EditBox control: increase capacity
Re: EditBox control: increase capacity
Hi all.
The final solution is more simpler than what I said in the previous post.
In source file: c_windows.c you change the original GETWINDOWTEXT function for this function:
HB_FUNC ( GETWINDOWTEXT )
   int iLen = GetWindowTextLength((HWND) hb_parnl (1));
   TCHAR *cText = (TCHAR*) hb_xgrab((iLen+1) * sizeof(TCHAR));
   GetWindowText((HWND) hb_parnl (1), (LPTSTR) cText, (iLen+1));
   HMG_retc( cText );
   hb_xfree( cText );
and re-build the library.
Thank you Dr. Soto ! Working properly.
GETWINDOWTEXT function shorter and better !
I will announce in the other forum your patch for fix and for next releases. Many tks
Carlos Britos
Post by Carlos Britos »
Hi Claudio
I found a couple of problems in the editbox.
With increasing text size caretPos not return the real value.
The overwrite mode is not working.
Everything seems to be related to EM_GETSEL (32 bit). I don't have it very clear.
I don't know how to increase the limit of EM_GETSEL.
It wasn't tested yet with your last function.
Lamento no poder ayudar
Carlos Britos wrote:Hi Claudio
Carlos thanks for reporting this bug.
In source file: h_controlmisc.prg you change the original _GetCaretPos function for this function:
Function _GetCaretPos ( ControlName , FormName )
Local i, nStart, nEnd
   i := GetControlIndex ( ControlName, FormName )
   If i == 0
      Return 0
   EndIf
   HMG_SendMessage ( _HMG_SYSDATA [3] [i] , EM_GETSEL, @nStart, @nEnd )
Return nEnd
In source file: c_windows.c your add this function:
HB_FUNC (HMG_SENDMESSAGE)
{  HWND hWnd   = (HWND) hb_parnl(1);
   UINT nMsg   = (UINT) hb_parnl(2);
   LONG wParam = (LONG) hb_parnl(3);
   LONG lParam = (LONG) hb_parnl(4);
   LONG lResult;
   lResult = (LONG) SendMessage (hWnd, nMsg, (WPARAM) &wParam, (LPARAM) &lParam);
   hb_retnl ((LONG) lResult);
   if (HB_ISBYREF(3))
       hb_stornl ((LONG) wParam, 3);
   if (HB_ISBYREF(4))
       hb_stornl ((LONG) lParam, 4);
Best Regards,
Claudio
Hi Claudio,
changes were made and rebuilded LIB, but overwrite mode is still not working. :(
Pablo César wrote:but overwrite mode is still not working. :(
Sorry Pablo, but I not understand what you said.
Me refiero que cuando editamos dentro del EditBox, mismo que presionemos la tecla insert, no difiere el comportamiento entre sobre-escribir um texto ya existe y el modo de insercion de texto. Para que puedas entender mejor Claudio, fijate en este link (ejecutable y fuentes):
How do I introduce insert/overwrite mode in edit control ?
Carlos Britos wrote:The overwrite mode is not working.
Creo que esto nunca funcionó en el EditBox de HMG. Solo vuelvo a exponer lo que Carlos se referia. Seria importante como nueva implementacion y no como correccion.
I mean that when you edit within the EditBox, even we press the insert key, no different behavior between um overwrite text already exists and the text insertion mode. So you can better understand Claudio and notice in this link (executable and source)
I think this never worked in the EditBox HMG. Just back to expose what Carlos was referring. It would be important as a new implementation and not as correction of it.
Pablo César wrote:I think this never worked in the EditBox HMG. Just back to expose what Carlos was referring. It would be important as a new implementation and not as correction of it.
Ok now I understand, the problem is that EditBox control does not support these functions, you must be implemented to "lung".
Carlos Britos
Best Regards,
Claudio
Hi Claudio
This code works ok, thanks Maestro.
Carlos Britos
Hi
Can anyone test this code?
 * Copyright 2010 Roberto Lopez <mail.box.hmg@gmail.com>
 * http://www.hmgforum.com//
		WIDTH 640 HEIGHT 480 ;
		TITLE 'HMG Demo' ;
		ICON 'DEMO.ICO' ;
		@ 30,10 EDITBOX Edit_1 ;
			WIDTH 410 ;
			HEIGHT 140 ;
         VALUE 'EditBox!!'
      SendMessage (GetControlHandle("Edit_1","Form_1"), 197, 0, 0 )
		DEFINE BUTTON D
			ROW	250
			COL	290
			WIDTH	130
         CAPTION  '_GetCaretPos'
         ACTION   msginfo( hb_NtoS( _GetCaretPos( "Edit_1", "Form_1" ) ) )
		END BUTTON
	Form_1.Center()
	Form_1.Activate()
   If i == 0
      Return 0
   EndIf
   HMG_SendMessage ( _HMG_SYSDATA [3] [i] , 176, @nStart, @nEnd )
Return nEnd
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
   LONG lResult;
   if (HB_ISBYREF(3))
   if (HB_ISBYREF(4))
#include "HMG_UNICODE.h"
#define _WIN32_IE      0x0500
#define HB_OS_WIN_32_USED
#include <shlobj.h>
#include <commctrl.h>
#include "hbapi.h"
#include "hbvm.h"
#include "hbstack.h"
#include "hbapiitm.h"
#include "winreg.h"
#include "tchar.h"
LRESULT APIENTRY SubClassFunc( HWND hwnd, UINT uMsg, WPARAM wParam, LPARAM lParam );
static WNDPROC lpfnOldWndProc;
HB_FUNC( INITEDITBOX )
   HWND hwnd;
   HWND hbutton;
   int Style ;
   hwnd = (HWND) hb_parnl (1);
   Style = ES_MULTILINE | ES_WANTRETURN | WS_CHILD ;
   if ( hb_parl (10) )
      Style = Style | ES_READONLY ;
   if ( ! hb_parl (11) )
      Style = Style | WS_VISIBLE ;
   if ( ! hb_parl (12) )
      Style = Style | WS_TABSTOP ;
   if ( ! hb_parl (13) )
      Style = Style | WS_VSCROLL  ;
      Style = Style | ES_AUTOVSCROLL ;
   if ( ! hb_parl (14) )
      Style = Style | WS_HSCROLL ;
   hbutton = CreateWindowEx( WS_EX_CLIENTEDGE, _TEXT("EDIT"), _TEXT(""),
   Style ,
   hb_parni(3), hb_parni(4) , hb_parni(5), hb_parni(6) ,
   hwnd,(HMENU)hb_parni(2) , GetModuleHandle(NULL) , NULL ) ;
   SendMessage ( hbutton , (UINT)EM_LIMITTEXT ,(WPARAM) hb_parni(9) , (LPARAM) 0 ) ;
   lpfnOldWndProc = (WNDPROC) SetWindowLong( (HWND) hbutton, GWL_WNDPROC, (LONG) SubClassFunc);
   hb_retnl ( (LONG) hbutton );
LRESULT APIENTRY SubClassFunc( HWND hWnd, UINT msg, WPARAM wParam, LPARAM lParam )
   switch( msg )
      case WM_CHAR:                               //
         if ( ( ! GetKeyState( VK_INSERT ) == 0 ) && ( wParam != VK_RETURN ) && ( wParam != VK_BACK ) )
            SendMessage( hWnd, WM_KEYDOWN, VK_DELETE, 0 ) ;
         break;
      return CallWindowProc( lpfnOldWndProc, hWnd, 0, 0, 0 ) ;
   return CallWindowProc( lpfnOldWndProc, hWnd, msg, wParam, lParam ) ;
#pragma ENDDUMP
