HMG 3.1.2
dhaine_adp
Re: HMG 3.1.2 (Test)
Post by dhaine_adp »
Hola Doctor,
I'm sorry Danny, it's my fault.
You change in file C:\hmg.3.1.2\SOURCE\UNICODE_STRING.prg
Code:
#translate HMG_LEN (<x>) => LEN (<x>)
#translate HMG_LOWER (<c>) => LOWER (<c>)
#translate HMG_UPPER (<c>) => UPPER (<c>)
#translate HMG_PADC (<x>,<n>,[<c>]) => PADC (<x>,<n>,[<c>])
#translate HMG_PADL (<x>,<n>,[<c>]) => PADL (<x>,<n>,[<c>])
#translate HMG_PADR (<x>,<n>,[<c>]) => PADR (<x>,<n>,[<c>])
for:
Code:
FUNCTION HMG_LEN(x); RETURN LEN (x)
FUNCTION HMG_LOWER(c); RETURN LOWER (c)
FUNCTION HMG_UPPER(c); RETURN UPPER (c)
FUNCTION HMG_PADC(x,n,c); RETURN PADC(x,n,c)
FUNCTION HMG_PADL(x,n,c); RETURN PADL(x,n,c)
FUNCTION HMG_PADR(x,n,c); RETURN PADR(x,n,c)
and rebuild the lib. with ANSI option (comment line #define COMPILE_HMG_UNICODE)
Claudio.
Muchas gracias Dr. Claudio para que esto esté arreglado. :D Now, it is working fine.
I have explored the generated libhmg.a using http://codigo-base.blogspot.com/search/ ... orer%20Lib
There are strange code attached to unicode_string.o in libhmg.a One possibility is that Explorer Lib does not support unicode. It seems its not a big deal though as long as the Public symbols, external symbols and COFF format is recognized. Other HMG objects are ok. This condition is the same between HMG Unicode Enabled and HMG ANSI build. See attached.
Thank you very much again for the fixed.
Danny
Danny
Manila, Philippines
Steed
Post by Steed »
Hi Again,
I post a little video at first compilation the text_box contros works well, bud at the second try it fails
Prueba error.rar
(381.98 KiB) Downloaded 880 times
thanks,
Ed
mol wrote:
Steed wrote:
srvet_claudio wrote:
Hi Ed.
Can you post a small example and describe the bug ?
Claudio
Hi, Claudio,
1- Run prueba.exe
2- Hit Properties button
3- Hit Save Button
Save button execute the next code:
cTemp:=GetProperty('Win2','Text_1a','Value')
msgbox(alltrim(cTemp)+"x")
But in a randomly manner the value is not returned, sometimes msgbox shows: "Pruebax"
And sometimes only shows "x"
The attachment Prueba.rar is no longer available
The attachment test1.PNG is no longer available
Thanks for your attention
Ed
I've compiled your sample with hmg 3.0.46 and 3.1.2. Everytime result of SAVE button was good.
Code is so simple, so I can't see any bug within.
Strange...
PS. One error was in line about 120 in procedure Get_Folders
before
SetProperty('Win2','Text_'+ntrim(Opz),'Value',cFolder)
after change
SetProperty('Win2','Text_'+ntrim(Opz)       + "a"      ,'Value',cFolder)
Marek
Steed
Post by Steed »
Hi, Claudio
after follow the steps that you suggets to dhaine_adp
and
y recompile the example
HMG_MYSYNC.rar
(8.22 KiB) Downloaded 847 times
, the text_box controls work well bud something happend with the grid that doesn´t show correctly the content
It should be "C:\Ins\" and not "H"
Sorry to bother you with that but the issues with the text_box is a problem.
with out comment line #define COMPILE_HMG_UNICODE
again the text_boxt fails
Steed wrote:Hi Again,
The attachment Prueba error.rar is no longer available
thanks,
Ed
Steed wrote:Sorry to bother you with that but the issues with the text_box is a problem.
Hi Ed.
It's a strange problem, I made several tests with HMG.3.1.2 and works well your code.
Claudio.
Dear colleagues Rathinagiri and Dr. Soto, is it possible to release a new version 3.1.3 ? With all patches and missing libs ?
