Consulta sobre resolución de pantalla.
Re: Consulta sobre resolución de pantalla.
Thanks Danny :)
I was not tested Tool-Bar yet.
TIA :D
Any full updated version of AutoAdjust available?
Hi Rathi
Any problem after Danny's correction ?
I need that version only Esgici. All the corrections are in bits. I want the whole code.
Rathinagiri wrote:Any full updated version of AutoAdjust available?
Auto-adjust screen shoot
AutoAdjustD616.zip
Auto-adjust source files
(23.53 KiB) Downloaded 724 times
I'm not sure, it's "full" or not ;)
And this not updated version of original work of Miguel; adapted to MAIN.DEMO of HMG.
Thank you Esgici.
dhaine_adp
Post by dhaine_adp »
Hi Everyone,
Here's a tweak to AutoAdjust(). Backup your old code and then replaced the FOR...NEXT loop block with this:
   FOR k := 1 To ControlCount
      ControlName := _HMG_SYSDATA[ 2, k ]
      IF _IsControlDefined ( ControlName, ParentForm )
         ControlType := _HMG_SYSDATA[ 1, k ]
         IF !EMPTY( ControlName ) .AND. ;
            !( ControlType $ "MENU,HOTKEY,TOOLBAR,MESSAGEBAR,ITEMMESSAGE,TIMER" )
            DO CASE
               CASE ControlType == "RADIOGROUP"
                  _HMG_aControlSpacing     := _HMG_SYSDATA[ 22 ]
                  _HMG_aControlMiscData1   := _HMG_SYSDATA[  8 ]
                  _HMG_aControlSpacing [k] := _HMG_aControlSpacing [k] * IIF(_HMG_aControlMiscData1 [k], nDivw, nDivh)
               CASE ControlType == "SLIDER"     // do nothing
               CASE ControlType == "STATUSBAR"  // do nothing
               CASE ControlType == "TEXT"
                  _SetControlSizePos( ControlName, ParentForm,;
                  _GetControlRow( ControlName, ParentForm ) * nDivh, ;   // row
                  _GetControlCol ( ControlName, ParentForm ) * nDivw ,;  // column
                  _GetControlWidth( ControlName, ParentForm ) * nDivw,;  // with
                  _GetControlHeight ( ControlName, ParentForm ) )        // height
               CASE ControlType == "BUTTON"
                  _GetControlHeight ( ControlName, ParentForm ) )        // _GetControlHeight ( ControlName, ParentForm ) * nDivh )
               CASE !ControlType $ "TOOLBUTTON"
                  _SetControlSizePos ( ControlName, ParentForm,;
                  _GetControlRow ( ControlName, ParentForm ) * nDivh, _GetControlCol ( ControlName, ParentForm ) * nDivw,;
                  _GetControlWidth ( ControlName, ParentForm ) * nDivw, _GetControlHeight ( ControlName, ParentForm ) * nDivh )
            OTHERWISE
               IF EMPTY( _HMG_SYSDATA[ 28, k ] )
                  _SetFontSize ( ControlName, ParentForm , 8 * nDivh )
                  _SetFontSize ( ControlName, ParentForm , _HMG_SYSDATA[28] [k] * nDivh )
            ENDCASE
   NEXT k
What it does?
1. Basically it doesn't changed the height of TEXTBOX (TEXT), and BUTTON controls.
2. SLIDER and STATUSBAR width, height and font size never changed as well.
Its okay for me to change the width so that it can better fit the desktop width and height based on monitors resolution. However when the height (TEXTBOX, SLIDER, STATUSBAR and BUTTONS) changes the screen looks like it becomes magnified (technically this is correct but some users is not pleased by these kind of effect as a result of the aspect ratio computation).
You can add more exceptions by adding case statement such as (example):
CASE ControlType == "LABEL"
   **apply your changes here
Danny
Danny
Manila, Philippines
Very nice Steed !!!
Thank you Danny for your sharing !
This your code is more stable one. :D
I have added a slider row and width and seems ok as follows:
Function AutoAdjust( cForm )
Local hWnd := GetFormHandle( cForm )
Local i,;                    // From no
      k,;                    // Control no
      ParentForm,;
      ControlCount,;
      ControlName,;
      ControlType,;
      nWidth,;
      nHeight,;
      lvisible := .T.,;
      nDivw,;
      nDivh
IF GetDesktopWidth() < GetWindowWidth ( hWnd )
   nWidth := GetDesktopWidth()
   nWidth := GetWindowWidth ( hWnd )
IF GetDesktopHeight() < GetWindowHeight ( hWnd )
   nHeight := GetDesktopHeight()
   nHeight := GetWindowHeight( hWnd )
IF IsWindowVisible( hWnd ) .AND. ! IsAppXPThemed()
   HideWindow ( hWnd )
   lvisible := .F.
i := aScan ( _HMG_SYSDATA[67], hWnd )
ParentForm := _HMG_SYSDATA[66] [i]
IF _HMG_SYSDATA[ 92, i ] > 0 .AND. _HMG_SYSDATA[ 91, i ] > 0
   nDivw := nWidth  / _HMG_SYSDATA[ 92, i]
   nDivh := nHeight / _HMG_SYSDATA[ 91, i]
   nDivw := 1
   nDivh := 1
ControlCount := LEN ( _HMG_SYSDATA[ 3 ] )
         DO CASE
         OTHERWISE
         ENDCASE
NEXT k
_HMG_SYSDATA[92] [i] := nWidth
_HMG_SYSDATA[91] [i] := nHeight
IF lvisible
   ShowWindow ( hWnd )
I also added the new TimerPicker control and some others little changes with controls positioning in the sample demo at attached file.
MAIN.AUTOADJUST.rar
(23.62 KiB) Downloaded 457 times
AutoAdjust controls by window resizing
Looking for ShellAbout function present in our HMG library, came again to this topic...
I've noted some bugs and corrected already in C:\hmg.3.4.0\SAMPLES\Basics\MAIN_AUTOADJUST as follows:
  1. Fixed ShellAbout() in Demo.prg
  2. Optimized code in AutoAdjust.prg for RADIOGROUP,TEXT and BUTTON (it's the same treatment)
  3. Be included in Demo.prg new TimerPicker control
In attached here is the improved DEMO for C:\hmg.3.4.0\SAMPLES\Basics\MAIN_AUTOADJUST
MAIN_AUTOADJUST.rar
Source files
(23.6 KiB) Downloaded 446 times
demo.rar
Executable file
(1.14 MiB) Downloaded 489 times
Important:
I discovered a strange behaviour, when resizing works normally in XP and in Win7 AERO mode but in CLASSIC mode is not working at all (not working anything).
And I also cutted off ISAPPXPTHEMED() because the function is not working... :cry:
B.Rgds
