HMG 3.1.2
Re: HMG 3.1.2 (Test)
Pablo César wrote:Dear Rathinagiri,
I am still without your return my questions of these:
Pablo César wrote:Dear Rathinagiri, thank you for this new release but basically in this version are applied modifications of UNICODE adjustments but regarding Build.bat in samples, Build.bat at HMG main folder, ComboSearchBox, AutoAdjust sample/library and QHTM library have It been included or not yet ?
Please also note to update in next release, version.txt file was not updated. In this last one version.txt should contains "3.1.2 (Test 2013-04-04)".
Hi Pablo,
Your point is well taken. In the next version I will do the needful. I am sure it follows soon.
srvet_claudio wrote:
mol wrote:I've prepared simple sample. Try to compile it.
First, press button "Load Modal Window #1" on Main Form, then try to load or define Window #2.
Error occurs.
When you press "Load Modal Window #2" on Main Form - everything works OK.
When you remove ONCHANGE phrase from Browse control, everything works OK.
This problem is caused by evaluating code blocks while loading or defining windows, I think.
Regards, Marek
Hi Marek.
I fixed the problem.
Please replace c:\hmg.3.1.2\source\h_menu.prg for the h_menu.prg attachment file, and rebuild the HMG.
Claudio.
I have no problems with MENU's now!
I'm testing whole application.
Thanks Claudio, you are speedy as always :lol:
rathinagiri wrote:Your point is well taken. In the next version I will do the needful. I am sure it follows soon.
Thank you amigo, for yours considerations !
mol wrote:I have no problems with MENU's now!
Wow Good News !!! Mr. Claudio Our genius !
Something is wrong with printing subsystem. I'll try to trace problems tomorrow.
Let sb. try to print something and write about results.
Marek
Steed
Post by Steed »
Steed wrote:Frist at all,I have to say many thanks.
Bud I have to report that the issue with the textbox control remained
Ed
Hi Ed.
Can you post a small example and describe the bug ?
Claudio
Hi, Claudio,
1- Run prueba.exe
2- Hit Properties button
3- Hit Save Button
Save button execute the next code:
cTemp:=GetProperty('Win2','Text_1a','Value')
msgbox(alltrim(cTemp)+"x")
But in a randomly manner the value is not returned, sometimes msgbox shows: "Pruebax"
And sometimes only shows "x"
Prueba.rar
(1.65 KiB) Downloaded 408 times
Thanks for your attention
Ed
Ed
Hi Ed.
Claudio
Hi, Claudio,
1- Run prueba.exe
3- Hit Save Button
Prueba.rar
Ed
I've compiled your sample with hmg 3.0.46 and 3.1.2. Everytime result of SAVE button was good.
Code is so simple, so I can't see any bug within.
Strange...
PS. One error was in line about 120 in procedure Get_Folders
before
SetProperty('Win2','Text_'+ntrim(Opz),'Value',cFolder)
after change
SetProperty('Win2','Text_'+ntrim(Opz)       + "a"      ,'Value',cFolder)
Marek
mol wrote: I've compiled your sample with hmg 3.0.46 and 3.1.2. Everytime result of SAVE button was good.
Strange...
before
after change
Marek
I also tested with HMG.3.1.2 (Win 7) and it worked fine with compile for ANSI and UNICODE.
dhaine_adp wrote:Hi,
I rebuild HMG Lib 3.1.2 with ANSI only by putting a comment to SET_COMPILE_HMG_UNICODE.ch and execute buildalllib.bat
1. I created another folder and named it as c:\hmg-ansi
2. I copied the contents of HMG 3.1.2 folder and put them to c:\hmg-ansi
3. I edit hmg.ini and put c:\hmg-ansi
4. Put comment marker on //#define COMPILE_HMG_UNICODE
5. At the command prompt inside the c:\hmg-ansi I typed: buildalllib > result.txt
6. I modified my projects .hbc and point everything to c:\hmg-ansi
When I compile the application I've got errors as shown below:
Did I miss something? It seems like during the rebuilding process the compiler didn't pick-up the missing reference (undefined reference) from #else block of #ifdef...#else...#endif of <hmgdir>\source\unicode_string.prg
Please test if you can duplicate the problem on Windows XP Pro SP2.
Also the redirected result.zip (result.txt) file attached (from command line) generated looks like a unicode text file format. Looks funny on ASCII editor and in notepad++ reached about 8000+ lines.
hbmk2: Warning: Non-portable output filename: '-oppcmembers-ansi.exe'. Delete
'.exe' extension.