Pablo César wrote:Dear Rathinagiri,
I am still without your return my questions of these:
Pablo César wrote:Dear Rathinagiri, thank you for this new release but basically in this version are applied modifications of UNICODE adjustments but regarding Build.bat in samples, Build.bat at HMG main folder, ComboSearchBox, AutoAdjust sample/library and QHTM library have It been included or not yet ?
Please also note to update in next release, version.txt file was not updated. In this last one version.txt should contains "3.1.2 (Test 2013-04-04)".
and
srvet_claudio wrote:Maybe lack the menu patch viewtopic.php?p=25991#p25991
Steed
Post by Steed »
Sorry, to be recurrent but even in this little example the textbox control fails
Atacched please find complied example (.exe)
prueba0.rar
(765.08 KiB) Downloaded 933 times
Function Main()
 DEFINE WINDOW Prueba AT 252 , 489 WIDTH 368 HEIGHT 274 MAIN
    DEFINE TEXTBOX Text_1
        ROW    90
        COL    100
        WIDTH  120
        HEIGHT 24
        VALUE ""
    END TEXTBOX
    DEFINE BUTTON Button_1
        ROW    120
        COL    110
        WIDTH  100
        HEIGHT 28
        ACTION Muestra()
        CAPTION "Button_1"
    END BUTTON
 Prueba.Center
 Prueba.Activate
Procedure Muestra()
   local cTemp
   cTemp:=Prueba.Text_1.Value
   msgbox(cTemp+"X")
Thanks again for your attention and help
Leopoldo Blancas
Post by Leopoldo Blancas »
Hola Steed...
Tu aplicación no falla, lo compile y todo Ok
Function Main()
        ROW    90
        COL    100
        WIDTH  120
        HEIGHT 24
        VALUE ""
    END TEXTBOX
        ROW    120
        COL    110
        WIDTH  100
        HEIGHT 28
        ACTION Muestra()
        CAPTION "Button_1"
    END BUTTON
 Prueba.Center
 Prueba.Activate
Procedure Muestra()
   local cTemp
   msgbox(cTemp+"X")
   Prueba.Text_1.Value := cTemp + " X"  //AGREGUE ESTO
Steed
Post by Steed »
Gracias, leopoldo
Probaste con el .exe que envié adjunto ?
si no, podiras probar con el exe adjunto, sin compilar en tu maquina.
cuando haces click en el boton deberia motrar el contenido del label+"x" pero ami solo me muestra la "x"
Algunas veces ejecuta bien, pero si la cierro y la ejecuto nuevamente comienza a fallar
Gracias,
Ed
Leopoldo Blancas wrote:Hola Steed...
Leopoldo Blancas
Hola Steed...
Ya lo volví a hacer con tu exe y todo bien..., por que no cargas otra vez el HMG.3.1.2,
Polo
Hello Steed ...
I did it again with your exe and all good ..., why not again HMG.3.1.2 loads,
Polo
dhaine_adp
Hi Steed,
I also tried your HMG_MySync and Prueba. I never encountered the problem you have described. I test it on Win XP Pro SP2 without XP Theme. Everything works fine for me.
If I am not mistaken there are two patches on this release, one reported by Marek (Mol) and the other one is about ANSI and UTF8. Have you tried a clean install of HMG 3.1.2? If you've done it then take a look at your <hmgDirInstallFolder>\IDE\hmg.ini if it match your current installation directory. Correct it if it didn't match.
Also check your buildalllib.bat if it points to the correct path. Then rebuild your HMG Libs. Look at the code below this is my test:
Function Main()
        ROW    90
        COL    100
        WIDTH  120
        HEIGHT 24
        VALUE ""
    END TEXTBOX
        ROW    120
        COL    110
        WIDTH  100
        HEIGHT 28
        ACTION MsgBox( ltrim( rtrim( Prueba.Text_1.Value) ) + "X", "Test" )  // MsgInfo( ltrim( rtrim( Prueba.Text_1.Value) ) + "X" , "Test" )   //
        CAPTION "Button_1"
    END BUTTON
 Prueba.Center
 Prueba.Activate
Procedure Muestra()
   local cTemp
   msgbox(cTemp+"X")
Both of them works perfectly with me and I won't be able to duplicate the problem you have posted. When you rebuild your test apps, delete the executable files and the hbmk folder if present or simply from the IDE do Reset Project Incremental Data. Then build your app again.
Danny
Danny
Manila, Philippines
