I found a mistake in the parameterization when the DBF is clicked on folder whose name contains spaces (for example, My Documents), then STRU did not interpret the path+name of the DBF because he was not quoted.
The parameter should contain quotes to receive fully the file name, as follows: C:\..\Stru.exe "%1" /G
File compressed file was actualized already for new download.
fchirico
Post by fchirico »
Pablo César wrote:The "Setup" option now has one more item that allows access to STRU by clicking on DBF in Window Explorer:
Excelent!!!!
Thank you.
Saludos, Fernando Chirico.
Pablo César wrote:Ohh thank you amigo Esgici, as always you are so kind !
I sent a MP to Dr. Soto, asking for any C code solution for these specialfolders cases.
Shall wait and I´ll revert to you.
Best regards
Hola Pablo :
para las carpetas MSDM tiene esto :
http://msdn.microsoft.com/en-us/library ... older.aspx
Thanks Fernando for your enjoying !
Thank you Daniel, I have already solved this was a UNICODE convertion for special folders in my code. The problem was when comes with latin accents, but now I've fixed. Tks.
Now I am working in MEMO extension file auto-recognizing and it is working very well...
At begining I have decided to let user or fixed format (DBT/FPT), but I've found a problem when file was not existing then the system crash... but now accessing in low level without memo file, we can know which type is. It is quite ready but I am finishing tomorrow. I am still recovering from surgery, but I believe tomorrow or on monday I finish this:
aMemos:={{"0x02","FoxBase",""},;
         {"0x03","dBASE III, dBASE IV, dBASE 5, dBASE 7, FoxPro, FoxBASE+",""},;
         {"0x04","dBASE 7",""},;
         {"0x30","Visual FoxPro","FPT"},;
         {"0x31","Visual FoxPro",""},;
         {"0x43","dBASE IV, dBASE 5",""},;
         {"0x63","dBASE IV, dBASE 5",""},;
         {"0x83","dBASE III, FoxBase+, FoxPro","DBT"},;
         {"0x8B","dBASE IV, dBASE 5","DBT"},;
         {"0x8C","dBASE 7","DBT"},;
         {"0xCB","dBASE IV, dBASE 5","DBT"},;
         {"0xE5","SMT","SMT"},;
         {"0xEB","dBASE IV, dBASE 5","DBT"},;
         {"0xF5","FoxPro","FPT"},;
         {"0xFB","FoxBase",""},;
         {"0x54","dBASE IV with SQL","DBT"},;
         {"0xA7","FoxPro 2.x (or older)","DBT"},;
         {"0xB9","FoxBase",""},;
         {"0xE2","dBASE III+ or FoxBase+","DBT"},;
         {"0xEF","dBASE IV","DBT"}}
This is an Array with codes, descriptions and extension names for DBf with Memo fields. I've compoused from many sources (I hope to be in good order).
Another thing is to implement with a persistent routine for opening DBFs that I should do too.
Thanks at all for your entusiastic comments and interests. :D
Hi Pablo.
To develop applications that support ANSI and UNICODE, we must abandon those text functions that only support ANSI character set. Here is a partial list of equivalences:
           ANSI/UNICODE               ANSI Only
-          HMG_LEN()             <=>   LEN()
-          HMG_LOWER()           <=>   LOWER()
-          HMG_UPPER()           <=>   UPPER()
-          HMG_PADC()            <=>   PADC()
-          HMG_PADL()            <=>   PADL()
-          HMG_PADR()            <=>   PADR()
-          HMG_ISALPHA()         <=>   ISALPHA()
-          HMG_ISDIGIT()         <=>   ISDIGIT()
-          HMG_ISLOWER()         <=>   ISLOWER()
-          HMG_ISUPPER()         <=>   ISUPPER()
-          HMG_ISALPHANUMERIC()  <=>   RETURN (ISALPHA(c) .OR. ISDIGIT(c))
-          (*) HB_USUBSTR()      <=>   SUBSTR()
-          (*) HB_ULEFT()        <=>   LEFT()
-          (*) HB_URIGHT()       <=>   RIGHT()
-          (*) HB_UAT()          <=>   AT()
-          (*) HB_UTF8RAT()      <=>   RAT()
-          (*) HB_UTF8STUFF()    <=>   STUFF()
           (*) Harbour native functions
You have to replace in the source code all functions which only supports ANSI character set for ANSI/UNICODE equivalent functions.
Claudio.
PS: Hi all, this comment is true for all the applications that you develop for UNICODE.
srvet_claudio wrote:To develop applications that support ANSI and UNICODE, we must abandon those text functions that only support ANSI character set. Here is a partial list of equivalences:
Harbour native functions:
HB_UAT()          <=>   AT()
That's right !!! Great, Dr. Soto ! Now it is clear for me ! Many thank you !
It is very very good to use UNICODE mode. IMO this is the right way... It is wonderfull ! Thank you Dr. Soto for your genious idea ! :)
Routine persistence for DBF opening has been implemented with also auto-recognition of type of DBF, as promissed as follows:
I hope to be enjoyed !
<Attached file removed, see last message with new release>
Gracias amigo
Good advance :)
Viva HMG :D
Thank amigo Esgici for your interest ! :)
By the way, is it possible to correct your Turkish.Lng file in UTF-8 format and post to us ? And please also let us know if STRU is working properly in your language (in console and GUI modes).
B.Rgds
Pablo César wrote:is it possible to correct your Turkish.Lng file in UTF-8 format and post to us ?
Done (new lines added).
Tested, no problem encountered for both ( Console and Windows) modes.
Thanks a lot again :)
Viva HMG :D
TurkishLng.zip
Turkish Language file for STRU application
(1.93 KiB) Downloaded 431 times
