Incremental Search with Combo Box
Re: Incremental Search with Combo Box
We may ask Roberto to add sort .t. and ondisplaychange event to the in-place-edit combobox controls.
sudip
Post by sudip »
Hi Esgici,
Regarding HMG documentation, COMBOBOX under COLUMNCONTROLS property of GRID have only one property /parameter : acItems; neither event, nor method.
Can COLUMNVALID {....} code block array be used for this?
With best regards.
Nope. For using the incremental search, either we have to use sort .t. or ondisplaychange event.
IMHO Columnvalid event would be fired only when the control losts its focus.
Hi
Another ( unsuccessful ) try for incremental search.
Not in Combo box, but somewhat similar it : combined a text box and a listbox, namely Combined Search Box :idea:
At beginning, the idea look liked me feasible, until terminated :(
For seeing the problem please uncomment line 27 :
@ 55, 190 TEXTBOX txbMessy
Any idea for surmount this problem ?
CSBox.zip
Combined Search Box try
(2.71 KiB) Downloaded 309 times
OMG! It is really fantastic Esgici. It shows various possibilities of HMG.
My suggestions: (I am also trying)
1. To do away the problem of overlapping controls behind the listbox, we can write a "HideControlsBehind()" function for the "on gotfocus" event of the text box, for all the controls that have either row or col or having visibility in that region of listbox. And, "on lostfocus" event would do "ShowControlsBehind()" of course.
2. We can have an "On Enter/On lostfocus" event for the textbox to select and hide the listbox once the user presses enter key at any time.
sudip
Post by sudip »
Esgici,
Excellent !!! :D
Regards.
Hi Esgici,
I think, I had done away the overlapping controls problem.
Try this code. I am further modifying...
CSBox.prg
  CSBox ( Combined Search Box ) try
#include "minigui.ch"
PROC Main()
   aCountries := HB_ATOKENS( MEMOREAD( "Countries.lst" ),   CRLF )
   ASORT( aCountries )                    // This Array MUST be sorted
   DEFINE WINDOW frmCSBTest ;
      WIDTH 550 ;
      HEIGHT 300 ;
      TITLE 'CSBox ( Combined Search Box ) Test' ;
      MAIN ;
      ON INIT MakeCSBs()
      ON KEY ESCAPE ACTION frmCSBTest.Release
   END WINDOW // frmCSBTest
   frmCSBTest.Center
   frmCSBTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROC MakeCSBs()                           // Making CSBox(s)
   DefnCSBox( ThisWindow.Name, 'Country',;         // Names suffix
                               'Country Name :',;  // Prompt
                               25,;                // CSBox Box Row No
                               100,;               // CSBox Box Col No
                               200,;               // Text Box Width
                               20,;                // Text Box Height
                               aCountries )
   frmCSBTest.TxBCountry.SetFocus()
RETU // MakeCSBs()
PROC DefnCSBox( ;                           // Define a CSBox
              cFrmName,;    // Form / Window Name
              cCSBName,;    // CSBox Name
              cLblValu,;    // Prompt
              nCSBRow,;     // CSBox Row No
              nCSBCol,;     // CSBox Col No
              nTxBWidth,;   // Text Box Width
              nTxBHeight,;  // Text Box Height
              aArray )      // Search array
    LOCAL cLblName := "Lbl" + cCSBName,;
          cTxBName := "TxB" + cCSBName,;
          cLsBName := "LsB" + cCSBName,;
          nLblWidt := 0,;
          nTxBCol  := 0,;
          nLsBRow  := 0
    DEFINE LABEL &cLblName
       PARENT    &cFrmName
       ROW        nCSBRow
       COL        nCSBCol
       HEIGHT     nTxBHeight
       VALUE      cLblValu
       RIGHTALIGN .T.
       AUTOSIZE   .T.