Harbour 3.2.0dev (r1303181903)
Copyright (c) 1999-2013, http://harbour-project.org/
C:/hmg-ansi/lib/libhmg.a(h_controlmisc.o):h_controlmisc.c:(.data+0x28): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_controlmisc.o):h_controlmisc.c:(.data+0x208): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_windows.o):h_windows.c:(.data+0x38): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_windows.o):h_windows.c:(.data+0x10e8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_status.o):h_status.c:(.data+0x48): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_status.o):h_status.c:(.data+0x58): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_toolbar.o):h_toolbar.c:(.data+0x128): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_menu.o):h_menu.c:(.data+0x2c8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_dialogs.o):h_dialogs.c:(.data+0xb8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_hotkey.o):h_hotkey.c:(.data+0x68): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_label.o):h_label.c:(.data+0x108): undefined reference to `HB_FUN_HMG_LOWER'
C:/hmg-ansi/lib/libhmg.a(h_button.o):h_button.c:(.data+0x158): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_textbox.o):h_textbox.c:(.data+0x148): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_textbox.o):h_textbox.c:(.data+0x228): undefined reference to `HB_FUN_HMG_LOWER'
C:/hmg-ansi/lib/libhmg.a(h_textbox.o):h_textbox.c:(.data+0x2b8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_combo.o):h_combo.c:(.data+0x78): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_checkbox.o):h_checkbox.c:(.data+0x148): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_browse.o):h_browse.c:(.data+0xa8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_browse.o):h_browse.c:(.data+0x948): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_tab.o):h_tab.c:(.data+0x58): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_tab.o):h_tab.c:(.data+0x128): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_radio.o):h_radio.c:(.data+0xe8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_tree.o):h_tree.c:(.data+0xd8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_grid.o):h_grid.c:(.data+0x68): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_grid.o):h_grid.c:(.data+0xb8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libhmg.a(h_font.o):h_font.c:(.data+0xb8): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libhmg.a(h_timer.o):h_timer.c:(.data+0xa8): undefined reference to `HB_FUN_HMG_UPPER'
C:/hmg-ansi/lib/libgraph.a(h_graph.o):h_graph.c:(.data+0x118): undefined reference to `HB_FUN_HMG_LEN'
C:/hmg-ansi/lib/libini.a(h_ini.o):h_ini.c:(.data+0x1f8): undefined reference to `HB_FUN_HMG_LEN'
gcc.exe C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/ppcmembers.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/archive.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/auditdashboard.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/chkinifile.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/classprogressbar.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/codegen.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/datacollection.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/dbfmaketable.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/dialogue.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/exp2excel.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/filemain.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/genclassbrwobj.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/gregcivil.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/makefile.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/nsdlacommfunc.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/ppcmaster.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/recordpicker.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/reports.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/rptpersonalinfo.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/theviewport.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/treeclassview.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/usermgr.o C:/DOCUME~1/Danny/LOCALS~1/Temp/hbmk_0k4uhy.dir/hbmk_xrfeqb.o F:/DAD/members/_temp.o -Wl,--nxcompat -Wl,--dynamicbase -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lhfcl -lini -lreport -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lvalleylibs -ldaleaidcommon -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -o"ppcmembers-ansi.exe" -L"C:/hmg-ansi/harbour/lib/win/mingw" -L"C:/hmg-ansi/lib" -L"c:/hmg-ansi/lib"
hbmk2: Error: Referenced, missing, but unknown function(s): HMG_UPPER(),
HMG_LEN(), HMG_LOWER()
TIA,
Danny
I'm sorry Danny, it's my fault.
You change in file C:\hmg.3.1.2\SOURCE\UNICODE_STRING.prg
   #translate HMG_LEN (<x>)    =>   LEN (<x>)
   #translate HMG_LOWER (<c>)   =>   LOWER (<c>)
   #translate HMG_UPPER (<c>)   =>   UPPER (<c>)
   #translate HMG_PADC (<x>,<n>,[<c>])   =>   PADC (<x>,<n>,[<c>])
   #translate HMG_PADL (<x>,<n>,[<c>])   =>   PADL (<x>,<n>,[<c>])
   #translate HMG_PADR (<x>,<n>,[<c>])   =>   PADR (<x>,<n>,[<c>])
for:
   FUNCTION HMG_LEN(x); RETURN LEN (x)
   FUNCTION HMG_LOWER(c); RETURN LOWER (c)
   FUNCTION HMG_UPPER(c); RETURN UPPER (c)
   FUNCTION HMG_PADC(x,n,c); RETURN PADC(x,n,c)
   FUNCTION HMG_PADL(x,n,c); RETURN PADL(x,n,c)
   FUNCTION HMG_PADR(x,n,c); RETURN PADR(x,n,c)
and rebuild the lib. with ANSI option (comment line #define COMPILE_HMG_UNICODE)
Claudio.
Does will be useful :?:
SET ENCODING ANSI/UTF8
( yet another global setting :( )
