HMG 3.1.4
Carlos Britos
Re: HMG 3.1.4 (Test)
Hi.
the below attachments, capture and exe are on Xp.
The exe is not an HMG code but the related function SetCuebanner() is Almost identical. The exe is just to show the behaviour. The exe wwas compiled with harboour 3.2 and bcc but is the same with MinGW. Unicode and Ansi.
- capture in XP
- CAP1.png (4.48 KiB) Viewed 5610 times
- cue.zip
- exetest
- (1.07 MiB) Downloaded 278 times
HMG 3.1.4 (Test)
Hi Carlos, thank you for your patience and contribution. But your exe here in WinXP SP2 lamentably not working...
Shall be SP2/SP3 the problem ?
In Win7 is working perfectly.
Carlos Britos
Maybe I have sp3Pablo César wrote: Shall be SP2/SP3 the problem ?
HMG 3.1.4 (Test)
And for Spinner and ComboBox did not worked in HMG (even in Win7) and also not for EDITBOX, RICHEDITBOX (these last two, you said already not working).
HMG 3.1.4 (Test)
Yes Rathi, I also have found this... but I still do not understanding. I guess something in C:\hmg.3.1.4\MINGW\include\commctrl.h where COMCTL32_VERSION is declare to 5 or 6... but this is in MINIGW.Rathinagiri wrote:CueBanner is supported in XP as declared in MSDN here.
And as the MSDN suggests,
"Note To use this API, you must provide a manifest specifying Comclt32.dll version 6.0. For more information on manifests, see Enabling Visual Styles."
We have a manifest file in HMG Resource path. But how to enable!?
Carlos Britos
Remember combobox and spinner are specials controls, two or more in one.Pablo César wrote:And for Spinner and ComboBox did not worked in HMG (even in Win7) and also not for EDITBOX, RICHEDITBOX (these last two, you said already not working).
The combobox has listbox + textbox or label and spinner has updown + textbox.
To set the cuebanner you need the handle of the edit part. The textbox of combobox or spinner.
HMG 3.1.4 (Test)
Ahhh yes, you are right. I do not know how to do it, I will continue searching...Carlos Britos wrote:Remember combobox and spinner are specials controls, two or more in one.
Define window Form_1 at 0, 0 width 400 height 300 main Title "Demo2 - Carlos example"
DEFINE TEXTBOX Text_1
ROW 10
COL 10
WIDTH 200
END TEXTBOX
DEFINE TEXTBOX Text_2
ROW 40
COL 10
WIDTH 200
END TEXTBOX
DEFINE EDITBOX Edit_1
ROW 10
COL 230
WIDTH 120
HEIGHT 110
VALUE ""
END EDITBOX
DEFINE COMBOBOX Combo_1
ROW 70
COL 10
WIDTH 200
HEIGHT 100
ITEMS {"Item 1","Item 2","Item 3"}
VALUE 0
END COMBOBOX
DEFINE SPINNER Spinner_1
ROW 100
COL 10
WIDTH 200
HEIGHT 24
RANGEMIN 1
RANGEMAX 10
VALUE 0
END SPINNER
DEFINE RICHEDITBOX RichEdit_1
ROW 130
COL 230
WIDTH 120
HEIGHT 90
VALUE ""
END RICHEDITBOX
End window
SetTextBoxCueBanner("Form_1","Text_1","Enter your name here")
SetTextBoxCueBanner("Form_1","Text_2","Enter address here")
SetTextBoxCueBanner("Form_1","Spinner_1","Spinner CueBanner")
SetTextBoxCueBanner("Form_1","Combo_1","ComboBox CueBanner")
SetTextBoxCueBanner("Form_1","Edit_1","EditBox CueBanner")
SetTextBoxCueBanner("Form_1","RichEdit_1","RichEditBox CueBanner")
Form_1.center
Form_1.activate
Function SetTextBoxCueBanner(cParent,cControl,cText)
Local nHandle := GetControlHandle(cControl,cParent)
Setcuebanner(nHandle,cText,.t.) // Third parameter is for not dissapear when getfocus
#pragma BEGINDUMP
#define COMPILE_HMG_UNICODE
#include <HMG_UNICODE.h>
#include <windows.h>
#include <commctrl.h>
#define ECM_FIRST 0x1500 // Edit control messages
#define EM_SETCUEBANNER (ECM_FIRST + 1) // Set the cue banner with the lParm = LPCWSTR
HB_FUNC( SETCUEBANNER ) // (editHandle, cMsg) -> nil
#ifdef UNICODE
LPWSTR lpWCStr = HMG_parc(2) ;
#else
LPWSTR lpWCStr = (LPCWSTR) ( hb_parc(2) == NULL ) ? NULL : hb_mbtowc( (const char *) hb_parc(2) ) ;
#endif
SendMessage( (HWND) hb_parnl(1), EM_SETCUEBANNER, (WPARAM) hb_parl(3), (LPARAM) (LPCWSTR) lpWCStr ) ;
SysFreeString( lpWCStr );
#pragma ENDDUMPProbably for EditBox and RichEditBox would exist a way for do it too...
Carlos Britos
Please try with code
Note that:
in spinner GetControlHandle() return an array. So SetTextBoxCueBanner() need a trick to work.
in combobox I'm using FindWindowEx( GetControlHandle( "Combo_1", "Form_1" ), 0, "Edit", Nil ) to get the handle of textbox.
Note that:
Probably, I'd tried time ago but with no luck, sorry.Probably for EditBox and RichEditBox would exist a way for do it too...
ROW 10
COL 10
WIDTH 200
END TEXTBOX
ROW 40
COL 10
WIDTH 200
END TEXTBOX
ROW 10
COL 230
WIDTH 120
HEIGHT 110
VALUE ""
END EDITBOX
ROW 70
COL 10
WIDTH 200
HEIGHT 100
VALUE 0
DISPLAYEDIT .T. // must be .T. for cuebanner
END COMBOBOX
ROW 100
COL 10
WIDTH 200
HEIGHT 24
RANGEMIN 1
RANGEMAX 10
VALUE 0
END SPINNER
ROW 130
COL 230
WIDTH 120
HEIGHT 90
VALUE ""
END RICHEDITBOX
End window
// SetTextBoxCueBanner("Form_1","Spinner_1","Spinner CueBanner")
// SetTextBoxCueBanner("Form_1","Combo_1","ComboBox CueBanner")
Setcuebanner(FindWindowEx( GetControlHandle( "Combo_1", "Form_1" ), 0, "Edit", Nil ),"ComboBox CueBanner",.f.)
Setcuebanner( GetControlHandle( "Spinner_1", "Form_1" )[1],"Spinner CueBanner",.f.)
Form_1.center
Form_1.activate
Setcuebanner(nHandle,cText,.f.)
#pragma BEGINDUMP
#ifdef UNICODE
#else
#endif
#pragma ENDDUMP
Carlos Britos
Hi Pablo
En MSDN I saw this comment:
Maybe is the problem with sp2
Can you try if this is true for us ?wParam option note
wParam TRUE - only appears to work on Vista.
Under XP the cue text always disappears when the control gets focus regardless of this parameter.
Stanley Roark
4/13/2009
- srvet_claudio
Hi boys,Remember combobox and spinner are specials controls, two or more in one.
this is how to get all handles of a control:
hControl := GetControlHandle (cControlName, cParentName)
IF Valtype (hControl) == "A"
FOR i = 1 TO LEN(hControl)
ControlHandle := hControl [i]
ProcessControlHandle (ControlHandle)
Procedure ProcessControlHandle (ControlHandle)
// code for process ControlHandle
