HMG 2.9.0 (Forum test)
- Roberto Lopez
- HMG Founder
Harbour MiniGUI 2.9.0 Changelog:
English:
- Fixed: Grid (CellNavigation). OnChange event not fired when selection is automatically changed after accepting cell edit with [Enter].
Roberto.
English:
Roberto.
- hmg290.rar
- (367.24 KiB) Downloaded 408 times
Re: HMG 2.9.0 (Forum test)
Thanks a lot Roberto.
Thank´s Master Roberto,
for this nice and great work.
Hi Roberto,Roberto Lopez wrote:Harbour MiniGUI 2.9.0 Changelog:
There is a double checking for CellNavigation flag in the h_windows.prg.
Please take a look for the following code:
* Grid Processing .....................................
if (_HMG_SYSDATA [1] [i] = "GRID") .Or. (_HMG_SYSDATA [1] [i] = "MULTIGRID")
IF _HMG_SYSDATA [32] [i] == .T. // first checking for CellNavigation flag
* Grid Key Handling .........................
If GetNotifyCode ( lParam ) = LVN_KEYDOWN
IF _HMG_SYSDATA [32] [i] == .T. // check again??
Do Case
- Roberto Lopez
- HMG Founder
CellNavigation has been a very complicated and difficult to debug feature.gfilatov wrote:Hi Roberto,Roberto Lopez wrote:Harbour MiniGUI 2.9.0 Changelog:
Please take a look for the following code:May be to fix an aboved issue in this buildCode: Select all
* Grid Processing ..................................... if (_HMG_SYSDATA [1] [i] = "GRID") .Or. (_HMG_SYSDATA [1] [i] = "MULTIGRID") IF _HMG_SYSDATA [32] [i] == .T. // first checking for CellNavigation flag * Grid Key Handling ......................... If GetNotifyCode ( lParam ) = LVN_KEYDOWN IF _HMG_SYSDATA [32] [i] == .T. // check again?? Do Case ...
It is possible that the code could be optimized, but until now, I've focused on bugs.
I'll take a look at it ASAP.
Thanks for reporting.
Roberto.
Roberto,Roberto Lopez wrote:CellNavigation has been a very complicated and difficult to debug feature.
Thanks for your attention, maestro
I'm glad to help for code's optimization.
- Roberto Lopez
- HMG Founder
You are right. It was a completely nonsense double checkgfilatov wrote: There is a double checking for CellNavigation flag in the h_windows.prg.
I've removed the extra 'if'.
Roberto.
Talking about code optimization, the lines:
could be rewritten:
According to a quick test that i have done, the second "optimized" version is more than twice faster compared to the first.
P.S. Of course the above "optimization" it is proposed just for "educational / academical" reasons and in no way should be taken as correction, because we all know that the "real life coding" has its own rules, priorities and necessities..
regards,
Pete
if (_HMG_SYSDATA [1] [i] $ "MULTIGRID")
IF (_HMG_SYSDATA [32] [i])
regards,
Pete
