OBJ parameter
OBJ parameter
Dear gentlemen,
I have found this interesting code which is for OOHG:
 * ComboBox Sample n° 7
 * Author: Fernando Yurisich <fernando.yurisich@gmail.com>
 * Licensed under The Code Project Open License (CPOL) 1.02
 * See <http://www.codeproject.com/info/cpol10.aspx>
 * Based on a sample from OOHG distribution
 * (c) 2002 Roberto Lopez
 * Modified by Ciro Vargas Clemow <cvc@oohg.org>
#include "oohg.ch"
FUNCTION Main
   WIDTH 400 ;
   HEIGHT 200 ;
   TITLE 'CaretPos in ComboBox with DisplaEdit Clause' ;
   DEFINE MAIN MENU
      DEFINE POPUP 'Test'
         MENUITEM 'Get Value' ;
            ACTION autoMsgInfo( oCombo:Value )
         MENUITEM 'Set Value' ;
            ACTION oCombo:Value := 1
         MENUITEM 'Get DisplayValue' ;
            ACTION MsgInfo( oCombo:DisplayValue )
         MENUITEM 'Set DisplayValue' ;
            ACTION ( oCombo:DisplayValue := 'New Text', ;
                     oCombo:SetFocus(), ;
                     oCombo:CaretPos := 3 )
      END POPUP
   END MENU
   @ 10,10 COMBOBOX Combo_1 OBJ oCombo ;
      ITEMS { 'Orange' , 'Black' , 'Yellow' } ;
      VALUE 1 ;
      DISPLAYEDIT ;
      IMAGE {} ;
      ON DISPLAYCHANGE ForceUpperCase( oCombo, oText )
    oCombo:FontColorSelected := GREEN
    oCombo:BackColorSelected := YELLOW
   @ 50, 10 TEXTBOX Text_1 OBJ oText
CENTER WINDOW Form_1
STATIC FUNCTION ForceUpperCase( oCombo, oText )
LOCAL nPos := oCombo:CaretPos
oText:value := oCombo:DisplayValue
oCombo:DisplayValue := Upper( oCombo:DisplayValue )
oCombo:CaretPos := nPos
Please note there is a new directive for declaring all components: OBJ which assigned a name o one OBJECT.
My question is:
Is It possible to get this in HMG ?
This would give use more power for assignements on our code ?
Re: OBJ parameter
HMG 3.xx is not based on objects.
So can not use suc a code:
It's possible in HMG 4.x, but this release is suspended.
OBJ parameter
Thank you Marek for replying.
I thought it could be a good idea to work at leat as semi-OOP. But as you said, HMG4 it was already. Which is a very sad to have been discontinued the work of HMG4...
We ended up losing a lot without it... so sad ! :cry:
Re: OBJ parameter
Pablo César wrote: Which is a very sad to have been discontinued the work of HMG4...
I agree with you...
OBJ parameter
Probably one of the reasons they have discouraged the development of HMG4 may have been the lack of an IDE.
I was enjoying seeing the HMG4 being adapted to work in semi-OOP...
Re: OBJ parameter
Hola Pablo :
Yo en T.Pascal utilizaba "objetos", la forma más basica era esta.
type
alumnos = RECORD
clave:integer;
nombre:string[30];
estatura:real;
end;
var
alumno:alumnos;
BEGIN
clrscr;
(* capturando registro *)
write('dame clave : ');readln(alumno.clave);
write('dame nombre : ');readln(alumno.nombre);
write('dame estatura : ');readln(alumno.estatura);
(* operaciones *)
alumno.estatura := alumno.estatura + 0.23456;
(* despliegue *)
writeln;writeln;
writeln('clave : ',alumno.clave);
writeln('nombre : ',alumno.nombre);
writeln('estatura : ',alumno.estatura:0:2);
readln;
END.
ya estoy adaptando mi codigo para trabajar de esa manera
alumno:nombre := 'Pablo'
alumno:grabar
ud puede adaptar y trabajar con OBJETOS tanto HMG y su codigo :
míre usted hmg.ch y textbox.prg dentro de hmg.4, haga una pequeña modificacion a los sources de hmg.3 y haga una prueba si funciona.
parcial codigo de textbox.prg
   TEXTBOX class
CLASS TEXTBOX FROM CONTROL
   DATA cClass                                    INIT   "TEXTBOX"
// data: please preserve alphabetic order.
