HMG 3.1.5
Jairo Maia
Re: HMG 3.1.5 (Test)
Post by Jairo Maia »
Happy Birthday HMG Forum!
Thank you very much HMG Team for the new version. It was a GREAT GIFT for us.
Best Regards,
Congratulations!
Gracias a todos por el desarrollo y crecimiento de HMG.
Thank you all for the development and growth of HMG.
nelstu
Post by nelstu »
Gracias a todos!!!! slds Nelson Stuardo
fchirico
Post by fchirico »
Es increible... ya han pasado 6 años!
Gracias a todos, fundamentalmente a Roberto y Rathi, y luego a mucha gente que han aportado siempre (Esgici, Sudip, Mol, etc.) ya los de la nueva camada (por llamarlos de algún modo).
Quiero comentarles que desde hace 6 años no dejado un solo día de leer todas las noches este foro.
MUCHAS GRACIAS!
It's amazing ... it's been 6 years!
Thank you all, primarily to Roberto and Rathi, then many people who have contributed forever (Esgici, Sudip, Mol, etc..) And the new breed (to call it somehow).
I want to tell you that for the last six years not a single day longer read this forum every night.
THANK YOU!
Saludos, Fernando Chirico.
Pablo César wrote: Is it possible an example of these ?
- ANIMATE WINDOW cFormName MODE nFlags INTERVAL nMilliseconds
- ANIMATE WINDOW cFormName MODE nFlags (See Docs for various modes)
- New Read Keyboard Functions (like as HMG_GetLastVirtualKeyDown, HMG_GetLastVirtualKeyName, HMG_VirtualKeyIsPressed, GetKeyState, HMG_SendCharacter...)
- New Convert Unicode Value (like as HMG_GetUnicodeValue and MG_GetUnicodeCharacter)
You asked for it, now have fun :D
HMG_EVENT_MONITOR_1.0.3.rar
(7.91 KiB) Downloaded 586 times
Thank you Mr. claudio for your contribution to HMG
Great news!
I'm on the vacation now, but I'll test it after return!
Best regards!
HMG 3.1.5 (Test)
Thank you gentleman ! :D
I found nothing about "ANIMATE WINDOW" command throughout your code. :cry:
I was fascinated with your code and I would like to contribute with some changes that I believe will provide a better interface:
- I changed the position and size of each window, because depending on the screen resolution, it is difficult to interact.
- I put the the "Modal Window" in separate function, just for be called via a button.
- HMG_InstallEventMonitor was add a label with options.
- I changed the string from Tamil to Arabic because it is visible in some cases where Windows XP does not have support for Asian linguaguem (Case CueBanner).
- There is a problem when is focused on Button_1 and Button_2, MsgInfo is incorrect according Mouse Pointer be focused (see screen captured below):
Probably this mistake needs a different approaching for to be solved. :?
HMG 3.1.5 (Test)
I just forgot to attach the files with changes... :oops:
HMG_EVENT_MONITOR.rar
(8.06 KiB) Downloaded 385 times
quartz565
Post by quartz565 »
Thanks Rathi !!
  • - New in HFCL: HMG_Zebra Barcode Creation Function using hbzebra harbour contrib library and HFCL BosTaurus library. (Contributed by Dr. Claudio Soto and S. Rathinagiri)
    - HMG_CreateBarCode( cCode, cType, [nBarwidth], [nBarHeight], [lDisplayCode], [cPNGFileName], [aBarColor], [aBackColor], [lCheckSum], [lWide2_5], [lWide3] )
    - HMG_CreateBarCode() function can be used to create barcode image in png file format if cPNGFileName parameter is included. If cPNGFileName is omitted, the function returns the hBitMap handle of barcode.
    - Any one of the following Barcode types is allowed. { "EAN13","EAN8","UPCA","UPCE","CODE39","ITF","MSI","CODABAR","CODE93","CODE11","CODE128","PDF417","DATAMATRIX","QRCODE" }
    - Checkdigit will be generated by library if omitted.
Great news !!!
Nice upgrade
Nikos
Best Regards,
Nikos.
os: Windows Server 2019 - 64
