Print Preview in HMG, CatchysoftActiveX,PrintPreview Activex
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Re: Print Preview in HMG, CatchysoftActiveX,PrintPreview Act
Post by karweru »
Thank you so much Rathi...this will be very usefull.
Kind regards,
Gilbert.
Hola amigos
Haber si les puede servir este ejemplo que utiliza la libreria TPRINT
la libreria está en: http://www.embalajesterra.com/misdoc/pr ... ramas.html
Google Translate
Hello friends
Have if they can serve this example that uses the library TPRINT
The bookstore is in:
Factura.zip
(818.92 KiB) Downloaded 575 times
Hola Mustafa, my brother; welcome back !
What happiness hearing you :D
I hope that you are fine :)
and I wish more see you :)
I'll examine your participation, thanks.
Saludos cordiales
Hi All
esgici wrote: ...I'll examine your participation...
Done :)
This program is bigger than seen ;)
Mustafa, thanks again to share :)
A bit modified by courtesy of author:
Slightly modified GenFactura (image)
GenFactura.zip
Slightly modified GenFactura (source files)
(229.54 KiB) Downloaded 572 times
Thank you form example etc. to esgici and mustafa
jairpinho
Post by jairpinho »
Thank Mustafa by example Factura.zip helped me in my system
mustafa wrote:Hola amigos
Google Translate
Hello friends
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
jairpinho
Post by jairpinho »
Thank Esgici by example GenFactura.zip helped me in my system
esgici wrote:Hi All
Done :)
GenFactura.zip
Jair Pinho