   DATA nAlignment                  INIT  TXT_LEFT       PROTECTED
   DATA nCaseConvert                INIT  TXT_NONE       PROTECTED
	DATA oColor                      INIT	NIL         	PROTECTED
   DATA nDataType                   INIT  NIL            PROTECTED
   DATA cDecPoint                   INIT  "."            PROTECTED // by default USA format
   DATA cFormat                     INIT  ""             PROTECTED // by default USA format ELSE European
   DATA lLostFocusExecFlag          INIT  .F.            PROTECTED
   DATA cThousands                  INIT  ","            PROTECTED // by default USA format
   DATA nMaxLength                  INIT  NIL            PROTECTED
   DATA cInputMask                  INIT  ""             PROTECTED // what user set
   DATA xItemDisplay                INIT  NIL            PROTECTED
   DATA xItemEdit                   INIT  NIL            PROTECTED
   DATA bOnValid                    INIT  NIL            PROTECTED
   DATA cPictDateFormat             INIT  ""             PROTECTED
   DATA cPictDisplay                INIT  ""             PROTECTED
   DATA cPictEdit                   INIT  ""             PROTECTED
   DATA oRegExp                     INIT  NIL            PROTECTED
   DATA cRegExpValidator            INIT  NIL            PROTECTED
   DATA oRegExpValidator            INIT  NIL            PROTECTED
   DATA xValue                      INIT  NIL            PROTECTED
parcial codigo para hmg.ch
  #command @ <nRow>, <nCol> TEXTBOX <tagreference> ;
      [ <dummy1: OF, PARENT> <oParent> ]      ;
      [ TOVAR <varname> ] ;
      [ HEIGHT <nHeight> ]                   ;
      [ WIDTH <nWidth> ]                     ;
      [ FIELD <cField> ]            ;
      [ VALUE <cValue> ]                     ;
      [ < lReadOnly: READONLY > ]          ;
      [ FONT <cFontName> ]                   ;
      [ SIZE <nFontSize> ]                   ;
      [ <lFontBold : BOLD> ]            ;
      [ <lFontItalic : ITALIC> ]         ;
      [ <lFontUnderline : UNDERLINE> ]      ;
      [ <lFontStrikeout : STRIKEOUT> ]      ;
      [ TOOLTIP <cToolTip> ]                 ;
      [ BACKCOLOR <aBackColor> ]         ;
      [ FONTCOLOR <aFontColor> ]         ;
      [ DISABLEDBACKCOLOR <aDisabledBackColor> ]   ;
      [ DISABLEDFONTCOLOR <aDisabledFontColor> ]   ;
      [ MAXLENGTH <nMaxLength> ]         ;
      [ <lUpper: UPPERCASE> ]            ;
      [ <lLower: LOWERCASE> ]            ;
      [ <lNumeric: NUMERIC> ]            ;
      [ <lDate: DATE> ]                  ;
      [ <lPassWord: PASSWORD> ]         ;
      [ INPUTMASK <cInputMask> ]      ;
      [ FORMAT <cFormat> ]      ;
      [ ON CHANGE <bOnChange> ]         ;
      [ ON GOTFOCUS <bOnGotFocus> ]         ;
      [ ON LOSTFOCUS <bOnLostFocus> ]         ;
      [ ON ENTER <bOnEnter> ]      ;
      [ <lRightAlign: RIGHTALIGN> ]   ;
      [ <lNoVisible: INVISIBLE> ]   ;
      [ <lNoTabStop: NOTABSTOP> ]   ;
      [ HELPID <nHelpId> ]       ;
   With Object [<varname> :=] TEXTBOX():New(<"tagreference"> [ , <oParent> ]) ;;
      [:Row      := <nRow>      ]   ;;
      [:Col      := <nCol>      ]   ;;
      [:Width      := <nWidth>      ]   ;;
      [:Height   := <nHeight>      ]   ;;
      [:Field      := <"cField">      ]   ;;
      [:Value      := <cValue>      ]   ;;
      [:lReadOnly   := <.lReadOnly.>   ]   ;;
      [:FontName   := <cFontName>      ]   ;;
      [:FontSize   := <nFontSize>      ]   ;;
      [:FontBold   := <.lFontBold.>   ]   ;;
      [:FontItalic   := <.lFontItalic.>   ]   ;;
      [:FontUnderline   := <.lFontUnderline.>   ]   ;;
      [:FontStrikeout   := <.lFontStrikeout.>   ]   ;;
      [:ToolTip   := <cToolTip>      ]   ;;
      [:BackColor   := <aBackColor>      ]   ;;
      [:FontColor   := <aFontColor>      ]   ;;
      [:MaxLength   := <nMaxLength>      ]   ;;
      [:PassWord   := <.lPassWord.>   ]   ;;
      [:InputMask   := <cInputMask>      ]   ;;
      [:Format   := <cFormat>      ]   ;;
      [:OnChange   := <{bOnChange}>   ]   ;;
      [:OnGotFocus   := <{bOnGotFocus}>   ]   ;;
      [:OnLostFocus   := <{bOnLostFocus}>   ]   ;;
      [:OnEnter   := <{bOnEnter}>      ]   ;;
      [:Visible   := !<.lNoVisible.>   ]   ;;
      [:TabStop   := !<.lNoTabStop.>   ]   ;;
      [:HelpId   := <nHelpId>      ]   ;;
      [:Alignment      := if( <.lRightAlign.> , 2 , 0 ) ]         ;;
      [:DisabledBackColor   := <aDisabledBackColor>   ]            ;;
      [:DisabledFontColor   := <aDisabledFontColor>   ]            ;;
      [:CaseConvert      := if ( <.lUpper.> , 1 , If( <.lLower.> , 2 , 0  )  ) ]   ;;
      [:DataType      := if ( <.lNumeric.> , 1 , if( <.lDate.> , 2 ,0 )) ]         ;;
   End With
OBJ parameter
Gracias Daniel por responder.
Lo que quieres decirnos es que es posible implementar objetos modificando el código fuente de HMG 3 ? Confirma eso ? Porque yo no hé hecho cambios de esta naturaleza. En ese punto, busco ser conservador, pero seria interesante tu confirmación. Porque con modificaciones poderíamos evaluar la posibilidad de dejar HMG3 en SEMI-OOP y dejarlo como opcional con la clausula "OBJ" (asi como lo hace en OOHG). Eso claro si es aprobado por Roberto Lopez, asi tendríamos mas poder de acceso a objetos.
-- Transalated to English
What you tell us is that objects can be implemented by modifying the source code of HMG 3? Please, could you confirm it ? Because I not use to male this source modifications. At that point, I try to be conservative, but it would be interesting to your confirmation. For with changes we could evaluate the possibility of let HMG3 ready to work with SEMI-OOP and with optional clause "OBJ" (as well as it does in ooHG). Of course under Roberto approval, so we would have more access to objects.
