Selecting directory and choosing filtered file extensions.
NickSteel
Post by NickSteel »
I need to start with a windows directory tree, select a directory and select a
specified file extension if it exists.
I'm sure there's a sample for this, but I cannot find it.
Re: Selecting directory and choosing filtered file extension
You have to use GetFile() function.
Syntax of GetFile()
      GetFile ( acFilter ,  cTitle ,  cDefaultPath , lMultiSelect , lNoChangeDir ) -->SelectedFileName(s)
If <lMultiSelect> option is used, a character array containing selected
(maximun number of selected files returned is 63).
eg.: GetFile( { { "*.prg", "Harbour Program Files" }, { "*.ch", "Harbour Header Files" } } ,;
                  "Select a prg/ch file")
NickSteel
Post by NickSteel »
Opens the directory screen and allows changing directories, but does not list any *.prg files in directories where they exist.
Pardon my ignorance.
Sorry. You have to write like this.
GetFile( { { "Harbour Program Files", "*.prg" }, { "Harbour Header Files", "*.ch" } } ,;
NickSteel
Post by NickSteel »
:D
Does this return the location and file name for selecting? My program will parse the selected file into a DBF.
Yes.
NickSteel
Post by NickSteel »
If I use:
tempx = GetFile( { { "Harbour Program Files", "*.prg" }, { "Harbour Header Files", "*.ch" } } ,;
and
MsgInfo (tempx)
I get blank message box. How is best way to "see" the info in tempx?
Did you click cancel in the GetFile dialog?
It returns the selected filename along with the path.
Please try this sample...
   cFileName :=  GetFile( { { "Harbour Program Files", "*.prg" }, { "Harbour Header Files", "*.ch" } } ,;
   MsgInfo ( cFileName )
