei para a 3.1.4 onde tudo está funcionando ok. :mrgreen:
Google Translator:
After I installed version 3.1.5 I started to have errors when I declare parameters in a function. :?
These variables declared PARAMETERS must be recognized as public by other procedures in the module, as documented in Clipper NG, but are not. :shock:
The strange thing is that I did some simple tests and worked, but when I compile a program that works well in 3.1.4 the same failure 3.1.5. :cry:
I also noticed strange behavior in modal windows, for example, a function running under the 3.1.4 run a modal window and after I perform a msginfo when road under the 3.1.5 just after the msginfo modal window does not work, simply nothing occurs. Strange ... I went back to 3.1.4 where everything is working ok. :mrgreen:
Amarante wrote:...
Please clarify, what "errors" you are about ?
Sorry, but it seems that you are wrong; please look at attached image captured from Clipper NG.
What kind will be variable declared by PARAMETER statement ?
...just after the msginfo modal window does not work, simply nothing occurs. Strange ... I went back to 3.1.4 where everything is working ok. :mrgreen:
Message problem may be related to this subject.
De fato Amarante, havia problemas com respeito as citações suas, pois a instrução do Dr. Soto de colocar como comentário a linha 49 do arquivo C:\hmg.3.1.5\SOURCE\h_windows.prg, então deixa-a assim:
// #define ALLOW_ONLY_ONE_MESSAGE_LOOP
Depois disso, grave o arquivo e execute o C:\hmg.3.1.5\BuildLib.bat. Recompile o programa e verifique se persistem os mesmos erros e relate pra gente aqui.
It is a fact Amarante, there were problems regarding your citations, as the instruction of Dr. Soto to put as a comment line 49 of file C:\hmg.3.1.5\SOURCE\h_windows.prg, then let it lije this:
// # define ALLOW_ONLY_ONE_MESSAGE_LOOP
After that, save the file and run the C:\hmg.3.1.5\ BuildLib.bat file. Recompile your program and check if it is contining with the same mismatches and report to us here.
Amarante
Post by Amarante »
esgici wrote:
Amarante wrote:...
Tonight (I'm in Brazil) will be publishing a job here in the forum (hopefully) that I think will be useful to all and where it may be clearer what is happening in 3.1.5, please wait.
My fault, where I wrote public read private
Amarante wrote:My fault, where I wrote public read private
Yeah Esgici is correct. But any way these problems seems is also affected by that patch of Dr. Soto, please try and revert.
Amarante
Post by Amarante »
Português:
Obrigado Pablo César, vou recompilar a h_windows.prg e testar.
Google Translate:
Thanks Pablo César, will recompile h_windows.prg and test.
This is the line of all the problems of HMG.3.1.5
This macro makes that HMG works as would a normal C program in Windows with a single loop of messages, but HMG is Clipper programming style not is C programming. I'll try to explain with a simple example:
PROCEDURE Main
PRIVATE var1 := 100
   DEFINE WINDOW Win_1  AT 0,0 WIDTH 300 HEIGHT 300 MAIN
      @ 50, 50 Button Button_1 Caption 'Test' Action test()
   Win_1.Center
   Win_1.Activate
PROCEDURE Test
PRIVATE var2 := 200
   MsgDispVar ("One")  ---> this work Ok
   DEFINE WINDOW Win_2  AT 0,30 WIDTH 200 HEIGHT 200 MODAL
      @ 50, 50 Button Button_1 Caption 'Test' Action MsgDispVar ("Tow")  //  ---> this not work with a single message loop
   Win_2.Center
   Win_2.Activate
PROCEDURE MsgDispVar (Title)
   MsgInfo (ListCalledFunctions (), Title)
   MsgDebug (var1, IF(TYPE("var2")<>"U", Var2, NIL))
With multiple loops message every time you activate a window, the program stop at that point and waiting for user response and thus simulates what would READ clause in Clipper when running on DOS.
With a single message loop the activate a window, not stop the execution of the program and the procedure continues.
In this case the Win_2.Activate is equivalent to Win_2.Show as in C.
Is for this razon that second call of MsgDispVar() not work well, because Test() procedure is finish and var2 not exist.
Compare the result of ListCalledFunctions() with a single and with a multiple message loop and see diference.
