Codejock / RibbonBar
Re: Codejock / RibbonBar
Post by EduardoLuis »
Hi Daniel:
I check zip file and the compilation, and both works ok.-
I've tested on Hmg 3.046 and 3.13 and in both compiles ok.-
I use IDE to compile exe file.-
I attach new zip file containing EXE.-
demo2.zip
(1.52 MiB) Downloaded 453 times
fchirico
Post by fchirico »
EduardoLuis wrote:Hi Daniel:
Muchas gracias Eduardo!
Está re bueno!
Saludos, Fernando Chirico.
Gracias Fernando.-
Eduardo
Hi Dany:
Thanks for your calification.- (By the way: is not too much ????)
Thanks again.-
Eduardo
Leopoldo Blancas
Post by Leopoldo Blancas »
Hola DanielMaximiliano...
Si no va tu sello no vale.... jijiji
Polo
Leopoldo Blancas
Hola Eduardo Luis... se ve muy bien tus pantallas, felicidades!!!!
Pero mi pregunta es, con que programa haces esas imágenes?
Polo
Hello Eduardo Luis ... looks great your screens, congratulations!!
But my question is, with what program do these images?
Polo
Very nice !
Are there any "ribbonbar screen generators / editors" available for easy editing?
Hi friends:
Original ribbonbar as a friend told me is a .NET application.-
So, to create that type of menu (ribbonbar) you must have .NET developper systems.-
With .NET applications you can create a really ribbonbar menu, i mean, with all control predefined to each situation you need.- No mather i think this is not compatible with HMG.-
To create ribbonbar screens i use 3 programs.-
1.- PAINT, original application includes on all Window system.-
2.- The superb BosTaurus from our HMG specialist Claudio Soto to generate gradients.-
3.- ADOBE Photoshop for the final touchs.-
With PAINT and BosTauros i've create a big samples library with different types of buttons so when i decide to create a new application, some jobs are made.- That is the big job.
Each time i create a new ribbonbar, that one becomes a new sample on my library, so next one takes me less time to generate a new ribbond.-
After creating .BMP ribbonbar file, to avoid pixelation on the convertion to .JPG file, it's neccesary to proccess image with Adobe Photoshop to create a .JPG high resolution file.-
And that's all.
As i said before, it's a handmade job, that takes a big effort - principally to your eyes -, but the final result justify the effort.-
I hope this will help you.-
With regards. Eduardo
Hi Friends:
Since long time i was fascinated with ribbon bar, so i insist to apply this philosofy to my developes.-
Here goes a refurnished version of "Contacts".-
Unfortunetly i've forgot at home souce code, so today i upload only exe file and it's tables.-
Soon i'll upload code (after debuggin some unnecesary routines).-
Wishing all of you have a nice 2014, with regards. Eduardo
black_ribbon_bar.zip
(3.35 MiB) Downloaded 423 times
