First topic, please help with little project
Re: First topic, please help with little project
dragancesu wrote:Now I have a problem with date, I've want date format like GERMAN type which should show date in dd.mm.yyyy but not so. Datepicker shows how it wants
How is it defined? Or to make the conversion date-string?
As far as I observe, Date Picker control don't obey project's date format settings. Most probably it use date format of system (OS, Windows).
I guess this may be confirmed by changing OS's regional settings.
This is screen shoot of <hmg>\SAMPLES\Controls\DatePicker\DATEPICKER\Demo.prg:
HMG DatePicker Demo screen shoot
HMG DatePicker Demo.JPG (12.27 KiB) Viewed 5077 times
Turkish national date format is : DD.MM.YYYY
Hi All
esgici wrote:...
Tried and confirmed;
When changed date format in OS ( Windows ) settings ( via Control Panel of Windows ),
date format of DatePicker control of HMG too changed according the system setting.
TIA :D
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
Thanks for your reply, I tried and saw datepicker shows the date as defined in the contol panel
For years I use clipper and I was surprised that a set date is not responding, now it's all clear, but I think it would be reported, perhaps as a bug
dragancesu wrote:... but I think it would be reported, perhaps as a bug
This isn't a bug, but a feature :arrow:
As the developer, you haven't need to struggle about date format of your users;
whatsoever date format of your users, your application run with true format depending on user's system setting;
if user want change date format in your application, it will be sufficient changing system setting, without
turn to you 8-)
What more do you want?
HMG is superb :D
tonton2
Post by tonton2 »
good evening
when I want to delete a record in your example (client.rar), I receive this message
how to remedy please
Procedure SUPRIMER()
		  If MsgYesNo ( 'Vous étes Sur de vouloir Supprimer ce Client')
			If Client->(FLock())
			  Delete
			   Win_1.Browse_1.Delete
			   Win_1.Browse_1.EnableUpdate()
			   Win_1.Browse_1.Refresh
			  Unlock
		  EndIf
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Salam Aleyk Tabet
Please look at here, I hope will be useful :)
maassalam
tonton2
Post by tonton2 »
Bonsoir tout le monde
Mon probleme est que lorsque j'utilise une variable interne a la procedure voir example c'est ok mais quand j'utilise une variable ,appelée de l'exterieur ca me donne l'erreur suivante.
grand merci a tous et en particulier a mr Esgici
Hello everyone
My problem is that when I use an internal variable to the procedure see example is ok but when I use a variable called from outside it gives me the following error.
big thank you to everyone and especially to mr Esgici
brow1.rar
(823.25 KiB) Downloaded 298 times
notUnderstand.rar
(823.42 KiB) Downloaded 315 times
Y.TABET
