Edit Extended / Edit WorkArea - ABM / ABM2
Re: Edit Extended
Puedes mostrarnos el comienzo de tu programa, es decir parte (no precisa todo), solo para hechar una mirada...
ahhh decime, los botones que viene en tu EDIT EXTENDED, son de HMG o no ?
Could post part of your code, please ?
Tell me something else, buttons displayed from EDIT EXTEND are the same of HMG or not ?
Gustavo Romo
Re: Edit Extended
My initial code is
#include 'miniGUI.ch'
ANNOUNCE RDDSYS
INIT PROCEDURE RDDINIT
REQUEST DBFCDX , DBFFPT
RDDSETDEFAULT('DBFCDX')
SET EXCLUSIVE OFF
SET DELETE ON
SET DATE BRITISH
SET EPOCH TO 1964
SET BROWSESYNC ON
SET NAVIGATION EXTENDED
REQUEST HB_LANG_ES
SET LANGUAGE TO SPANISH
InitMessages( "ES" )
HB_LANGSELECT( "ES" )
set defaul to \ceu\datos
USE \CEU\SISTEMA\CEU VIA "DBFCDX" NEW
SET PATH TO ALLTRIM(CEU->PDATOS)
DEFINE POPUP "Catalogos"
ITEM 'Maestros' ACTION EditaMaestro() IMAGE "C:\VUDL\ICONS\Catalogo.BMP"
Catalogo.prg
Procedure EditaMaestro()
USE MAESTRO VIA "DBFCDX" INDEX MAESTRO NEW
EDIT WORKAREA MAESTRO
CLOSE MAESTRO
no se como copiar la imagen del programa, pero son los mismos botones que HMG
ANNOUNCE RDDSYS
SET EXCLUSIVE OFF
SET DELETE ON
SET DATE BRITISH
SET EPOCH TO 1964
SET BROWSESYNC ON
REQUEST HB_LANG_ES
Catalogo.prg
CLOSE MAESTRO
- imagenhmg.png (40.25 KiB) Viewed 14261 times
Re: Edit Extended
Remueva ese: HB_LANGSELECT( "ES" ) y recompila.
Please comment HB_LANGSELECT( "ES" ) and rebuild it.
Gustavo Romo
Re: Edit Extended
remain the problem
permanece el problema
pero puedes ver en la imagen que los botones vienen en español, interesante no, solo afecta EDIT interesante no?
You can see in the image, EDIT FUNCTION still in English, msginfo in spanish
- HMG2.png (54.12 KiB) Viewed 14253 times
Re: Edit Extended
Ops pensé que era EDIT EXTENDED... es solo EDIT ?
Ahhh no hé hecho ningun test de lenguage, todavia...
Ops EXTENDED EDIT I thought it was ... is only EDIT?
Ahhh hé not made any language test, yet ...
Re: Edit Extended
Para mi tanto en HMG como en Minigui Extended, me funciona bien en español.
Cual serian las versiones de HMG y Minigui Extended ? Talvez sea ai el problema.
For me both as MiniGUI Extended HMG I works well in Spanish.
What would be the versions of HMG and MiniGUI Extended? Maybe the problem is ai.
Gustavo Romo
Re: Edit Extended
just for example purpose send to you EDIT EXTENDED
- HMG3.png (73.42 KiB) Viewed 14250 times
Edit Extended
Eses son los botones de Minigui Extended, no de HMG. El problema debe estar en Minigui Extended. Talvez la version... fijate !
That is the MiniGUI Extended buttons and not of HMG. The problem must be in MiniGUI Extended. Perhaps the version ... Look up !
Re: edit extended
Bonsoir comment rendre l'interface de EDIT-Extended en francais merci d'avance pour vos reponses
Hi how to make the interface EDIT-Extended in french thank you in advance for your answers
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
Re: edit extended
Please read this: http://hmgforum.com/viewtopic.php?p=27009#p27009tonton2 wrote:Bonsoir comment rendre l'interface de EDIT-Extended en francais merci d'avance pour vos reponses
