Yeah ! I've got it ! Good... debug events is coming...srvet_claudio wrote:The idea of these functions is to try to create a debug for events (which is better suited to the GUI)
HMG 3.1.4
HMG 3.1.4 (Test)
Re: HMG 3.1.4 (Test)
gracias por la nueva version de HMG.
thanks for the new version of HMG, recently finished installing Windows 7 from scratch, I'll try
Hola Claudio : el IDE sigue sin funcionar el Windows 7 Home premium 64, recien termino de instalarlo y me da el error de Lenguaje, miro la carpeta y veo que Language.ini tiene tamaño 0kb.danielmaximiliano wrote:gracias por la nueva version de HMG.
HMG esta instalado con privilegios de administrador, mañana instalare Teamweaver para dejarte invertigar en la maquina. SLDS y gracias por el tiempo en el desarrollo de HMG.
Hi Rati & Claudio:
As allways WOW what a great job.-
I've download yesterday new 3.14 version, and till now all works fine.-
Rati: i've tested HMGDOC and as in previous versions except 3.46 it's not possible to put / print spanish characters.- Till now this is the only bug i found.-
No mather that, new functions are trully excellent.-
Congratulations. Masters friends.-
With regards.
Eduardo.
With regards.
Eduardo.
HMG 3.1.4 (Test)
New considerations and some others items have been redone at my re-edited message of:
http://hmgforum.com/viewtopic.php?p=27346#p27346
- esgici
Thanks a lot, very good enhancementChangeLog.txt wrote:New CueBanner demo in samples\controls\textbox\cuebanner (Contributed by S. Rathinagiri)
Hereafter we don't need define & use a separate LABEL as a prompt before each TEXTBOX
IMHO instead of being sample, this should be a new HMG function.
Viva HMG
Viva INTERNATIONAL HMG
The problem is it won't work in XP and below.
IMHO, CueBanner could be a replacement for ToolTip.
HMG 3.1.4 (Test)
Yes, It's a pity not working in XP...Rathinagiri wrote:The problem is it won't work in XP and below.
Or being optional...IMHO, CueBanner could be a replacement for ToolTip.
But really very good resource, Rathi. Thanks again for sharing with us !
chrisjx2002
Hello,
Is there a possiblity to make it work with XP?
It would be great as many people still have windows xp on their PC and it is quite difficult to make a special version when on xp.
