HMG 3.1.4
Carlos Britos
Re: HMG 3.1.4 (Test)
Post by Carlos Britos »
Hi.
the below attachments, capture and exe are on Xp.
The exe is not an HMG code but the related function SetCuebanner() is Almost identical. The exe is just to show the behaviour. The exe wwas compiled with harboour 3.2 and bcc but is the same with MinGW. Unicode and Ansi.
capture in XP
capture in XP
cue.zip
exetest
(1.07 MiB) Downloaded 278 times
HMG 3.1.4 (Test)
Hi Carlos, thank you for your patience and contribution. But your exe here in WinXP SP2 lamentably not working...
Shall be SP2/SP3 the problem ?
In Win7 is working perfectly.
Carlos Britos
Pablo César wrote: Shall be SP2/SP3 the problem ?
Maybe I have sp3
HMG 3.1.4 (Test)
And for Spinner and ComboBox did not worked in HMG (even in Win7) and also not for EDITBOX, RICHEDITBOX (these last two, you said already not working).
HMG 3.1.4 (Test)
Rathinagiri wrote:CueBanner is supported in XP as declared in MSDN here.
And as the MSDN suggests,
"Note To use this API, you must provide a manifest specifying Comclt32.dll version 6.0. For more information on manifests, see Enabling Visual Styles."
We have a manifest file in HMG Resource path. But how to enable!?
Yes Rathi, I also have found this... but I still do not understanding. I guess something in C:\hmg.3.1.4\MINGW\include\commctrl.h where COMCTL32_VERSION is declare to 5 or 6... but this is in MINIGW.
Carlos Britos
Pablo César wrote:And for Spinner and ComboBox did not worked in HMG (even in Win7) and also not for EDITBOX, RICHEDITBOX (these last two, you said already not working).
Remember combobox and spinner are specials controls, two or more in one.
The combobox has listbox + textbox or label and spinner has updown + textbox.
To set the cuebanner you need the handle of the edit part. The textbox of combobox or spinner.
HMG 3.1.4 (Test)
Carlos Britos wrote:Remember combobox and spinner are specials controls, two or more in one.
Ahhh yes, you are right. I do not know how to do it, I will continue searching...
Define window Form_1 at 0, 0 width 400 height 300 main Title "Demo2 - Carlos example"
	DEFINE TEXTBOX Text_1
        ROW    10
        COL    10
        WIDTH  200
    END TEXTBOX
    DEFINE TEXTBOX Text_2
        ROW    40
        COL    10
        WIDTH  200
    END TEXTBOX
    DEFINE EDITBOX Edit_1
        ROW    10
        COL    230
        WIDTH  120
        HEIGHT 110
        VALUE ""
    END EDITBOX
    DEFINE COMBOBOX Combo_1
        ROW    70
        COL    10
        WIDTH  200
        HEIGHT 100
        ITEMS {"Item 1","Item 2","Item 3"}
        VALUE 0
    END COMBOBOX
    DEFINE SPINNER Spinner_1
        ROW    100
        COL    10
        WIDTH  200
        HEIGHT 24
        RANGEMIN 1
        RANGEMAX 10
        VALUE 0
    END SPINNER
    DEFINE RICHEDITBOX RichEdit_1
        ROW    130
        COL    230
        WIDTH  120
        HEIGHT 90
        VALUE ""
    END RICHEDITBOX
End window
SetTextBoxCueBanner("Form_1","Text_1","Enter your name here")
SetTextBoxCueBanner("Form_1","Text_2","Enter address here")
SetTextBoxCueBanner("Form_1","Spinner_1","Spinner CueBanner")
SetTextBoxCueBanner("Form_1","Combo_1","ComboBox CueBanner")
