HMG 3.1.2
jairpinho
Re: HMG 3.1.2 (Test)
Post by jairpinho »
hello I'm having trouble with accents. I installed version 3.1.2 of HMG following image like this my system
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Amigo, falta você configurar o seu editor para o padrão UTF-8. Isso se já colocou o Set Language to Portuguese.
jairpinho
Post by jairpinho »
Pablo César wrote:Amigo, falta você configurar o seu editor para o padrão UTF-8. Isso se já colocou o Set Language to Portuguese.
Portugues:
Ola Pablo mas o problema seria no formulário da IDE, esta escrito com acento normal porem quando compila fica com caracteres estranhos
Inglês:
Hello Pablo but the problem would be in the form of IDE, it is written with an accent standard however is when compiling with strange characters
Jair Pinho
jairpinho
Post by jairpinho »
jairpinho wrote:hello I'm having trouble with accents. I installed version 3.1.2 of HMG following image like this my system
new forms created with HMG IDE are in ANSI format, should have an option in the IDE to change the Encode leaving default for new forms, I have to open all forms created through the IDE with an editor and convert to UTF8 to stay with correct characters.
Jair Pinho
joposadas
Post by joposadas »
I have the same problem and I have not changed my FRM because they are many, and hopefully the new release can make the change in the IDE.
I using the version 3.0.46 because I have the accent problem
I believe the problem is in IDE which creates a frm files in ANSI format. But we have not source codes of HMG/IDE, so if you still are using fmg files, you can edit with Notepad++ en UTF-8 format correcting brazilian accents and save file.
Try to modify the forms with the publisher, on entering search and replace to change the character and the character it replaces, I use that and is more practical.
jairpinho
Post by jairpinho »
danielmaximiliano wrote:Try to modify the forms with the publisher, on entering search and replace to change the character and the character it replaces, I use that and is more practical.
Hello Daniel and Pablo César
It was exactly what I did, open the files fmg and converted to UTF8, but this should be done by the IDE to new forms or an option in preferences that could choose a standard UTF8/ANSI etc..
Jair Pinho
Esperemos que Roberto lea estas lineas y pueda realizar un nuevo IDE con estas necesidades.
I'm working on the conversion of the IDE to support the Unicode character set.