    END LABEL // &lblName
    nLblWidt := GetProperty( cFrmName, cLblName, "WIDTH" )
    nTxBCol  := nCSBCol + nLblWidt + 5
    DEFINE TEXTBOX &cTxBName
       PARENT   &cFrmName
       ROW      nCSBRow - 2
       COL      nTxBCol
       WIDTH    nTxBWidth
       HEIGHT   nTxBHeight
       ONCHANGE SetCSBoxVal( cFrmName, this.name , aArray )
    END TEXTBOX // &cTxBName
    nLsBRow := GetProperty( cFrmName, cTxBName, "ROW" ) + nTxBHeight - 1
    DEFINE LISTBOX &cLsBName
       PARENT   &cFrmName
       COL      nTxBCol
       ROW      nLsBRow
       WIDTH    nTxBWidth
       HEIGHT   200
       ITEMS    {}
    END LISTBOX
    SetProperty( cFrmName, cLsBName, "VISIBLE", .F. )
RETU // DefnCSBox()
PROC SetCSBoxVal( ;                       // Setting CSBox values
                  cFrmName,;   // Form / Windows name
                  cTxBName,;   // Text Box Name
                  aList )      // Items list
   LOCAL cCurval  := GetProperty( cFrmName, cTxBName, "Value" ),;
         nFrmHeig := GetProperty( cFrmName, "HEIGHT" ),;
         aResults := {},;
         n1Result := 0,;
         cLsBName := "LsB" + SUBSTR( cTxBName, 4 ),;
         c1Found  := '',;
         cMethod  := '',;
         lNoResult := .F.
    IF !EMPTY( cCurval )
       WHILE ( n1Result := ASCAN( aList, { | c1 | UPPER( LEFT( c1, LEN( cCurval ) ) ) == UPPER( cCurval )}, n1Result + 1 ) )  > 0  ;
             .AND. n1Result < LEN( aList )
          AADD( aResults, aList[ n1Result ] )
       ENDDO
       IF !EMPTY( aResults )
          nLsBRow  := GetProperty( cFrmName, cLsBName, "ROW" )
          nLsBCol  := GetProperty( cFrmName, cLsBName, "COL" )
          nLsBLeng := GetProperty( cFrmName, cLsBName, "WIDTH" )
          nLsBHeig := MAX( MIN( LEN( aResults ) * 15,  nFrmHeig - nLsBRow - 40 ), 20 )
          DoMethod( cFrmName, cLsBName, "Release" )
          for i := 1 to len(_hmg_sysdata[1])
                if ((_hmg_sysdata[18,i] > nLsBRow .and. _hmg_sysdata[18,i] < nLsBRow + nLsBHeig) .or. (_hmg_sysdata[18,i]+_hmg_sysdata[21,i] > nLsBRow .and. _hmg_sysdata[18,i]+_hmg_sysdata[21,i] < nLsBRow + nLsBHeig)) .and. ((_hmg_sysdata[19,i] > nLsBCol .and. _hmg_sysdata[19,i] < nLsBCol + nLsBLeng) .or. (_hmg_sysdata[19,i]+_hmg_sysdata[20,i] > nLsBCol .and. _hmg_sysdata[19,i]+_hmg_sysdata[20,i] < nLsBCol + nLsBLeng)) .and. _hmg_sysdata[4,i] == GetFormHandle(CFrmName)
					setproperty(cFrmName,_hmg_sysdata[2,i],"VISIBLE",.f.)
          next i
             PARENT     &cFrmName
             ROW        nLsBRow
             COL        nLsBCol
             WIDTH      nLsBLeng
             HEIGHT     nLsBHeig
             ITEMS      aResults
             VALUE      1
             ONDBLCLICK {||SetProperty( cFrmName, cTxBName, "VALUE", this.item( this.value ) ),;
						   SetProperty( cFrmName, cLsBName, "VISIBLE", .F. ),;
					       CSBoxSearchOver()}
          END LISTBOX
          SetProperty( cFrmName, cLsBName, "VISIBLE", .T. )
          lNoResult := .T.
       ENDIF !EMPTY( aResults )
       lNoResult := .T.
    ENDIF !EMPTY( cCurval )
    IF lNoResult
RETU // SetCSBoxVal()
function CSBoxSearchOver()
Local nLsBRow := this.row
Local nLsBCol := this.col
Local nLsBLeng := this.width
Local nLsBHeig := this.height
Local cFrmname := thiswindow.name
					setproperty(cFrmName,_hmg_sysdata[2,i],"VISIBLE",.t.)
          next i
return nil
Hi Rathi
Thanks your interest an participations.
I'll try.
My expectation is an intervention by Roberto.
sudip wrote: Excellent !!! :D
Thanks Sudip, but
May I differ with you?
rathinagiri wrote:I had done away the overlapping controls problem.
Hi Rathi
Thanks a lot, tried, works fine, without overlapping :)
Now, I am working to understand your code :)