SetTextBoxCueBanner("Form_1","Edit_1","EditBox CueBanner")
SetTextBoxCueBanner("Form_1","RichEdit_1","RichEditBox CueBanner")
Form_1.center
Form_1.activate
Function SetTextBoxCueBanner(cParent,cControl,cText)
Local nHandle := GetControlHandle(cControl,cParent)
Setcuebanner(nHandle,cText,.t.) // Third parameter is for not dissapear when getfocus
#pragma BEGINDUMP
#define COMPILE_HMG_UNICODE
#include <HMG_UNICODE.h>
#include <windows.h>
#include <commctrl.h>
#define ECM_FIRST         0x1500          // Edit control messages
#define EM_SETCUEBANNER  (ECM_FIRST + 1)  // Set the cue banner with the lParm = LPCWSTR
HB_FUNC( SETCUEBANNER )                    // (editHandle, cMsg) -> nil
   #ifdef UNICODE
      LPWSTR lpWCStr = HMG_parc(2) ;
   #else
      LPWSTR lpWCStr = (LPCWSTR) ( hb_parc(2) == NULL ) ? NULL : hb_mbtowc( (const char *) hb_parc(2) ) ;
   #endif
   SendMessage( (HWND) hb_parnl(1), EM_SETCUEBANNER, (WPARAM) hb_parl(3), (LPARAM) (LPCWSTR) lpWCStr ) ;
   SysFreeString( lpWCStr );
#pragma ENDDUMP
May you try to correct this code for us ?
Probably for EditBox and RichEditBox would exist a way for do it too...
Carlos Britos
Please try with code
Note that:
in spinner GetControlHandle() return an array. So SetTextBoxCueBanner() need a trick to work.
in combobox I'm using FindWindowEx( GetControlHandle( "Combo_1", "Form_1" ), 0, "Edit", Nil ) to get the handle of textbox.
Probably, I'd tried time ago but with no luck, sorry.
        ROW    10
        COL    10
        WIDTH  200
    END TEXTBOX
        ROW    40
        COL    10
        WIDTH  200
    END TEXTBOX
        ROW    10
        COL    230
        WIDTH  120
        HEIGHT 110
        VALUE ""
    END EDITBOX
        ROW    70
        COL    10
        WIDTH  200
        HEIGHT 100
        VALUE 0
        DISPLAYEDIT .T.      // must be .T. for cuebanner
    END COMBOBOX
        ROW    100
        COL    10
        WIDTH  200
        HEIGHT 24
        RANGEMIN 1
        RANGEMAX 10
        VALUE 0
    END SPINNER
        ROW    130
        COL    230
        WIDTH  120
        HEIGHT 90
        VALUE ""
    END RICHEDITBOX
End window
// SetTextBoxCueBanner("Form_1","Spinner_1","Spinner CueBanner")
// SetTextBoxCueBanner("Form_1","Combo_1","ComboBox CueBanner")
Setcuebanner(FindWindowEx( GetControlHandle( "Combo_1", "Form_1" ), 0, "Edit", Nil ),"ComboBox CueBanner",.f.)
Setcuebanner( GetControlHandle( "Spinner_1", "Form_1" )[1],"Spinner CueBanner",.f.)
Form_1.center
Form_1.activate
Setcuebanner(nHandle,cText,.f.)
#pragma BEGINDUMP
   #ifdef UNICODE
   #else
   #endif
#pragma ENDDUMP
Carlos Britos
Hi Pablo
En MSDN I saw this comment:
wParam option note
wParam TRUE - only appears to work on Vista.
Under XP the cue text always disappears when the control gets focus regardless of this parameter.
Stanley Roark
4/13/2009
Can you try if this is true for us ?
Maybe is the problem with sp2
Hi boys,
this is how to get all handles of a control:
hControl := GetControlHandle (cControlName, cParentName)
IF Valtype (hControl) == "A"
    FOR i = 1 TO LEN(hControl)
        ControlHandle := hControl [i]
        ProcessControlHandle (ControlHandle)
Procedure ProcessControlHandle (ControlHandle)
   // code for process ControlHandle
